Part Number: TMS570LC4357
Hi, I would like to have information about the F021 Flash API code, needed for certification purposes.
Thank you.
Thank you.
Hi Cabriele,
The F021 Flash API source code is under NDA control. Does your company have NDA with TI?
TI does not normally distribute the source code. The reason is that modifying the code can potentially impact the flash in the devices. A modified API must not be used in your application. For creating a flash programming solution, the flash API library must be used as provided by TI.
