MCU-PLUS-SDK-AM263PX: Ethernet LWIP TCP Client SDK Example for Control Card - Abort Error
Part Number: MCU-PLUS-SDK-AM263PX
Other Parts Discussed in Thread: UNIFLASH, DP83869
I am getting an About Error (-13) at netconn_connect() when I run the MCU-PLUS-SDK-AM263PX SDK example: enet_cpsw_tcpclient_am263px-cc_r5fss0-0_freertos_ti-arm-clang
I made some minor changes for handling the IPv4 addresses. Namely, the sever address is hard-coded, and the client is using static IP instead of DHCP.
When I run the same 'application code' on the AM263x Control Card version of the project, it works.
The hardware setup is the same.
The TCP Server is running Wireshark. I can see the transmissions for AM263x, but there are none for AM263Px.
The Ethernet cable is connected to the middle (with sticker) port on AM263x.
Before I spend additional time troubleshooting, I want to check:
Is there any differences between the Control Cards, or SDKs that would cause the About Error (-13) on AM263Px when running the same application-layer code?
  • Hi TollMan,
    Just to eliminate confusions and isolate the problem, can you please let me know the result of running enet_loopback or enet_layer2_cpsw example on AM263Px.
    The out of box applications are expected to work and if the logic works for AM263x, it should have for AM263Px as well.
    Can you also let me know the bootmode? Are you flashing your application image or loading the .out file from CCS (for AM263Px)
    Shaunak
  • Hi Shaunak,
    I am running Bootmode == SPI (8S) - Octal Read Mode
    The SBL is SBL_NULL.
    I tested with: enet_loopback_am263px-cc_r5fss0-0_freertos_ti-arm-clang running only the first core. Hopefully this is a valid test.
    This is gEnetLpbk halted upon the call to EnetApp_showMenu():
    Observations:
    1)
    Is the value of the gEnetLpbk.hostMacAddr suspicious?
    Perhaps the value was not written to the EVK?
    2)
    I do not see any meaningful Debug_Log() printfs when I run enet_loopback_am263px-cc_r5fss0-0_freertos_ti-arm-clang.
    This is what I see:
    *** Enabling Peripheral Clocks ***
    Cortex_R5_0: GEL Output: Enabling RTI[0:3] Clocks
    Cortex_R5_0: GEL Output: Enabling RTI_WDT[0:3] Clocks
    Cortex_R5_0: GEL Output: Enabling UART[0:5]/LIN[0:5] Clocks
    Cortex_R5_0: GEL Output: Enabling QSPI Clocks
    Cortex_R5_0: GEL Output: Enabling I2C Clocks
    Cortex_R5_0: GEL Output: Enabling TRACE Clocks
    Cortex_R5_0: GEL Output: Enabling MCAN[0:3] Clocks
    Cortex_R5_0: GEL Output: Enabling MMCSD Clocks
    Cortex_R5_0: GEL Output: Enabling MCSPI[0:4] Clocks
    Cortex_R5_0: GEL Output: Enabling CONTROLSS Clocks
    Cortex_R5_0: GEL Output: Enabling CPTS Clocks
    Cortex_R5_0: GEL Output: Enabling RGMI[5,50,250] Clocks
    Cortex_R5_0: GEL Output: Enabling XTAL_TEMPSENSE_32K Clocks
    Cortex_R5_0: GEL Output: Enabling XTAL_MMC_32K Clocks
    ***All IP Clocks are Enabled***
    Tollman
  • Hi Tollman,
    Do you not see any prints in the terminal window? The above prints are the gel script logs. Do you not see any application initialization logs in the terminal?
    Shaunak
  • Hi Shaunak,
    Regarding:
      "Do you not see any prints in the terminal window?"
    I retested with the same results. Running the loopback SDK example without breakpoint only outputs:
    Regarding:
    I do not see any. I verified that:
      EnetApp_showMenu()
    ...is executing which contains:
      DebugP_log("%s", loopbackTestMenu);
    I also ran a 'known good' SDK example:
      adc_soc_continuous_am263px-cc_r5fss0-0_nortos_ti-arm-clang
    ...to verify there is not a setup issue. I see prints running that example:
    [Cortex_R5_0] ADC Soc Continuous Test Started
    ADC 1 channel 0 output:
    9
    1081
    1080
    1080
    1080
    1082
    1081
    1081
    1081
    1082
    1081
    ADC Soc Continuous Test Passed
    All tests have passed!!
    Tollman
  • Hi Tollman,
    Apologies for the delayed response and thanks for being patient. I tried to replicate the issue but I was not able to.
    I suspect it might also be due to some incorrect configurations in PLL clocks (coming from the gel files). Can we once test the same application by flashing the image to the board. We do have a known issue with CCS 12.5 and CCS 12.6 where the gel files incorrectly configure the clock and the board Rx does not work properly. This issue is seen only in the case of AM263Px and I suspect that is the blocker here.
    Please follow the steps shown here: https://software-dl.ti.com/mcu-plus-sdk/esd/AM263X/latest/exports/docs/api_guide_am263x/TI_UNIFLASH_TOOL.html
    Wanted to try it on your end since I was unable to replicate it
    Shaunak
  • The application appears to run normally when I execute the image loaded from OSPI. I'll bottom-paste the printf log below for confirmation.
    What can be done to allow me to develop, and debug a project based on the enet_cpsw_tcpclient_am263px-cc_r5fss0-0_freertos_ti-arm-clang SDK example?
    Tollman
    Here is the printf log:
    [HSM_CLIENT] New Client Registered with Client Id = 0<CR><LF>
    Starting OSPI Bootloader ... <CR><LF>
    [BOOTLOADER_PROFILE] Boot Media : NOR SPI FLASH <CR><LF>
    [BOOTLOADER_PROFILE] Boot Media Clock : 133.333 MHz <CR><LF>
    [BOOTLOADER_PROFILE] Boot Image Size : 0 KB <CR><LF>
    [BOOTLOADER_PROFILE] Cores present : <CR><LF>
    r5f0-0<CR><LF>
    [BOOTLOADER PROFILE] System_init : 265us <CR><LF>
    [BOOTLOADER PROFILE] Drivers_open : 107us <CR><LF>
    [BOOTLOADER PROFILE] LoadHsmRtFw : 13414us <CR><LF>
    [BOOTLOADER PROFILE] Board_driversOpen : 33724us <CR><LF>
    [BOOTLOADER PROFILE] CPU load : 78us <CR><LF>
    [BOOTLOADER_PROFILE] SBL Total Time Taken : 47593us <CR><LF>
    <CR><LF>
    Image loading done, switching to application ...<CR><LF>
    <CR><LF>
    0: Internal MAC loopback <CR><LF>
    1: External PHY loopback <CR><LF>
    <CR><LF>
    Enter option:
    4/22/2024 13:13:09.998 [TX] - 0
    4/22/2024 13:13:10.011 [RX] - 0
    4/22/2024 13:13:13.163 [TX] - <CR><LF>
    4/22/2024 13:13:13.177 [RX] - <CR><LF>
    =============================<CR><LF>
    Enet Loopback: Iteration 1 <CR><LF>
    CPSW_3G Test<CR><LF>
    EnetAppUtils_reduceCoreMacAllocation: Reduced Mac Address Allocation for CoreId:0 From 4 To 2 <CR><LF>
    PHY 0 is alive<CR><LF>
    initQs() txFreePktInfoQ initialized with 16 pkts<CR><LF>
    Received 5000 packets<CR><LF>
    Delete EnetApp_rxTask() and exit..<CR><LF>
    Transmitted 5000 packets <CR><LF>
    Delete EnetApp_txTask() and exit..<CR><LF>
    <CR><LF>
    Port 0 Statistics<CR><LF>
    -----------------------------------------<CR><LF>
    rxGoodFrames = 5000<CR><LF>
    rxBcastFrames = 5000<CR><LF>
    rxOctets = 2590000<CR><LF>
    txGoodFrames = 5000<CR><LF>
    txBcastFrames = 5000<CR><LF>
    txOctets = 2590000<CR><LF>
    octetsFrames512to1023 = 10000<CR><LF>
    netOctets = 5180000<CR><LF>
    txPri[0] = 5000<CR><LF>
    txPriBcnt[0] = 2590000<CR><LF>
    <CR><LF>
    <CR><LF>
    Port 1 Statistics<CR><LF>
    <CR><LF>
    Cpsw_handleLinkDown:1655 <CR><LF>
    Test complete: PASS<CR><LF>
    Enet Loopback: Iteration 2 <CR><LF>
    <CR><LF>
    <CR><LF>
    <CR><LF>
    <CR><LF>
    Enet Loopback: Iteration 3 <CR><LF>
    EnetAppUtils_reduceCoreMacAllocation: Reduced Mac Address Allocation for CoreId:0 From 4 To 1 <CR><LF>
    <CR><LF>
    <CR><LF>
    <CR><LF>
    <CR><LF>
    Enet Loopback: Iteration 4 <CR><LF>
    <CR><LF>
    <CR><LF>
    <CR><LF>
    <CR><LF>
    Enet Loopback: Iteration 5 <CR><LF>
    <CR><LF>
    <CR><LF>
    <CR><LF>
    <CR><LF>
    Loopback application completed<CR><LF>
    All tests have passed!!<CR><LF>
  • Hi Tollman,
    Thanks for running the tests and confirming the issue. So the issue is with the gel files which are incorrectly initializing the PLL clocks. These gel files shall be fixed in the next CCS release. I will provide the gel files. Please replace it in the mentioned path and try running again with the correct gel files.
    Path: C:\ti\ccs1260\ccs\ccs_base\emulation\gel\AM263P\AM263Px_PLL
    AM263Px_PLL.gel
    Replace the gel file here. Restart your CCS and try again
    OR
    Alternatively, since the issue persists because of the gel files, in CCS, open your target configuration for AM263Px, go to Advanced, select Cortex_R5_0 and remove the csp gel file path is in the Initialization script field. Then launch your target config, run in OSPI bootmode with SBL NULL.
    Shaunak
  • I replaced the gel file, and restarted CCS as suggested. However, I think there is still a problem since I do not see the printfs that were seen when running from OSPI.
    When I run:
    ... in debug mode I see on the console:
    Cortex_R5_0: GEL Output: Gel files loading on R5F0 Complete
    Cortex_R5_0: GEL Output: ***OnTargetConnect() Launched***
    Cortex_R5_0: GEL Output: AM263Px Initialization Scripts Launched.
    Please Wait...
