AM2634: Error initializing emulator: (Error -260 @ 0x0)
Part Number: AM2634
Hii
Today I tried to debug a program for AM2634-LP , I encountered following error-
DEBUGSSM_0: Error initializing emulator: (Error -260 @ 0x0) An attempt to connect to the XDS110 failed. The cause may be one or more of: no XDS110 is connected, invalid firmware update, invalid XDS110 serial number, or faulty USB cable. The firmware and serial number may be updated using the xdsdfu utility found in the .../ccs_base/common/uscif/xds110 directory of your installation. View the XDS110SupportReadMe.pdf file there for instructions. (Emulation package 12.6.0.00029)
device manager detects the xds110 debug probe.
but when i run xdsdfu -m command, it gives the requested device not found
C:\ti\ccs1260\ccs\ccs_base\common\uscif\xds110>xdsdfu -m
USB Device Firmware Upgrade Utility
Copyright (c) 2008-2019 Texas Instruments Incorporated. All rights reserved.
Scanning USB buses for supported XDS110 devices...
The requested device was not found on the bus.
How to solve this issue??
