MSPM0L1306: instruction guide -> number of cpu clocks
Part Number: MSPM0L1306
is there any document how many cpu clocks an assemble instruction needs?
Can I measure the cpu clocks in CCS?
Regards, Holger
  • Hi Holger,
    There is a ton of information on the web regarding ARM, instruction set and number of clock cycles. Just make sure you search for M0+ instruction set.
    Try this one to start with -> Developer.arm.com
    Unfortunately, there is no way to measure within CCS, but if you enable the SYSTICK timer, it runs at the same clock rate as the CPU.  It won't be perfect, but it will give you some measurement of cycles.