    Cortex_R5_0: GEL Output: AM263Px_Cryst_Clock_Loss_Status() Launched
    Cortex_R5_0: GEL Output: Crystal Clock present
    Cortex_R5_0: GEL Output: AM263Px_SOP_Mode() Launched
    Cortex_R5_0: GEL Output: SOP MODE = 0x00000003
    OSPI - 8S Functional boot mode
    Cortex_R5_0: GEL Output: AM263Px_Read_Device_Type() Launched
    Cortex_R5_0: GEL Output: EFuse Device Type Value = 0x000000AA
    Cortex_R5_0: GEL Output: AM263Px_dual_or_lockstep_mode() Launched
    Cortex_R5_0: GEL Output: r5fss0 = 0x00000001
    Cortex_R5_0: GEL Output: r5fss1 = 0x00000000
    R5FSS0 is in Dual core mode
    R5FSS1 is in Dual core mode
    Cortex_R5_0: GEL Output: MSS_CTRL Control Registers Unlocked
    Cortex_R5_0: GEL Output: MSS_TOP_RCM Control Registers Unlocked
    Cortex_R5_0: GEL Output: MSS_RCM Control Registers Unlocked
    Cortex_R5_0: GEL Output: MSS_IOMUX Control Registers Unlocked
    Cortex_R5_0: GEL Output: TOP_CTRL Control Registers Unlocked
    *** R5FSS0 Reset DualCore ***
    ***R5FSS1 Reset DualCore ***
    Cortex_R5_0: GEL Output: R5F ROM Eclipse
    Cortex_R5_0: GEL Output: R5FSS0_0 Released
    Cortex_R5_0: GEL Output: R5FSS0_1 Released
    Cortex_R5_0: GEL Output: R5FSS1_0 Released
    Cortex_R5_0: GEL Output: R5FSS1_1 Released
    Cortex_R5_0: GEL Output: L2 Mem Init Complete
    Cortex_R5_0: GEL Output: MailBox Mem Init Complete
    Cortex_R5_0: GEL Output: *********** R5FSS0/1 Dual Core mode Configured********
    Cortex_R5_0: GEL Output: In ROM Setting Mode
    Cortex_R5_0: GEL Output: Switch to XTAL Complete
    Cortex_R5_0: GEL Output: CORE PLL Configuration Complete
    Cortex_R5_0: GEL Output: SYS_CLK DIVBY2
    Cortex_R5_0: GEL Output: DPLL_CORE_HSDIV0_CLKOUT0 selected as CLK source for R5FSS & SYS CLKs
    CLK Programmed R5F=400MHz and SYS_CLK=200MHz
    I know the application is running because it halts at a breakpoint in EnetApp_showMenu() as seen here:
    I am running in OSPI bootmode with SBL NULL, but did not modify any Target Configuration yet:
    What should I try next?
    Tollman
  • Hi Tollman,
    Unfortunately, I'm not able to reproduce this issue. The only known issues were with the PLL gel scripts. In your case, replacing the gel file did not help.
    Can you please try the following as well:
    1. Open CSS console and check for prints when you run the application
    2. Open CCS terminal and open the correct UART COM port as well. Do you see multiple 'C' being printed in the terminal when you switch the boot mode to UART? The COM port in which these multiple 'C' prints are visible (in UART boot mode), will be the one which will show you the application prints when running the application in SBL_NULL + OSPI boot mode.
    I do not think the issue is with the networking software now as you confirmed the breakpoints being hit.
    Shaunak
  • I can see the printfs (that are not seen on in the CCS console) in my terminal connected to UART0.
    Remember that I created this thread because:
    Although I hit breakpoints Lwip2Enet_sendTxPackets(), I do not see any packets in Wireshark running on my Ethernet LAN.
    Question 1:
    Do you think that the issue with the PLL / gel script, and the Ethernet communication are related?
    Question 2a:
    How can I troubleshoot the Ethernet communication issue?
    Question 2b:
    Can you recommend a place for breakpoint, or a good Watch Expression?
    Tollman
  • Hi Tollman,
    1. The issue with the PLL clocks would lead to the board communication being unstable. The PLL clocks will configure the PHY clocks and incorrect config might lead to the Tx/Rx of packets to fail, thus leading to lwIP connection being aborted. But we need to confirm this. Since you hit the breakpoint, it does not seem to be a lwIP or the driver issue to me and maybe something related to the PHY.
    2. I am not able to reproduce the issue with the out-of-box example, but I do have some debug pointers for you that can help
    3. Before you try to establish a TCP client server connection, try to ping the microcontroller with the IP that would be shown in the prints (for example: Enet IF UP Event. Local interface IP:10.24.72.91), ping this IP and check if you get a reply.
    4. In your CCS expressions window, pause the after you get the lwIP connection abort (-13) error and type "lwip_stats". In these lwIP stats, check the "tcp", "ip", "icmp". Expand each one and check if there are drops, protocol errors, or any other unexpected statistics getting incremented.
    5. Paste this in your expressions window: (CSL_Xge_cpswRegs *) 0x52820000. These are the CPSW stats. Scroll down until you find P0_STATS and PN_STATS. Expand each one and check for packet drops or CRC errors or ALE overrun. If possible please share the screenshot so I can review it as well.
    Similarly check for the PN_STATS[0].
    6. If all the stats seem fine. Try putting a breakpoint at "EnetDma_submitTxPktQ" function. This is the last Enet driver function that handles the packet. After this, the DMA takes care of the packet transfer.
    Also can you share some details about your network setup (between TCP Client and TCP server, their IP addresses etc)
    Shaunak
  • Hi Tollman,
    I would also like to know about the changes made in the application. The out of box example works fine, configuring the microcontroller to have a static IP is also fine (assuming you followed these steps: AM263x MCU+ SDK: Ethernet LwIP TCP/IP Static IP
    I would like to know how you configured the server static IP and also your application logs.
    Shaunak
  • Hi Shaunak,
    1)
    Regarding:
    "I would also like to know about the changes made in the application... "
    The changes I made were to:
    a) Use a static IP address for the Sitara. I do not want to rely on needing a DHCP server on the LAN. However, when using the unmodified SDK examples, I use the DHCP discovery packets as a way to verify that the stack is working. I can see the packets on Wireshark.
    b) Use a static IP address for the TCP Server address. I do not want to type the address in the console each execution.
    Again, when I run this application code on my TMDSCNCD263-AM263x Sitara Control Card it works.
    2)
    Regarding:
    "Before you try to establish a TCP client server connection, try to ping the microcontroller with the IP ...".
    I will try this with my application with Static IP. The DHCP version will not have an IP address to ping.
    3)
    Thanks for the troubleshooting tips. I will try out your suggestions regarding expressions, and breakpoints.
    Hopefully, I will post the results of my testing later today.
    Tollman
  • I ran a test using an unmodified version of the SDK example:
    I let the application run for several seconds, and then halted the processor at:
    while (false == App_isNetworkUp(netif_default))
    For reference:
    Here is what the Watch Expressions looks like:
    I also pasted them in the attached file.
    lwip_stats	struct stats_	{link={xmit=0,recv=0,fw=0,drop=0,chkerr=0...},etharp={xmit=0,recv=0,fw=0,drop=0,chkerr=...,ip_frag=...	0x700B1BE8
    	link	struct stats_proto	{xmit=0,recv=0,fw=0,drop=0,chkerr=0...}	0x700B1BE8
    		xmit	unsigned short	0	0x700B1BE8
    		recv	unsigned short	0	0x700B1BEA
    		fw	unsigned short	0	0x700B1BEC
    		drop	unsigned short	0	0x700B1BEE
    		chkerr	unsigned short	0	0x700B1BF0
    		lenerr	unsigned short	0	0x700B1BF2
    		memerr	unsigned short	0	0x700B1BF4
    		rterr	unsigned short	0	0x700B1BF6
    		proterr	unsigned short	0	0x700B1BF8
    		opterr	unsigned short	0	0x700B1BFA
    		err	unsigned short	0	0x700B1BFC
    		cachehit	unsigned short	0	0x700B1BFE
    	etharp	struct stats_proto	{xmit=0,recv=0,fw=0,drop=0,chkerr=0...}	0x700B1C00
    		xmit	unsigned short	0	0x700B1C00
    		recv	unsigned short	0	0x700B1C02
    		fw	unsigned short	0	0x700B1C04
    		drop	unsigned short	0	0x700B1C06
    		chkerr	unsigned short	0	0x700B1C08
    		lenerr	unsigned short	0	0x700B1C0A
    		memerr	unsigned short	0	0x700B1C0C
    		rterr	unsigned short	0	0x700B1C0E
    		proterr	unsigned short	0	0x700B1C10
    		opterr	unsigned short	0	0x700B1C12
    		err	unsigned short	0	0x700B1C14
    		cachehit	unsigned short	0	0x700B1C16
    	ip_frag	struct stats_proto	{xmit=0,recv=0,fw=0,drop=0,chkerr=0...}	0x700B1C18
    		xmit	unsigned short	0	0x700B1C18
    		recv	unsigned short	0	0x700B1C1A
    		fw	unsigned short	0	0x700B1C1C
    		drop	unsigned short	0	0x700B1C1E
    		chkerr	unsigned short	0	0x700B1C20
    		lenerr	unsigned short	0	0x700B1C22
    		memerr	unsigned short	0	0x700B1C24
    		rterr	unsigned short	0	0x700B1C26
    		proterr	unsigned short	0	0x700B1C28
    		opterr	unsigned short	0	0x700B1C2A
    		err	unsigned short	0	0x700B1C2C
    		cachehit	unsigned short	0	0x700B1C2E
    	ip	struct stats_proto	{xmit=1,recv=0,fw=0,drop=0,chkerr=0...}	0x700B1C30
