Part Number: AM2434
Hello Experts,
I have a couple questions regarding the profinet stack in the industrial-communications-SDK-AM243X.
- In the latest version (09.01.00) the Profinet Stack is available only with a temporary license. Is there any update on when a permanent license will be available?
- I'm considering to use an older version of the MCU-PLUS-SDK (version 08.03.00) where it uses a different profinet stack with a permanent license in order to start production. Will using this stack cause any problem with the latest versions of the AM2434 and will it work without any time limitation?
Thank you for your help.
Andrea Favero
