AM2431: Multiple boot images
Part Number: AM2431
Hello Expert,
I have a question regarding the boot process. We have slightly modified SBL ospi.
We are running our application on offset 0x100000 and we would also like to switch
to a different application in case a certain condition is met.
Is it possible to boot from different offsets ?
Could you provide me with information on what is necessary to change for this to be possible ?
BR,
Dominik Ondra
  • Hi ,
    The Application Offset is hard-coded via syscfg information. In case you wish to support a mechanism to support multiple locations, you can modify the same software for the flow and test the same.
    Check the variable in ti_drivers_config.c
    According to your use-case, the appImageOffset needs to be modified during the run-time.
    Aakash