    		xmit	unsigned short	1	0x700B1C30
    		recv	unsigned short	0	0x700B1C32
    		fw	unsigned short	0	0x700B1C34
    		drop	unsigned short	0	0x700B1C36
    		chkerr	unsigned short	0	0x700B1C38
    		lenerr	unsigned short	0	0x700B1C3A
    		memerr	unsigned short	0	0x700B1C3C
    		rterr	unsigned short	0	0x700B1C3E
    		proterr	unsigned short	0	0x700B1C40
    		opterr	unsigned short	0	0x700B1C42
    		err	unsigned short	0	0x700B1C44
    		cachehit	unsigned short	0	0x700B1C46
    	icmp	struct stats_proto	{xmit=0,recv=0,fw=0,drop=0,chkerr=0...}	0x700B1C48
    		xmit	unsigned short	0	0x700B1C48
    		recv	unsigned short	0	0x700B1C4A
    		fw	unsigned short	0	0x700B1C4C
    		drop	unsigned short	0	0x700B1C4E
    		chkerr	unsigned short	0	0x700B1C50
    		lenerr	unsigned short	0	0x700B1C52
    		memerr	unsigned short	0	0x700B1C54
    		rterr	unsigned short	0	0x700B1C56
    		proterr	unsigned short	0	0x700B1C58
    		opterr	unsigned short	0	0x700B1C5A
    		err	unsigned short	0	0x700B1C5C
    		cachehit	unsigned short	0	0x700B1C5E
    	igmp	struct stats_igmp	{xmit=0,recv=0,drop=0,chkerr=0,lenerr=0...}	0x700B1C60
    		xmit	unsigned short	0	0x700B1C60
    		recv	unsigned short	0	0x700B1C62
    		drop	unsigned short	0	0x700B1C64
    		chkerr	unsigned short	0	0x700B1C66
    		lenerr	unsigned short	0	0x700B1C68
    		memerr	unsigned short	0	0x700B1C6A
    		proterr	unsigned short	0	0x700B1C6C
    		rx_v1	unsigned short	0	0x700B1C6E
    		rx_group	unsigned short	0	0x700B1C70
    		rx_general	unsigned short	0	0x700B1C72
    		rx_report	unsigned short	0	0x700B1C74
    		tx_join	unsigned short	0	0x700B1C76
    		tx_leave	unsigned short	0	0x700B1C78
    		tx_report	unsigned short	0	0x700B1C7A
    	udp	struct stats_proto	{xmit=1,recv=0,fw=0,drop=0,chkerr=0...}	0x700B1C7C
    		xmit	unsigned short	1	0x700B1C7C
    		recv	unsigned short	0	0x700B1C7E
    		fw	unsigned short	0	0x700B1C80
    		drop	unsigned short	0	0x700B1C82
    		chkerr	unsigned short	0	0x700B1C84
    		lenerr	unsigned short	0	0x700B1C86
    		memerr	unsigned short	0	0x700B1C88
    		rterr	unsigned short	0	0x700B1C8A
    		proterr	unsigned short	0	0x700B1C8C
    		opterr	unsigned short	0	0x700B1C8E
    		err	unsigned short	0	0x700B1C90
    		cachehit	unsigned short	0	0x700B1C92
    	tcp	struct stats_proto	{xmit=0,recv=0,fw=0,drop=0,chkerr=0...}	0x700B1C94
    		xmit	unsigned short	0	0x700B1C94
    		recv	unsigned short	0	0x700B1C96
    		fw	unsigned short	0	0x700B1C98
    		drop	unsigned short	0	0x700B1C9A
    		chkerr	unsigned short	0	0x700B1C9C
    		lenerr	unsigned short	0	0x700B1C9E
    		memerr	unsigned short	0	0x700B1CA0
    		rterr	unsigned short	0	0x700B1CA2
    		proterr	unsigned short	0	0x700B1CA4
    		opterr	unsigned short	0	0x700B1CA6
    		err	unsigned short	0	0x700B1CA8
    		cachehit	unsigned short	0	0x700B1CAA
    	mem	struct stats_mem	{name=0x7011D108 {77 'M'},err=0,avail=0,used=0,max=416...}	0x700B1CAC
    		name	unsigned char *	0x7011D108 "MEM	0x700B1CAC
    		err	unsigned short	0	0x700B1CB0
    		avail	unsigned short	0	0x700B1CB2
    		used	unsigned short	0	0x700B1CB4
    		max	unsigned short	416	0x700B1CB6
    		illegal	unsigned short	0	0x700B1CB8
    	memp	struct stats_mem *[22]	[0x700B35B4 {name=0x7011D014 {82 'R'},err=0,avail=3,used=0,max=0...},0x700B3654 ...,...	0x700B1CBC
    		[0]	struct stats_mem *	0x700B35B4 {name=0x7011D014 {82 'R'},err=0,avail=3,used=0,max=0...}	0x700B1CBC
    		[1]	struct stats_mem *	0x700B3654 {name=0x7011D05C {85 'U'},err=0,avail=4,used=1,max=1...}	0x700B1CC0
    		[2]	struct stats_mem *	0x700B3624 {name=0x7011D04C {84 'T'},err=0,avail=5,used=0,max=0...}	0x700B1CC4
    		[3]	struct stats_mem *	0x700B3634 {name=0x7011C55F {84 'T'},err=0,avail=8,used=0,max=0...}	0x700B1CC8
    		[4]	struct stats_mem *	0x700B3644 {name=0x7011D03C {84 'T'},err=0,avail=128,used=0,max=0...}	0x700B1CCC
    		[5]	struct stats_mem *	0x700B34F4 {name=0x7011CD2F {65 'A'},err=0,avail=5,used=0,max=0...}	0x700B1CD0
    		[6]	struct stats_mem *	0x700B35C4 {name=0x7011CCF3 {82 'R'},err=0,avail=10,used=0,max=0...}	0x700B1CD4
    		[7]	struct stats_mem *	0x700B3514 {name=0x7011CDED {70 'F'},err=0,avail=15,used=0,max=0...}	0x700B1CD8
    		[8]	struct stats_mem *	0x700B3534 {name=0x7011D07A {78 'N'},err=0,avail=128,used=0,max=0...}	0x700B1CDC
    		[9]	struct stats_mem *	0x700B3544 {name=0x7011D064 {78 'N'},err=0,avail=10,used=0,max=0...}	0x700B1CE0
    		[10]	struct stats_mem *	0x700B3604 {name=0x7011C7F3 {84 'T'},err=0,avail=128,used=0,max=0...}	0x700B1CE4
    		[11]	struct stats_mem *	0x700B3614 {name=0x7011C326 {84 'T'},err=0,avail=128,used=0,max=0...}	0x700B1CE8
    		[12]	struct stats_mem *	0x700B3504 {name=0x7011CD11 {65 'A'},err=0,avail=30,used=0,max=0...}	0x700B1CEC
    		[13]	struct stats_mem *	0x700B3524 {name=0x7011CCC8 {73 'I'},err=0,avail=8,used=0,max=0...}	0x700B1CF0
    		[14]	struct stats_mem *	0x700B35F4 {name=0x7011CAFC {83 'S'},err=0,avail=17,used=7,max=7...}	0x700B1CF4
    		[15]	struct stats_mem *	0x700B3554 {name=0x7011D0BE {78 'N'},err=0,avail=1,used=0,max=0...}	0x700B1CF8
    		[16]	struct stats_mem *	0x700B3564 {name=0x7011C914 {80 'P'},err=0,avail=128,used=0,max=0...}	0x700B1CFC
    		[17]	struct stats_mem *	0x700B3574 {name=0x7011CDB1 {80 'P'},err=0,avail=0,used=0,max=0...}	0x700B1D00
    		[18]	struct stats_mem *	0x700B3584 {name=0x7011CC70 {77 'M'},err=0,avail=100,used=0,max=0...}	0x700B1D04
    		[19]	struct stats_mem *	0x700B3594 {name=0x7011CBC8 {77 'M'},err=0,avail=48,used=0,max=1...}	0x700B1D08
    		[20]	struct stats_mem *	0x700B35A4 {name=0x7011CB20 {77 'M'},err=0,avail=4,used=0,max=0...}	0x700B1D0C
    		[21]	struct stats_mem *	0x700B35E4 {name=0x7011CFEA {83 'S'},err=0,avail=22,used=0,max=0...}	0x700B1D10
    	sys	struct stats_sys	{sem={used=0,max=1,err=0},mutex={used=1,max=1,err=0},mbox={used=1,max=1,err=0}}	0x700B1D14
    		sem	struct stats_syselem	{used=0,max=1,err=0}	0x700B1D14
    			used	unsigned short	0	0x700B1D14
    			max	unsigned short	1	0x700B1D16
    			err	unsigned short	0	0x700B1D18
    		mutex	struct stats_syselem	{used=1,max=1,err=0}	0x700B1D1A
    			used	unsigned short	1	0x700B1D1A
    			max	unsigned short	1	0x700B1D1C
    			err	unsigned short	0	0x700B1D1E
    		mbox	struct stats_syselem	{used=1,max=1,err=0}	0x700B1D20
    			used	unsigned short	1	0x700B1D20
    			max	unsigned short	1	0x700B1D22
    			err	unsigned short	0	0x700B1D24
    	mib2	struct stats_mib2	{ipinhdrerrors=0,ipinaddrerrors=0,ipinunknownprotos=0,ipindiscards=0,ipindelivers=...	0x700B1D28
    		ipinhdrerrors	unsigned int	0	0x700B1D28
    		ipinaddrerrors	unsigned int	0	0x700B1D2C
    		ipinunknownprotos	unsigned int	0	0x700B1D30
    		ipindiscards	unsigned int	0	0x700B1D34
    		ipindelivers	unsigned int	0	0x700B1D38
    		ipoutrequests	unsigned int	1	0x700B1D3C
    		ipoutdiscards	unsigned int	0	0x700B1D40
    		ipoutnoroutes	unsigned int	0	0x700B1D44
    		ipreasmoks	unsigned int	0	0x700B1D48
    		ipreasmfails	unsigned int	0	0x700B1D4C
    		ipfragoks	unsigned int	0	0x700B1D50
    		ipfragfails	unsigned int	0	0x700B1D54
    		ipfragcreates	unsigned int	0	0x700B1D58
    		ipreasmreqds	unsigned int	0	0x700B1D5C
    		ipforwdatagrams	unsigned int	0	0x700B1D60
    		ipinreceives	unsigned int	0	0x700B1D64
    		tcpactiveopens	unsigned int	0	0x700B1D68
    		tcppassiveopens	unsigned int	0	0x700B1D6C
    		tcpattemptfails	unsigned int	0	0x700B1D70
    		tcpestabresets	unsigned int	0	0x700B1D74
    		tcpoutsegs	unsigned int	0	0x700B1D78
    		tcpretranssegs	unsigned int	0	0x700B1D7C
    		tcpinsegs	unsigned int	0	0x700B1D80
    		tcpinerrs	unsigned int	0	0x700B1D84
    		tcpoutrsts	unsigned int	0	0x700B1D88
    		udpindatagrams	unsigned int	0	0x700B1D8C
    		udpnoports	unsigned int	0	0x700B1D90
    		udpinerrors	unsigned int	0	0x700B1D94
    		udpoutdatagrams	unsigned int	1	0x700B1D98
    		icmpinmsgs	unsigned int	0	0x700B1D9C
    		icmpinerrors	unsigned int	0	0x700B1DA0
    		icmpindestunreachs	unsigned int	0	0x700B1DA4
    		icmpintimeexcds	unsigned int	0	0x700B1DA8
    		icmpinparmprobs	unsigned int	0	0x700B1DAC
    		icmpinsrcquenchs	unsigned int	0	0x700B1DB0
    		icmpinredirects	unsigned int	0	0x700B1DB4
    		icmpinechos	unsigned int	0	0x700B1DB8
    		icmpinechoreps	unsigned int	0	0x700B1DBC
    		icmpintimestamps	unsigned int	0	0x700B1DC0
    		icmpintimestampreps	unsigned int	0	0x700B1DC4
    		icmpinaddrmasks	unsigned int	0	0x700B1DC8
    		icmpinaddrmaskreps	unsigned int	0	0x700B1DCC
    		icmpoutmsgs	unsigned int	0	0x700B1DD0
    		icmpouterrors	unsigned int	0	0x700B1DD4
    		icmpoutdestunreachs	unsigned int	0	0x700B1DD8
    		icmpouttimeexcds	unsigned int	0	0x700B1DDC
    		icmpoutechos	unsigned int	0	0x700B1DE0
    		icmpoutechoreps	unsigned int	0	0x700B1DE4
    (CSL_Xge_cpswRegs *) 0x52820000	struct CSL_Xge_cpswRegs *	0x52820000 {ID_VER_REG=1804603651,CONTROL_REG=278532,Resv_16=[0 '\x00',0 '\x00',...,EM_CONTROL_REG=...
