Part Number: TMS570LC4357
CCS/TMS570LC4357: TMS570LC4357: bootloader application jump leads to SVC entry.
Recently I am working on the UART boot loader on TMS570LC4357. I found a example from TI itself.
Bootloader located in Bank0 and Application in Bank1.
Switch from Bootloader to application works properly, but when going into application and call OS_StartScheduler(); this not working.
as i know from the Documents , "The device supports only one exception vector table which is located at the beginning of the flash (0x00000000). When one SVC exception occurs in my application, the code branches to 0x08 in the exception table in 0x0000000".
my application start address :APP_START_ADDRESS 0x00200100
;Bootloader HL_sys_intvecs.asm
; HL_sys_intvecs.asm
; Copyright (C) 2009-2018 Texas Instruments Incorporated - www.ti.com
; Redistribution and use in source and binary forms, with or without
; modification, are permitted provided that the following conditions
; are met:
; Redistributions of source code must retain the above copyright
; notice, this list of conditions and the following disclaimer.
; Redistributions in binary form must reproduce the above copyright
; notice, this list of conditions and the following disclaimer in the
; documentation and/or other materials provided with the
; distribution.
; Neither the name of Texas Instruments Incorporated nor the names of
; its contributors may be used to endorse or promote products derived
; from this software without specific prior written permission.
; THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
; "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
; LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
; A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
; OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
; SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
; LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
; DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
; THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
; (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
; OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
.sect ".intvecs"
.arm
; import reference for interrupt routines
.ref _c_int00
.ref _svc
.ref phantomInterrupt
.def resetEntry
; interrupt vectors
resetEntry
b _c_int00
undefEntry
b undefEntry
b _svc
prefetchEntry
b prefetchEntry
dataEntry
b dataEntry
b phantomInterrupt
ldr pc,[pc,#-0x1b0]
ldr pc,[pc,#-0x1b0]
