Part Number: MSPM0L1306-Q1
Other Parts Discussed in Thread: CCSTUDIO
Hi Experts,
Can CCS theia generate disassembly code from C source?
Thank you for your check.
Hitoshi
Hi Experts,
Hitoshi
Hi Keith,
It seems that the customer sometimes needs to check the assembler code for the debug.
He would like just to know if CCS Theia has this feature or not.
If it supports, he could check the assembly code when the optimization level setting etc. is changed.
Hioshi
Hi Hitoshi,
CCS theia supports the disassembly. I would recommend customers to use CCSTUDIO(CCSTUDIO IDE, configuration, compiler or debugger | TI.com).
Yuhao
Hi Yuhao,
Understood that both CCS and CCS Theia support disassembly view only.
Hitoshi Sugawara