    	*((CSL_Xge_cpswRegs *) 0x52820000)	struct CSL_Xge_cpswRegs	{ID_VER_REG=1804603651,CONTROL_REG=278532,Resv_16=[0 '\x00',0 '\x00',0 '\x00',0 '\x00',...,EM_CONTROL_REG=...	0x52820000
    		ID_VER_REG	unsigned int	1804603651	0x52820000
    		CONTROL_REG	unsigned int	278532	0x52820004
    		Resv_16	unsigned char[8]	[0 '\x00',0 '\x00',0 '\x00',0 '\x00',0 '\x00'...]	0x52820008
    		EM_CONTROL_REG	unsigned int	0	0x52820010
    		STAT_PORT_EN_REG	unsigned int	7	0x52820014
    		PTYPE_REG	unsigned int	2	0x52820018
    		SOFT_IDLE_REG	unsigned int	0	0x5282001C
    		THRU_RATE_REG	unsigned int	12289	0x52820020
    		GAP_THRESH_REG	unsigned int	11	0x52820024
    		TX_START_WDS_REG	unsigned int	8	0x52820028
    		EEE_PRESCALE_REG	unsigned int	0	0x5282002C
    		TX_G_OFLOW_THRESH_SET_REG	unsigned int	4294967295	0x52820030
    		TX_G_OFLOW_THRESH_CLR_REG	unsigned int	0	0x52820034
    		TX_G_BUF_THRESH_SET_L_REG	unsigned int	4294967295	0x52820038
    		TX_G_BUF_THRESH_SET_H_REG	unsigned int	4294967295	0x5282003C
    		TX_G_BUF_THRESH_CLR_L_REG	unsigned int	0	0x52820040
    		TX_G_BUF_THRESH_CLR_H_REG	unsigned int	0	0x52820044
    		Resv_80	unsigned char[8]	[0 '\x00',0 '\x00',0 '\x00',0 '\x00',0 '\x00'...]	0x52820048
    		VLAN_LTYPE_REG	unsigned int	2292744448	0x52820050
    		EST_TS_DOMAIN_REG	unsigned int	0	0x52820054
    		Resv_256	unsigned char[168]	[0 '\x00',0 '\x00',0 '\x00',0 '\x00',0 '\x00'...]	0x52820058
    		TX_PRI0_MAXLEN_REG	unsigned int	2024	0x52820100
    		TX_PRI1_MAXLEN_REG	unsigned int	2024	0x52820104
    		TX_PRI2_MAXLEN_REG	unsigned int	2024	0x52820108
    		TX_PRI3_MAXLEN_REG	unsigned int	2024	0x5282010C
    		TX_PRI4_MAXLEN_REG	unsigned int	2024	0x52820110
    		TX_PRI5_MAXLEN_REG	unsigned int	2024	0x52820114
    		TX_PRI6_MAXLEN_REG	unsigned int	2024	0x52820118
    		TX_PRI7_MAXLEN_REG	unsigned int	2024	0x5282011C
    		Resv_4100	unsigned char[3812]	[0 '\x00',0 '\x00',0 '\x00',0 '\x00',0 '\x00'...]	0x52820120
    		P0_CONTROL_REG	unsigned int	131083	0x52821004
    		P0_FLOW_ID_OFFSET_REG	unsigned int	0	0x52821008
    		Resv_4112	unsigned char[4]	[0 '\x00',0 '\x00',0 '\x00',0 '\x00']	0x5282100C
    		P0_BLK_CNT_REG	unsigned int	2	0x52821010
    		P0_PORT_VLAN_REG	unsigned int	0	0x52821014
    		P0_TX_PRI_MAP_REG	unsigned int	1985229328	0x52821018
    		P0_PRI_CTL_REG	unsigned int	0	0x5282101C
    		P0_RX_PRI_MAP_REG	unsigned int	1985229328	0x52821020
    		P0_RX_MAXLEN_REG	unsigned int	1518	0x52821024
    		P0_TX_BLKS_PRI_REG	unsigned int	19158648	0x52821028
    		Resv_4144	unsigned char[4]	[0 '\x00',0 '\x00',0 '\x00',0 '\x00']	0x5282102C
    		P0_IDLE2LPI_REG	unsigned int	0	0x52821030
    		P0_LPI2WAKE_REG	unsigned int	0	0x52821034
    		P0_EEE_STATUS_REG	unsigned int	96	0x52821038
    		Resv_4176	unsigned char[20]	[0 '\x00',0 '\x00',0 '\x00',0 '\x00',0 '\x00'...]	0x5282103C
    		P0_FIFO_STATUS_REG	unsigned int	0	0x52821050
    		Resv_4384	unsigned char[204]	[0 '\x00',0 '\x00',0 '\x00',0 '\x00',0 '\x00'...]	0x52821054
    		P0_RX_DSCP_MAP_REG	unsigned int[8]	[0,286331153,572662306,858993459,1145324612...]	0x52821120
    		P0_PRI_CIR_REG	unsigned int[8]	[0,0,0,0,0...]	0x52821140
    		P0_PRI_EIR_REG	unsigned int[8]	[0,0,0,0,0...]	0x52821160
    		P0_TX_D_THRESH_SET_L_REG	unsigned int	522133279	0x52821180
    		P0_TX_D_THRESH_SET_H_REG	unsigned int	522133279	0x52821184
    		P0_TX_D_THRESH_CLR_L_REG	unsigned int	0	0x52821188
    		P0_TX_D_THRESH_CLR_H_REG	unsigned int	0	0x5282118C
    		P0_TX_G_BUF_THRESH_SET_L_REG	unsigned int	522133279	0x52821190
    		P0_TX_G_BUF_THRESH_SET_H_REG	unsigned int	522133279	0x52821194
    		P0_TX_G_BUF_THRESH_CLR_L_REG	unsigned int	0	0x52821198
    		P0_TX_G_BUF_THRESH_CLR_H_REG	unsigned int	0	0x5282119C
    		Resv_4864	unsigned char[352]	[0 '\x00',0 '\x00',0 '\x00',0 '\x00',0 '\x00'...]	0x528211A0
    		P0_SRC_ID_A_REG	unsigned int	67305985	0x52821300
    		P0_SRC_ID_B_REG	unsigned int	134678021	0x52821304
    		Resv_4896	unsigned char[24]	[0 '\x00',0 '\x00',0 '\x00',0 '\x00',0 '\x00'...]	0x52821308
    		P0_HOST_BLKS_PRI_REG	unsigned int	0	0x52821320
    		Resv_8192	unsigned char[3292]	[0 '\x00',0 '\x00',0 '\x00',0 '\x00',0 '\x00'...]	0x52821324
    		ENETPORT	struct CSL_Xge_cpswEnetportRegs[2]	[{PN_RESERVED_REG=0,PN_CONTROL_REG=0,PN_MAX_BLKS_REG=4100,Resv_16=[0 '\x00',0 '\x00',...,PN_BLK_CNT_REG=...,...	0x52822000
    		Resv_73728	unsigned char[57344]	[0 '\x00',0 '\x00',0 '\x00',0 '\x00',0 '\x00'...]	0x52824000
    		CPSW_NU_EST	struct CSL_Xge_cpswRegs_CPSW_NU_EST[2]	[{FETCH_LOC=[0,0,0,0,0...]},{FETCH_LOC=[0,0,0,0,0...]}]	0x52832000
    		Resv_106496	unsigned char[31744]	[0 '\x00',0 '\x00',0 '\x00',0 '\x00',0 '\x00'...]	0x52832400
    		P0_STATS	struct CSL_Xge_cpswP0StatsRegs	{RXGOODFRAMES=1,RXBROADCASTFRAMES=1,RXMULTICASTFRAMES=0,Resv_16=[0 '\x00',0 '\x00',...,RXCRCERRORS=...	0x5283A000
    			RXGOODFRAMES	unsigned int	1	0x5283A000
    			RXBROADCASTFRAMES	unsigned int	1	0x5283A004
    			RXMULTICASTFRAMES	unsigned int	0	0x5283A008
    			Resv_16	unsigned char[4]	[0 '\x00',0 '\x00',0 '\x00',0 '\x00']	0x5283A00C
    			RXCRCERRORS	unsigned int	0	0x5283A010
    			Resv_24	unsigned char[4]	[0 '\x00',0 '\x00',0 '\x00',0 '\x00']	0x5283A014
    			RXOVERSIZEDFRAMES	unsigned int	0	0x5283A018
    			Resv_32	unsigned char[4]	[0 '\x00',0 '\x00',0 '\x00',0 '\x00']	0x5283A01C
    			RXUNDERSIZEDFRAMES	unsigned int	0	0x5283A020
    			Resv_40	unsigned char[4]	[0 '\x00',0 '\x00',0 '\x00',0 '\x00']	0x5283A024
    			ALE_DROP	unsigned int	0	0x5283A028
    			ALE_OVERRUN_DROP	unsigned int	0	0x5283A02C
    			RXOCTETS	unsigned int	354	0x5283A030
    			TXGOODFRAMES	unsigned int	0	0x5283A034
    			TXBROADCASTFRAMES	unsigned int	0	0x5283A038
    			TXMULTICASTFRAMES	unsigned int	0	0x5283A03C
    			Resv_76	unsigned char[12]	[0 '\x00',0 '\x00',0 '\x00',0 '\x00',0 '\x00'...]	0x5283A040
    			TX_SOF_OVERRUN	unsigned int	0	0x5283A04C
    			TX_MOF_OVERRUN	unsigned int	0	0x5283A050
    			Resv_100	unsigned char[16]	[0 '\x00',0 '\x00',0 '\x00',0 '\x00',0 '\x00'...]	0x5283A054
    			TXOCTETS	unsigned int	0	0x5283A064
    			OCTETFRAMES64	unsigned int	0	0x5283A068
    			OCTETFRAMES65T127	unsigned int	0	0x5283A06C
    			OCTETFRAMES128T255	unsigned int	0	0x5283A070
    			OCTETFRAMES256T511	unsigned int	1	0x5283A074
    			OCTETFRAMES512T1023	unsigned int	0	0x5283A078
    			OCTETFRAMES1024TUP	unsigned int	0	0x5283A07C
    			NETOCTETS	unsigned int	354	0x5283A080
    			RX_BOTTOM_OF_FIFO_DROP	unsigned int	0	0x5283A084
    			PORTMASK_DROP	unsigned int	0	0x5283A088
    			RX_TOP_OF_FIFO_DROP	unsigned int	0	0x5283A08C
    			ALE_RATE_LIMIT_DROP	unsigned int	0	0x5283A090
    			ALE_VID_INGRESS_DROP	unsigned int	0	0x5283A094
    			ALE_DA_EQ_SA_DROP	unsigned int	0	0x5283A098
    			ALE_BLOCK_DROP	unsigned int	0	0x5283A09C
    			ALE_SECURE_DROP	unsigned int	0	0x5283A0A0
    			ALE_AUTH_DROP	unsigned int	0	0x5283A0A4
    			ALE_UNKN_UNI	unsigned int	0	0x5283A0A8
    			ALE_UNKN_UNI_BCNT	unsigned int	0	0x5283A0AC
    			ALE_UNKN_MLT	unsigned int	0	0x5283A0B0
    			ALE_UNKN_MLT_BCNT	unsigned int	0	0x5283A0B4
    			ALE_UNKN_BRD	unsigned int	0	0x5283A0B8
    			ALE_UNKN_BRD_BCNT	unsigned int	0	0x5283A0BC
    			ALE_POL_MATCH	unsigned int	0	0x5283A0C0
    			ALE_POL_MATCH_RED	unsigned int	0	0x5283A0C4
    			ALE_POL_MATCH_YELLOW	unsigned int	0	0x5283A0C8
    			ALE_MULT_SA_DROP	unsigned int	0	0x5283A0CC
    			ALE_DUAL_VLAN_DROP	unsigned int	0	0x5283A0D0
    			ALE_LEN_ERROR_DROP	unsigned int	0	0x5283A0D4
    			ALE_IP_NEXT_HDR_DROP	unsigned int	0	0x5283A0D8
    			ALE_IPV4_FRAG_DROP	unsigned int	0	0x5283A0DC
    			Resv_376	unsigned char[156]	[0 '\x00',0 '\x00',0 '\x00',0 '\x00',0 '\x00'...]	0x5283A0E0
    			TX_MEMORY_PROTECT_ERROR	unsigned int	0	0x5283A17C
    			ENET_PN_TX_PRI_REG	unsigned int[8]	[0,0,0,0,0...]	0x5283A180
    				[0]	unsigned int	0	0x5283A180
    				[1]	unsigned int	0	0x5283A184
    				[2]	unsigned int	0	0x5283A188
    				[3]	unsigned int	0	0x5283A18C
    				[4]	unsigned int	0	0x5283A190
    				[5]	unsigned int	0	0x5283A194
    				[6]	unsigned int	0	0x5283A198
    				[7]	unsigned int	0	0x5283A19C
    			ENET_PN_TX_PRI_BCNT_REG	unsigned int[8]	[0,0,0,0,0...]	0x5283A1A0
    				[0]	unsigned int	0	0x5283A1A0
    				[1]	unsigned int	0	0x5283A1A4
    				[2]	unsigned int	0	0x5283A1A8
    				[3]	unsigned int	0	0x5283A1AC
    				[4]	unsigned int	0	0x5283A1B0
    				[5]	unsigned int	0	0x5283A1B4
    				[6]	unsigned int	0	0x5283A1B8
    				[7]	unsigned int	0	0x5283A1BC
    			ENET_PN_TX_PRI_DROP_REG	unsigned int[8]	[0,0,0,0,0...]	0x5283A1C0
    				[0]	unsigned int	0	0x5283A1C0
