Part Number: TMS570LC4357
I would like to request the source code of the F021 API for certification purpose. I understand that is possible in this case.
Please, let me know further steps to follow.
Thank you!
Thank you!
Hi Luis,
The F021 Flash API source code is under NDA control. Does your company have NDA with TI?
TI does not normally distribute the source code. The reason is that modifying the code can potentially impact the flash in the devices. A modified API must not be used in your application. For creating a flash programming solution, the flash API library must be used as provided by TI.
Thanks & regards,
Jagadish
