Using High-End Timer (HET) in TMS470R1B1M
I am starting to write up code to implement UART using timer on TM470R1B1. Found an application note SPNA097 (attached) and HET timer user guide SPNA069 (attached). Following these two and sample code B1M_HET_UART_9600_H.het along with .h and .c, I added to project.
But, I keep getting the following errors upon build. Please let me know if I am missing anything here.
Error[Pe020]: identifier "HET_MEMORY" is undefined
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 31
Error[Pe020]: identifier "DJNZ_INSTRUCTION" is undefined
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 34
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 35
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 36
Error[Pe020]: identifier "SHFT_INSTRUCTION" is undefined
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 37
Error[Pe020]: identifier "MOV32_INSTRUCTION" is undefined
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 38
Error[Pe020]: identifier "BR_INSTRUCTION" is undefined
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 39
Error[Pe020]: identifier "MCMP_INSTRUCTION" is undefined
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 40
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 41
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 42
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 43
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 44
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 45
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 46
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 47
Error[Pe020]: identifier "ADCNST_INSTRUCTION" is undefined
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 48
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 49
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 50
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 51
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 52
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 53
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 54
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 55
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 56
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 57
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 58
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 59
C:\.......\ChipDemo_Sci\B1M_HET_UART_9600_H.h 66
Error while running C/C++ Compiler
-          Sai