    				[1]	unsigned int	0	0x5283A1C4
    				[2]	unsigned int	0	0x5283A1C8
    				[3]	unsigned int	0	0x5283A1CC
    				[4]	unsigned int	0	0x5283A1D0
    				[5]	unsigned int	0	0x5283A1D4
    				[6]	unsigned int	0	0x5283A1D8
    				[7]	unsigned int	0	0x5283A1DC
    			ENET_PN_TX_PRI_DROP_BCNT_REG	unsigned int[8]	[0,0,0,0,0...]	0x5283A1E0
    				[0]	unsigned int	0	0x5283A1E0
    				[1]	unsigned int	0	0x5283A1E4
    				[2]	unsigned int	0	0x5283A1E8
    				[3]	unsigned int	0	0x5283A1EC
    				[4]	unsigned int	0	0x5283A1F0
    				[5]	unsigned int	0	0x5283A1F4
    				[6]	unsigned int	0	0x5283A1F8
    				[7]	unsigned int	0	0x5283A1FC
    		PN_STATS	struct CSL_Xge_cpswPnStatsRegs[2]	[{RXGOODFRAMES=0,RXBROADCASTFRAMES=0,RXMULTICASTFRAMES=0,RXPAUSEFRAMES=0,RXCRCERRORS=...,...	0x5283A200
    			[0]	struct CSL_Xge_cpswPnStatsRegs	{RXGOODFRAMES=0,RXBROADCASTFRAMES=0,RXMULTICASTFRAMES=0,RXPAUSEFRAMES=0,RXCRCERRORS=...	0x5283A200
    				RXGOODFRAMES	unsigned int	0	0x5283A200
    				RXBROADCASTFRAMES	unsigned int	0	0x5283A204
    				RXMULTICASTFRAMES	unsigned int	0	0x5283A208
    				RXPAUSEFRAMES	unsigned int	0	0x5283A20C
    				RXCRCERRORS	unsigned int	0	0x5283A210
    				RXALIGNCODEERRORS	unsigned int	0	0x5283A214
    				RXOVERSIZEDFRAMES	unsigned int	0	0x5283A218
    				RXJABBERFRAMES	unsigned int	0	0x5283A21C
    				RXUNDERSIZEDFRAMES	unsigned int	0	0x5283A220
    				RXFRAGMENTS	unsigned int	0	0x5283A224
    				ALE_DROP	unsigned int	0	0x5283A228
    				ALE_OVERRUN_DROP	unsigned int	0	0x5283A22C
    				RXOCTETS	unsigned int	0	0x5283A230
    				TXGOODFRAMES	unsigned int	0	0x5283A234
    				TXBROADCASTFRAMES	unsigned int	0	0x5283A238
    				TXMULTICASTFRAMES	unsigned int	0	0x5283A23C
    				TXPAUSEFRAMES	unsigned int	0	0x5283A240
    				TXDEFERREDFRAMES	unsigned int	0	0x5283A244
    				TXCOLLISIONFRAMES	unsigned int	0	0x5283A248
    				TXSINGLECOLLFRAMES	unsigned int	0	0x5283A24C
    				TXMULTCOLLFRAMES	unsigned int	0	0x5283A250
    				TXEXCESSIVECOLLISIONS	unsigned int	0	0x5283A254
    				TXLATECOLLISIONS	unsigned int	0	0x5283A258
    				RXIPGERROR	unsigned int	0	0x5283A25C
    				TXCARRIERSENSEERRORS	unsigned int	0	0x5283A260
    				TXOCTETS	unsigned int	0	0x5283A264
    				OCTETFRAMES64	unsigned int	0	0x5283A268
    				OCTETFRAMES65T127	unsigned int	0	0x5283A26C
    				OCTETFRAMES128T255	unsigned int	0	0x5283A270
    				OCTETFRAMES256T511	unsigned int	0	0x5283A274
    				OCTETFRAMES512T1023	unsigned int	0	0x5283A278
    				OCTETFRAMES1024TUP	unsigned int	0	0x5283A27C
    				NETOCTETS	unsigned int	0	0x5283A280
    				RX_BOTTOM_OF_FIFO_DROP	unsigned int	0	0x5283A284
    				PORTMASK_DROP	unsigned int	0	0x5283A288
    				RX_TOP_OF_FIFO_DROP	unsigned int	0	0x5283A28C
    				ALE_RATE_LIMIT_DROP	unsigned int	0	0x5283A290
    				ALE_VID_INGRESS_DROP	unsigned int	0	0x5283A294
    				ALE_DA_EQ_SA_DROP	unsigned int	0	0x5283A298
    				ALE_BLOCK_DROP	unsigned int	0	0x5283A29C
    				ALE_SECURE_DROP	unsigned int	0	0x5283A2A0
    				ALE_AUTH_DROP	unsigned int	0	0x5283A2A4
    				ALE_UNKN_UNI	unsigned int	0	0x5283A2A8
    				ALE_UNKN_UNI_BCNT	unsigned int	0	0x5283A2AC
    				ALE_UNKN_MLT	unsigned int	0	0x5283A2B0
    				ALE_UNKN_MLT_BCNT	unsigned int	0	0x5283A2B4
    				ALE_UNKN_BRD	unsigned int	0	0x5283A2B8
    				ALE_UNKN_BRD_BCNT	unsigned int	0	0x5283A2BC
    				ALE_POL_MATCH	unsigned int	0	0x5283A2C0
    				ALE_POL_MATCH_RED	unsigned int	0	0x5283A2C4
    				ALE_POL_MATCH_YELLOW	unsigned int	0	0x5283A2C8
    				ALE_MULT_SA_DROP	unsigned int	0	0x5283A2CC
    				ALE_DUAL_VLAN_DROP	unsigned int	0	0x5283A2D0
    				ALE_LEN_ERROR_DROP	unsigned int	0	0x5283A2D4
    				ALE_IP_NEXT_HDR_DROP	unsigned int	0	0x5283A2D8
    				ALE_IPV4_FRAG_DROP	unsigned int	0	0x5283A2DC
    				Resv_320	unsigned char[96]	[0 '\x00',0 '\x00',0 '\x00',0 '\x00',0 '\x00'...]	0x5283A2E0
    				IET_RX_ASSEMBLY_ERROR	unsigned int	0	0x5283A340
    				IET_RX_ASSEMBLY_OK	unsigned int	0	0x5283A344
    				IET_RX_SMD_ERROR	unsigned int	0	0x5283A348
    				IET_RX_FRAG	unsigned int	0	0x5283A34C
    				IET_TX_HOLD	unsigned int	0	0x5283A350
    				IET_TX_FRAG	unsigned int	0	0x5283A354
    				Resv_380	unsigned char[36]	[0 '\x00',0 '\x00',0 '\x00',0 '\x00',0 '\x00'...]	0x5283A358
    				TX_MEMORY_PROTECT_ERROR	unsigned int	0	0x5283A37C
    				ENET_PN_TX_PRI_REG	unsigned int[8]	[0,0,0,0,0...]	0x5283A380
    				ENET_PN_TX_PRI_BCNT_REG	unsigned int[8]	[0,0,0,0,0...]	0x5283A3A0
    				ENET_PN_TX_PRI_DROP_REG	unsigned int[8]	[0,0,0,0,0...]	0x5283A3C0
    				ENET_PN_TX_PRI_DROP_BCNT_REG	unsigned int[8]	[0,0,0,0,0...]	0x5283A3E0
    			[1]	struct CSL_Xge_cpswPnStatsRegs	{RXGOODFRAMES=0,RXBROADCASTFRAMES=0,RXMULTICASTFRAMES=0,RXPAUSEFRAMES=0,RXCRCERRORS=...	0x5283A400
    				RXGOODFRAMES	unsigned int	0	0x5283A400
    				RXBROADCASTFRAMES	unsigned int	0	0x5283A404
    				RXMULTICASTFRAMES	unsigned int	0	0x5283A408
    				RXPAUSEFRAMES	unsigned int	0	0x5283A40C
    				RXCRCERRORS	unsigned int	0	0x5283A410
    				RXALIGNCODEERRORS	unsigned int	0	0x5283A414
    				RXOVERSIZEDFRAMES	unsigned int	0	0x5283A418
    				RXJABBERFRAMES	unsigned int	0	0x5283A41C
    				RXUNDERSIZEDFRAMES	unsigned int	0	0x5283A420
    				RXFRAGMENTS	unsigned int	0	0x5283A424
    				ALE_DROP	unsigned int	0	0x5283A428
    				ALE_OVERRUN_DROP	unsigned int	0	0x5283A42C
    				RXOCTETS	unsigned int	0	0x5283A430
    				TXGOODFRAMES	unsigned int	1	0x5283A434
    				TXBROADCASTFRAMES	unsigned int	1	0x5283A438
    				TXMULTICASTFRAMES	unsigned int	0	0x5283A43C
    				TXPAUSEFRAMES	unsigned int	0	0x5283A440
    				TXDEFERREDFRAMES	unsigned int	0	0x5283A444
    				TXCOLLISIONFRAMES	unsigned int	0	0x5283A448
    				TXSINGLECOLLFRAMES	unsigned int	0	0x5283A44C
    				TXMULTCOLLFRAMES	unsigned int	0	0x5283A450
    				TXEXCESSIVECOLLISIONS	unsigned int	0	0x5283A454
    				TXLATECOLLISIONS	unsigned int	0	0x5283A458
    				RXIPGERROR	unsigned int	0	0x5283A45C
    				TXCARRIERSENSEERRORS	unsigned int	0	0x5283A460
    				TXOCTETS	unsigned int	354	0x5283A464
    				OCTETFRAMES64	unsigned int	0	0x5283A468
    				OCTETFRAMES65T127	unsigned int	0	0x5283A46C
    				OCTETFRAMES128T255	unsigned int	0	0x5283A470
    				OCTETFRAMES256T511	unsigned int	1	0x5283A474
    				OCTETFRAMES512T1023	unsigned int	0	0x5283A478
    				OCTETFRAMES1024TUP	unsigned int	0	0x5283A47C
    				NETOCTETS	unsigned int	354	0x5283A480
    				RX_BOTTOM_OF_FIFO_DROP	unsigned int	0	0x5283A484
    				PORTMASK_DROP	unsigned int	0	0x5283A488
    				RX_TOP_OF_FIFO_DROP	unsigned int	0	0x5283A48C
    				ALE_RATE_LIMIT_DROP	unsigned int	0	0x5283A490
    				ALE_VID_INGRESS_DROP	unsigned int	0	0x5283A494
    				ALE_DA_EQ_SA_DROP	unsigned int	0	0x5283A498
    				ALE_BLOCK_DROP	unsigned int	0	0x5283A49C
    				ALE_SECURE_DROP	unsigned int	0	0x5283A4A0
    				ALE_AUTH_DROP	unsigned int	0	0x5283A4A4
    				ALE_UNKN_UNI	unsigned int	0	0x5283A4A8
    				ALE_UNKN_UNI_BCNT	unsigned int	0	0x5283A4AC
    				ALE_UNKN_MLT	unsigned int	0	0x5283A4B0
    				ALE_UNKN_MLT_BCNT	unsigned int	0	0x5283A4B4
    				ALE_UNKN_BRD	unsigned int	0	0x5283A4B8
    				ALE_UNKN_BRD_BCNT	unsigned int	0	0x5283A4BC
    				ALE_POL_MATCH	unsigned int	0	0x5283A4C0
    				ALE_POL_MATCH_RED	unsigned int	0	0x5283A4C4
    				ALE_POL_MATCH_YELLOW	unsigned int	0	0x5283A4C8
    				ALE_MULT_SA_DROP	unsigned int	0	0x5283A4CC
    				ALE_DUAL_VLAN_DROP	unsigned int	0	0x5283A4D0
    				ALE_LEN_ERROR_DROP	unsigned int	0	0x5283A4D4
    				ALE_IP_NEXT_HDR_DROP	unsigned int	0	0x5283A4D8
    				ALE_IPV4_FRAG_DROP	unsigned int	0	0x5283A4DC
    				Resv_320	unsigned char[96]	[0 '\x00',0 '\x00',0 '\x00',0 '\x00',0 '\x00'...]	0x5283A4E0
    				IET_RX_ASSEMBLY_ERROR	unsigned int	0	0x5283A540
    				IET_RX_ASSEMBLY_OK	unsigned int	0	0x5283A544
    				IET_RX_SMD_ERROR	unsigned int	0	0x5283A548
    				IET_RX_FRAG	unsigned int	0	0x5283A54C
    				IET_TX_HOLD	unsigned int	0	0x5283A550
    				IET_TX_FRAG	unsigned int	0	0x5283A554
    				Resv_380	unsigned char[36]	[0 '\x00',0 '\x00',0 '\x00',0 '\x00',0 '\x00'...]	0x5283A558
    				TX_MEMORY_PROTECT_ERROR	unsigned int	0	0x5283A57C
    				ENET_PN_TX_PRI_REG	unsigned int[8]	[1,0,0,0,0...]	0x5283A580
    				ENET_PN_TX_PRI_BCNT_REG	unsigned int[8]	[354,0,0,0,0...]	0x5283A5A0
    				ENET_PN_TX_PRI_DROP_REG	unsigned int[8]	[0,0,0,0,0...]	0x5283A5C0
    				ENET_PN_TX_PRI_DROP_BCNT_REG	unsigned int[8]	[0,0,0,0,0...]	0x5283A5E0
    Observation:
    (lwip_stats.ip.xmit) == 5, but (lwip_stats.link.xmit == 0)
    Note: I saw no packets on Wireshark.
    Please review.
    Tollman
  • Hi Tollman,
    Apologies for a delayed response, I was Out of office due to health issues.
    1. Based on the stats above, I see some IP packets were sent from lwIP to the ethernet driver (5 packets)
    2. I have replicated the same use case and tested and it worked. I set the AM263Px to "192.168.1.2" and hardcoded my server to "192.168.1.4" and used the command "ncat -e /bin/cat -kv -l 8888" on my linux PC to test. I am attaching my binary and logs. Can you please test with my .out binary file and confirm the same results.
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/908/enet_5F00_cpsw_5F00_tcpclient.release.out
    Note: The only changes I made were hardcoding the Static IP for client and server
    3. Can you please share the revision number of your AM263Px device? There should be a label mentioning "PROCxxxExx..."
    With the correct changes and network setup, I was able to run the same without any issues. And seeing that everything works fine on AM263x, i'm unsure on what the issue might be.
    Shaunak
  • Hi Shaunak,
    Regarding:
    "1. Based on the stats above, I see some IP packets were sent from lwIP to the ethernet driver (5 packets)"
    Does this mean that lwip_stats.link.xmit can be zero when packets are transmitted to the PHY? If so, what does this statistic mean?
    Regarding:
    "2. I have replicated the same use case and tested and it worked. I set the AM263Px to "192.168.1.2" and hardcoded my server to "192.168.1.4" and used the command "ncat -e /bin/cat -kv -l 8888" on my linux PC to test. I am attaching my binary and logs. Can you please test with my .out binary file and confirm the same results."
    Please provide a procedure for using this file. I tried copying it to my project, and then running in debug mode, but it gets overwritten. Also, it does not seem to be a valid file type for to Uniflash.
    Regarding:
    "3. Can you please share the revision number of your AM263Px device? There should be a label mentioning "PROCxxxExx...""
    The PCB says PCB#: PROC159E2
    Tollman
  • Hi Tollman,
    I tested with the AM263Px device, flashed SBL null, put the device in OSPI boot mode and then using CCS connected to the R5F core and loaded the given binary.
    I have attached the zip file so you can test in your desired wayenet_cpsw_tcpclient.zip
    Shaunak
  • Hi Shaunak,
    1)
    I executed the code you provided. I ran this on a second TMDSCNCD263P-AM263Px Sitara Control Card to check if I was unlucky with the first PCBA. Unfortunately, I still do not see Ethernet transmissions.
    Here is the printf output:
    INFO: Bootloader_socLoadHsmRtFw:82: Device Type : HSFS  <CR><LF>
    <CR><LF>
     INFO: Bootloader_socLoadHsmRtFw:84: HSMRT Size in Bytes : 23875 <CR><LF>
    INFO: Bootloader_socLoadHsmRtFw:97: hsm runtime firmware load complete ... <CR><LF>
    Starting NULL Bootloader ... <CR><LF>
    INFO: Bootloader_runCpu:155: CPU r5f1-1 is initialized to 400000000 Hz !!!<CR><LF>
    INFO: Bootloader_runCpu:155: CPU r5f1-0 is initialized to 400000000 Hz !!!<CR><LF>
    INFO: Bootloader_runCpu:155: CPU r5f0-1 is initialized to 400000000 Hz !!!<CR><LF>
    [BOOTLOADER_PROFILE] Boot Media       : undefined <CR><LF>
    [BOOTLOADER PROFILE] System_init                      :         70us <CR><LF>
    [BOOTLOADER PROFILE] Drivers_open                     :         40us <CR><LF>
    [BOOTLOADER PROFILE] LoadHsmRtFw                      :      31944us <CR><LF>
    [BOOTLOADER_PROFILE] SBL Total Time Taken             :      56144us <CR><LF>
    <CR><LF>
    NULL Bootloader Execution Complete... <CR><LF>
    INFO: Bootloader_loadSelfCpu:207: CPU r5f0-0 is initialized to 400000000 Hz !!!<CR><LF>
    INFO: Bootloader_runSelfCpu:217: All done, reseting self ...<CR><LF>
    <LF>
      CPSW LWIP TCP CLIENT    <CR><LF>
    Link Status Changed. PHY: 0x0, state: up<CR><LF>
    EnetPhy_bindDriver:1828 <CR><LF>
    Starting lwIP, local interface IP is dhcp-enabled<CR><LF>
    [LWIPIF_LWIP] NETIF INIT SUCCESS<CR><LF>
    Host MAC address-0 : 70:ff:76:1f:60:9b<CR>
    <CR><LF>
    Enet IF UP Event. Local interface IP:0.0.0.0<CR><LF>
    [LWIPIF_LWIP] Enet has been started successfully<CR><LF>
    Enet IF UP Event. Local interface IP:192.168.1.2<CR><LF>
    Waiting for network UP ...<CR><LF>
    Cpsw_handleLinkUp:1629 <CR><LF>
    MAC Port 2: link up<CR><LF>
    Network Link UP Event<CR><LF>
    Network is UP ...<CR><LF>
     TCP Client Menu: <CR><LF>
     IP eneterd is: 192.168.1.3 <CR><LF>
    <<<< ITERATION 1 >>>><CR><LF>
     Connecting to: 192.168.1.3:8888 <CR><LF>
    1. 49s : CPU load = 0.94 %<CR><LF>
    2. 50s : CPU load = 1.07 %<CR><LF>
    3. 51s : CPU load = 1.08 %<CR><LF>
    4. 52s : CPU load = 1.08 %<CR><LF>
    Connection with the server isn't established<CR><LF>
    <<<< ITERATION 2 >>>><CR><LF>
    1. 53s : CPU load = 1.10 %<CR><LF>
    2. 54s : CPU load = 1.08 %<CR><LF>
    3. 55s : CPU load = 1.10 %<CR><LF>
    4. 56s : CPU load = 1.08 %<CR><LF>
    2)
    As a sanity check, I again connected TMDSCNCD263-AM263x Sitara Control Card (not AM263Px) to the same TMDSHSECDOCK-180, and Ethernet connection immediately after the AM263Px version failed.
    Upon executing:
    enet_cpsw_tcpclient_am263x-cc_r5fss0-0_freertos_ti-arm-clang
    … on that same setup, I see the DHCP Discovery packets from the AM263x on Wireshark.
    3a)
    Have you compared the LWIP stats, and CPSW stats I provided to ones generated with your successful tests?
    3b) [repeat]
    Regarding:
    4a)
    Are there any test points I can probe to verify the transmissions are making it to and from the PHY?
    4b)
    Are there other signals worth probing?
    Tollman
  • Hi Tollman,
    Thanks for your response so far. I would like to understand this in more depth. I'm not able to reproduce so debugging it this way is a bit difficult for me. Meanwhile,
    1. Can you please share your Binary (.out file) with me so I can test the same on my AM263Px.
    2. I checked the lwip_stats of my working application, the link stats are not incremented.
    I don't see the call "LINK_STATS_INC(link.xmit);" being hit in the execution.
    In ideal working case, you should see lwip_stats.tcp.xmit and lwip_stats.tcp.recv incrementing. And the CPSW host port and mac port-1 stats Rx and Tx without drops..
    3. The previously shared stats were sent when the application was still stuck in waiting for network up while loop. Those stats did not help much. Can you please share the stats when the network is up, mac ports are link up and after you get the ABORT from lwIP.
    4. Did ping (ICMP) work?
    5. Can you once try running: https://software-dl.ti.com/mcu-plus-sdk/esd/AM263PX/latest/exports/docs/api_guide_am263px/EXAMPLES_ENET_LAYER2_CPSW.html (the same way, SBL NULL + OSPI boot mode)
    and verify if you see the packets on wireshark. My suspicion is not on the driver or the application code now. If this example fails to run, let's schedule a debug call on Monday and deep dive further in the debug/working session
    Shaunak
  • Regarding:
    Since my application original had the Abort Error, I haven’t been using it. I’ve been either testing with unmodified SDK examples, or code that you sent. I am attaching is the build output of the ‘static IP application’  that you provided. I only modified the host address.
    enet_cpsw_tcpclient_am263px-cc_r5fss0-0_p05-20240503a.zip
    2.
    Makes sense. Closed
    3.
    Regarding:
    "The previously shared stats were sent when the application was still stuck in waiting for network up while loop. Those stats did not help much. Can you please share the stats when the network is up, mac ports are link up and after you get the ABORT from lwIP."
    I retested with your ‘static IP application’ by putting a breakpoint at
    DebugP_log("Connection with the server isn't established\r\n");
    I think the stats suggest that the software ‘thinks’ that Ethernet is working.
    I did two test runs, one with the Host PC connected and running Wireshark, and one test run with host PC disconnected. Only Ethernet switch connected.
    A txt file with the watch expressions from both runs is attached.
    Run 1: Host PC connected and running wireshark
    lwip_stats	struct stats_	{link={xmit=0,recv=0,fw=0,drop=0,chkerr=0...},etharp={xmit=21,recv=0,fw=0,drop=0,chkerr=...,ip_frag=...	0x700B18C8
    	link	struct stats_proto	{xmit=0,recv=0,fw=0,drop=0,chkerr=0...}	0x700B18C8
    		xmit	unsigned short	0	0x700B18C8
    		recv	unsigned short	0	0x700B18CA
    		fw	unsigned short	0	0x700B18CC
    		drop	unsigned short	0	0x700B18CE
    		chkerr	unsigned short	0	0x700B18D0
    		lenerr	unsigned short	0	0x700B18D2
    		memerr	unsigned short	0	0x700B18D4
    		rterr	unsigned short	0	0x700B18D6
    		proterr	unsigned short	0	0x700B18D8
    		opterr	unsigned short	0	0x700B18DA
    		err	unsigned short	0	0x700B18DC
    		cachehit	unsigned short	0	0x700B18DE
    	etharp	struct stats_proto	{xmit=21,recv=0,fw=0,drop=0,chkerr=0...}	0x700B18E0
    		xmit	unsigned short	21	0x700B18E0
    		recv	unsigned short	0	0x700B18E2
    		fw	unsigned short	0	0x700B18E4
    		drop	unsigned short	0	0x700B18E6
    		chkerr	unsigned short	0	0x700B18E8
    		lenerr	unsigned short	0	0x700B18EA
    		memerr	unsigned short	0	0x700B18EC
    		rterr	unsigned short	0	0x700B18EE
    		proterr	unsigned short	0	0x700B18F0
    		opterr	unsigned short	0	0x700B18F2
    		err	unsigned short	0	0x700B18F4
    		cachehit	unsigned short	0	0x700B18F6
    	ip_frag	struct stats_proto	{xmit=0,recv=0,fw=0,drop=0,chkerr=0...}	0x700B18F8
    		xmit	unsigned short	0	0x700B18F8
    		recv	unsigned short	0	0x700B18FA
    		fw	unsigned short	0	0x700B18FC
    		drop	unsigned short	0	0x700B18FE
    		chkerr	unsigned short	0	0x700B1900
    		lenerr	unsigned short	0	0x700B1902
    		memerr	unsigned short	0	0x700B1904
    		rterr	unsigned short	0	0x700B1906
    		proterr	unsigned short	0	0x700B1908
    		opterr	unsigned short	0	0x700B190A
    		err	unsigned short	0	0x700B190C
    		cachehit	unsigned short	0	0x700B190E
    	ip	struct stats_proto	{xmit=5,recv=0,fw=0,drop=0,chkerr=0...}	0x700B1910
    		xmit	unsigned short	5	0x700B1910
    		recv	unsigned short	0	0x700B1912
    		fw	unsigned short	0	0x700B1914
    		drop	unsigned short	0	0x700B1916
    		chkerr	unsigned short	0	0x700B1918
    		lenerr	unsigned short	0	0x700B191A
    		memerr	unsigned short	0	0x700B191C
    		rterr	unsigned short	0	0x700B191E
    		proterr	unsigned short	0	0x700B1920
    		opterr	unsigned short	0	0x700B1922
    		err	unsigned short	0	0x700B1924
    		cachehit	unsigned short	0	0x700B1926
    	icmp	struct stats_proto	{xmit=0,recv=0,fw=0,drop=0,chkerr=0...}	0x700B1928
    		xmit	unsigned short	0	0x700B1928
    		recv	unsigned short	0	0x700B192A
    		fw	unsigned short	0	0x700B192C
    		drop	unsigned short	0	0x700B192E
    		chkerr	unsigned short	0	0x700B1930
    		lenerr	unsigned short	0	0x700B1932
    		memerr	unsigned short	0	0x700B1934
    		rterr	unsigned short	0	0x700B1936
    		proterr	unsigned short	0	0x700B1938
    		opterr	unsigned short	0	0x700B193A
    		err	unsigned short	0	0x700B193C
    		cachehit	unsigned short	0	0x700B193E
    	igmp	struct stats_igmp	{xmit=0,recv=0,drop=0,chkerr=0,lenerr=0...}	0x700B1940
    		xmit	unsigned short	0	0x700B1940
    		recv	unsigned short	0	0x700B1942
    		drop	unsigned short	0	0x700B1944
    		chkerr	unsigned short	0	0x700B1946
    		lenerr	unsigned short	0	0x700B1948
    		memerr	unsigned short	0	0x700B194A
    		proterr	unsigned short	0	0x700B194C
    		rx_v1	unsigned short	0	0x700B194E
    		rx_group	unsigned short	0	0x700B1950
    		rx_general	unsigned short	0	0x700B1952
    		rx_report	unsigned short	0	0x700B1954
    		tx_join	unsigned short	0	0x700B1956
    		tx_leave	unsigned short	0	0x700B1958
    		tx_report	unsigned short	0	0x700B195A
    	udp	struct stats_proto	{xmit=0,recv=0,fw=0,drop=0,chkerr=0...}	0x700B195C
    		xmit	unsigned short	0	0x700B195C
    		recv	unsigned short	0	0x700B195E
    		fw	unsigned short	0	0x700B1960
    		drop	unsigned short	0	0x700B1962
    		chkerr	unsigned short	0	0x700B1964
    		lenerr	unsigned short	0	0x700B1966
    		memerr	unsigned short	0	0x700B1968
    		rterr	unsigned short	0	0x700B196A
    		proterr	unsigned short	0	0x700B196C
    		opterr	unsigned short	0	0x700B196E
    		err	unsigned short	0	0x700B1970
    		cachehit	unsigned short	0	0x700B1972
    	tcp	struct stats_proto	{xmit=5,recv=0,fw=0,drop=0,chkerr=0...}	0x700B1974
    		xmit	unsigned short	5	0x700B1974
    		recv	unsigned short	0	0x700B1976
    		fw	unsigned short	0	0x700B1978
    		drop	unsigned short	0	0x700B197A
    		chkerr	unsigned short	0	0x700B197C
    		lenerr	unsigned short	0	0x700B197E
    		memerr	unsigned short	0	0x700B1980
    		rterr	unsigned short	0	0x700B1982
    		proterr	unsigned short	0	0x700B1984
    		opterr	unsigned short	0	0x700B1986
    		err	unsigned short	0	0x700B1988
    		cachehit	unsigned short	0	0x700B198A
    	mem	struct stats_mem	{name=0x7011A42C {77 'M'},err=0,avail=0,used=128,max=224...}	0x700B198C
    		name	unsigned char *	0x7011A42C "MEM	0x700B198C
    		err	unsigned short	0	0x700B1990
    		avail	unsigned short	0	0x700B1992
    		used	unsigned short	128	0x700B1994
    		max	unsigned short	224	0x700B1996
    		illegal	unsigned short	0	0x700B1998
    	memp	struct stats_mem *[22]	[0x700B33E4 {name=0x7011A328 {82 'R'},err=0,avail=3,used=0,max=0...},0x700B3484 ...,...	0x700B199C
    		[0]	struct stats_mem *	0x700B33E4 {name=0x7011A328 {82 'R'},err=0,avail=3,used=0,max=0...}	0x700B199C
    		[1]	struct stats_mem *	0x700B3484 {name=0x7011A370 {85 'U'},err=0,avail=4,used=0,max=0...}	0x700B19A0
    		[2]	struct stats_mem *	0x700B3454 {name=0x7011A360 {84 'T'},err=0,avail=5,used=0,max=1...}	0x700B19A4
    		[3]	struct stats_mem *	0x700B3464 {name=0x70119874 {84 'T'},err=0,avail=8,used=0,max=0...}	0x700B19A8
    		[4]	struct stats_mem *	0x700B3474 {name=0x7011A350 {84 'T'},err=0,avail=128,used=0,max=1...}	0x700B19AC
    		[5]	struct stats_mem *	0x700B3324 {name=0x7011A053 {65 'A'},err=0,avail=5,used=0,max=0...}	0x700B19B0
    		[6]	struct stats_mem *	0x700B33F4 {name=0x7011A017 {82 'R'},err=0,avail=10,used=0,max=0...}	0x700B19B4
    		[7]	struct stats_mem *	0x700B3344 {name=0x7011A111 {70 'F'},err=0,avail=15,used=0,max=0...}	0x700B19B8
    		[8]	struct stats_mem *	0x700B3364 {name=0x7011A38E {78 'N'},err=0,avail=128,used=0,max=0...}	0x700B19BC
    		[9]	struct stats_mem *	0x700B3374 {name=0x7011A378 {78 'N'},err=0,avail=10,used=1,max=1...}	0x700B19C0
    		[10]	struct stats_mem *	0x700B3434 {name=0x70119B25 {84 'T'},err=0,avail=128,used=0,max=0...}	0x700B19C4
    		[11]	struct stats_mem *	0x700B3444 {name=0x70119659 {84 'T'},err=0,avail=128,used=0,max=0...}	0x700B19C8
    		[12]	struct stats_mem *	0x700B3334 {name=0x7011A035 {65 'A'},err=0,avail=30,used=1,max=1...}	0x700B19CC
    		[13]	struct stats_mem *	0x700B3354 {name=0x70119FEC {73 'I'},err=0,avail=8,used=0,max=0...}	0x700B19D0
    		[14]	struct stats_mem *	0x700B3424 {name=0x70119E20 {83 'S'},err=0,avail=17,used=7,max=8...}	0x700B19D4
    		[15]	struct stats_mem *	0x700B3384 {name=0x7011A3D2 {78 'N'},err=0,avail=1,used=0,max=0...}	0x700B19D8
    		[16]	struct stats_mem *	0x700B3394 {name=0x70119C39 {80 'P'},err=0,avail=128,used=0,max=0...}	0x700B19DC
    		[17]	struct stats_mem *	0x700B33A4 {name=0x7011A0DF {80 'P'},err=0,avail=0,used=0,max=0...}	0x700B19E0
    		[18]	struct stats_mem *	0x700B33B4 {name=0x70119F94 {77 'M'},err=0,avail=100,used=1,max=2...}	0x700B19E4
    		[19]	struct stats_mem *	0x700B33C4 {name=0x70119EEC {77 'M'},err=0,avail=48,used=0,max=0...}	0x700B19E8
    		[20]	struct stats_mem *	0x700B33D4 {name=0x70119E44 {77 'M'},err=0,avail=4,used=0,max=0...}	0x700B19EC
    		[21]	struct stats_mem *	0x700B3414 {name=0x7011A305 {83 'S'},err=0,avail=22,used=0,max=0...}	0x700B19F0
    	sys	struct stats_sys	{sem={used=1,max=1,err=0},mutex={used=1,max=1,err=0},mbox={used=2,max=2,err=0}}	0x700B19F4
    		sem	struct stats_syselem	{used=1,max=1,err=0}	0x700B19F4
    			used	unsigned short	1	0x700B19F4
    			max	unsigned short	1	0x700B19F6
    			err	unsigned short	0	0x700B19F8
    		mutex	struct stats_syselem	{used=1,max=1,err=0}	0x700B19FA
    			used	unsigned short	1	0x700B19FA
    			max	unsigned short	1	0x700B19FC
    			err	unsigned short	0	0x700B19FE
    		mbox	struct stats_syselem	{used=2,max=2,err=0}	0x700B1A00
    			used	unsigned short	2	0x700B1A00
    			max	unsigned short	2	0x700B1A02
    			err	unsigned short	0	0x700B1A04
    	mib2	struct stats_mib2	{ipinhdrerrors=0,ipinaddrerrors=0,ipinunknownprotos=0,ipindiscards=0,ipindelivers=...	0x700B1A08
    		ipinhdrerrors	unsigned int	0	0x700B1A08
    		ipinaddrerrors	unsigned int	0	0x700B1A0C
    		ipinunknownprotos	unsigned int	0	0x700B1A10
    		ipindiscards	unsigned int	0	0x700B1A14
    		ipindelivers	unsigned int	0	0x700B1A18
    		ipoutrequests	unsigned int	5	0x700B1A1C
    		ipoutdiscards	unsigned int	0	0x700B1A20
    		ipoutnoroutes	unsigned int	0	0x700B1A24
    		ipreasmoks	unsigned int	0	0x700B1A28
    		ipreasmfails	unsigned int	0	0x700B1A2C
    		ipfragoks	unsigned int	0	0x700B1A30
    		ipfragfails	unsigned int	0	0x700B1A34
    		ipfragcreates	unsigned int	0	0x700B1A38
    		ipreasmreqds	unsigned int	0	0x700B1A3C
    		ipforwdatagrams	unsigned int	0	0x700B1A40
    		ipinreceives	unsigned int	0	0x700B1A44
    		tcpactiveopens	unsigned int	1	0x700B1A48
    		tcppassiveopens	unsigned int	0	0x700B1A4C
    		tcpattemptfails	unsigned int	0	0x700B1A50
    		tcpestabresets	unsigned int	0	0x700B1A54
    		tcpoutsegs	unsigned int	1	0x700B1A58
    		tcpretranssegs	unsigned int	0	0x700B1A5C
    		tcpinsegs	unsigned int	0	0x700B1A60
    		tcpinerrs	unsigned int	0	0x700B1A64
    		tcpoutrsts	unsigned int	0	0x700B1A68
    		udpindatagrams	unsigned int	0	0x700B1A6C
    		udpnoports	unsigned int	0	0x700B1A70
    		udpinerrors	unsigned int	0	0x700B1A74
    		udpoutdatagrams	unsigned int	0	0x700B1A78
    		icmpinmsgs	unsigned int	0	0x700B1A7C
    		icmpinerrors	unsigned int	0	0x700B1A80
    		icmpindestunreachs	unsigned int	0	0x700B1A84
    		icmpintimeexcds	unsigned int	0	0x700B1A88
    		icmpinparmprobs	unsigned int	0	0x700B1A8C
    		icmpinsrcquenchs	unsigned int	0	0x700B1A90
    		icmpinredirects	unsigned int	0	0x700B1A94
    		icmpinechos	unsigned int	0	0x700B1A98
    		icmpinechoreps	unsigned int	0	0x700B1A9C
    		icmpintimestamps	unsigned int	0	0x700B1AA0
    		icmpintimestampreps	unsigned int	0	0x700B1AA4
    		icmpinaddrmasks	unsigned int	0	0x700B1AA8
    		icmpinaddrmaskreps	unsigned int	0	0x700B1AAC
    		icmpoutmsgs	unsigned int	0	0x700B1AB0
    		icmpouterrors	unsigned int	0	0x700B1AB4
    		icmpoutdestunreachs	unsigned int	0	0x700B1AB8
    		icmpouttimeexcds	unsigned int	0	0x700B1ABC
    		icmpoutechos	unsigned int	0	0x700B1AC0
    		icmpoutechoreps	unsigned int	0	0x700B1AC4
    		P0_STATS	struct CSL_Xge_cpswP0StatsRegs	{RXGOODFRAMES=21,RXBROADCASTFRAMES=21,RXMULTICASTFRAMES=0,Resv_16=[0 '\x00',0 '\x00',...,RXCRCERRORS=...	0x5283A000
    			RXGOODFRAMES	unsigned int	21	0x5283A000
    			RXBROADCASTFRAMES	unsigned int	21	0x5283A004
    			RXOCTETS	unsigned int	1344	0x5283A030
    			OCTETFRAMES64	unsigned int	21	0x5283A068
    			OCTETFRAMES256T511	unsigned int	0	0x5283A074
    			NETOCTETS	unsigned int	1344	0x5283A080
    				TXGOODFRAMES	unsigned int	21	0x5283A434
    				TXBROADCASTFRAMES	unsigned int	21	0x5283A438
    				TXOCTETS	unsigned int	1344	0x5283A464
    				OCTETFRAMES64	unsigned int	21	0x5283A468
    				OCTETFRAMES256T511	unsigned int	0	0x5283A474
    				NETOCTETS	unsigned int	1344	0x5283A480
    				ENET_PN_TX_PRI_REG	unsigned int[8]	[21,0,0,0,0...]	0x5283A580
    				ENET_PN_TX_PRI_BCNT_REG	unsigned int[8]	[1344,0,0,0,0...]	0x5283A5A0
    Run 2: Host PC disconnected. Only Ethernet switch connected.
    4.
    Regrading:
    I ran the application you provided since it has a static IP ( 192.168.1.2)
    When I ping that address there is no response. I see ARP packets on wireshark “Who has 192.168.1.2. Tell 192.168.1.3”
    <CR><LF>
    1. 53s : CPU load = 1.11 %<CR><LF>
    2. 54s : CPU load = 1.09 %<CR><LF>
    3. 55s : CPU load = 1.11 %<CR><LF>
    4. 56s : CPU load = 1.09 %<CR><LF>
    5.
    Regrading:
    “5. Can you once try running: https://software-dl.ti.com/mcu-plus-sdk/esd/AM263PX/latest/exports/docs/api_guide_am263px/EXAMPLES_ENET_LAYER2_CPSW.html (the same way, SBL NULL + OSPI boot mode)
    and verify if you see the packets on wireshark. My suspicion is not on the driver or the application code now. If this example fails to run, let's schedule a debug call on Monday and deep dive further in the debug/working session”
    When I run the examples/networking/enet_layer2_cpsw SDK example, I see no packets from the EVK in Wireshark.
    <CR><LF>
    [BOOTLOADER PROFILE] LoadHsmRtFw                      :      31941us <CR><LF>
    [BOOTLOADER_PROFILE] SBL Total Time Taken             :      56139us <CR><LF>
    <CR><LF>
    <LF>
         Layer 2 CPSW Test    <CR><LF>
    <LF>
    Init all peripheral clocks<CR><LF>
    ----------------------------------------------<CR><LF>
    <LF>
    Create RX tasks<CR><LF>
    cpsw-3g: Create RX task<CR><LF>
    <LF>
    Open all peripherals<CR><LF>
    cpsw-3g: Open enet<CR><LF>
    <LF>
    Init all configs<CR><LF>
    cpsw-3g: init config<CR><LF>
    cpsw-3g: Open port 2<CR><LF>
    <LF>
    Attach core id 0 on all peripherals<CR><LF>
    cpsw-3g: Attach core<CR><LF>
    cpsw-3g: Open DMA<CR><LF>
    cpsw-3g: Waiting for link up...<CR><LF>
    cpsw-3g: MAC port addr: 70:ff:76:1f:60:9b<CR>
    <CR><LF>
    <LF>
    Enet L2 cpsw Menu:<CR><LF>
     's'  -  Print statistics<CR><LF>
     'r'  -  Reset statistics<CR><LF>
     'm'  -  Show allocated MAC addresses<CR><LF>
     'x'  -  Stop the test<CR><LF>
    <LF>
    ss<CR><LF>
    <CR><LF>
    <LF>
    <LF>
     cpsw-3g - Port 2 statistics<CR><LF>
    <LF>
    <LF>
    mm<CR><LF>
    <CR><LF>
    Invalid option, try again...<CR><LF>
    <LF>
    <LF>
    <LF>
    6a)  (repeat)
    6b) (repeat)
    Tollman
  • Hi Tollman,
    1. I tested with the binary attached by you (which i suppose did not work for you, I was able to establish a TCP connection successfully). The application worked as expected. You do have a ncat server running even before you run the Application on AM263Px right?
    Ping might not be the best test because the socket connection might have closed after certain attempts, let us ignore this for now.
    5. I see that the RX Stats are also not visible in the application logs. Did you send packets using colasoft or packEth as mentioned in the example documentation. Is it the case that even after sending packets the stats did not increase?
    6. You can put a breakpoint at EnetDma_submitTxPktQ. If you reach this function and the packet contents are correct here, then the packet is handed over to CPDMA for further transmission and lwIP or Ethernet driver won't have any role. I suspect the issue to be in PHY Tx and Rx configuration.
    The issue here does not seem to be with the lwIP or Ethernet driver but something beyond that.
    Can you try putting a breakpoint at these CPDMA APIs:
    For Tx from the MCU:  EnetCpdma_enqueueTx (If we reach this breakpoint and the packet is visible on the wireshark, then the driver and PHY work fine)
    For Rx on the MCU: EnetCpdma_dequeueRx (If we are able to reach this point in the driver, the PHY Rx works fine and the packet is handed to the driver)
    We can also schedule a debug call to investigate further. I have sent you an email regarding the same
    Shaunak
  • Hi Shaunak,
    1.
    Regarding:
    "I tested with the binary attached by you (which i suppose did not work for you, I was able to establish a TCP connection successfully). The application worked as expected. You do have a ncat server running even before you run the Application on AM263Px right?"
    I am using Wireshark. Since the LAN consists of only the Windows host with Wireshark running, a switch, and the Control Card, there is very little traffic. With this setup I can leave Wireshark running, without filters, and I do not need to have a TCP Server running. This eliminates ‘bad filters’, and TCP Server as points of failure. I can rely on Wireshark for all tests. Please let me know it you think there is a flaw in this method.
    Regarding:
    "Ping might not be the best test because the socket connection might have closed after certain attempts, let us ignore this for now."
    Correct me if I'm wrong, but I believe that ping shouldn't need a TCP connection.
    I am timing the ping by the printf() output. I wait for the “Connecting to: 192.168.1.3:8888“ printf().
    When I examine Wireshark, I see ARP packets when I see ARP packets “Who has 192.168.1.2. Tell 192.168.1.3” at the time of the ping with a Broadcast destination address. I believe that this it to get the MAC address needed for the ping. Regardless, since it is broadcast, I am fairly certain the Control Card should be receiving these packets. I also tried sending UDP to 192.168.1.2, to avoid needing a TCP connection. However, this resulted in the same ARP transmission. Next, I tried a UDP broadcast. When the test completed, I hit the breakpoint at the “"Connection with the server isn't established\r\n" and checked the watch expressions.
    I am attaching the results, but I believe that this is further confirmation that the Control Card is neither transmitting, or receiving successfully at the lower layers of the network stack.
    Run 1: Host PC connected and running wireshark. Sending UDP broadcast 255.255.255.255
    lwip_stats
    CSL_Xge_cpswRegs
    5.
    Regarding:
    "I see that the RX Stats are also not visible in the application logs. Did you send packets using colasoft or packEth as mentioned in the example documentation. Is it the case that even after sending packets the stats did not increase?"
    I am using ping on the command line, and PacketSender to transmit UDP. I tried to install ncat, but I didn't complete installation. I was afraid that it may not coexist well with Wireshark. See item .1.
    6.
    Regarding:
    "You can put a breakpoint at EnetDma_submitTxPktQ. If you reach this function and the packet contents are correct here, then the packet is handed over to CPDMA for further transmission and lwIP or Ethernet driver won't have any role. I suspect the issue to be in PHY Tx and Rx configuration."
    "Can you try putting a breakpoint at these CPDMA APIs:
    For Rx on the MCU: EnetCpdma_dequeueRx (If we are able to reach this point in the driver, the PHY Rx works fine and the packet is handed to the driver)"
    When I use your ‘static IP’ project, the breakpoint at EnetCpdma_enqueueTx() is hit. When I step through, I do not see any indications of errors.
    The breakpoint at EnetCpdma_dequeueRx() never gets hit.
    7.
    Regarding:
    "We can also schedule a debug call to investigate further. I have sent you an email regarding the same"
    I responded to your email.
    Tollman
  • Hi Tollman,
    I was talking from the perspective of TCP connection. You would need a TCP server running before the TCP Client (AM263Px) tries to establish a connection,
    If this was just to get the lwIP and CPSW stats, then no issues.
    The issue here seems to be with the PHY Rx clocks. Have you by any chance changed the clock source of PHY? Seems like the PHY clocks are causing the packets to be dropped even before it reaches the ethernet driver (CPDMA)
    To check further if the PHY Rx is working, can you probe the r212 resistor on AM263Px-CC DP83869 PHY? While you probe this, please run the enet_loopback example in "external loopback" mode? Please share the observations so we can confirm the PHY Rx clock issue. So far with the tests, I don't think the issue is with the Ethernet driver, or lwIP stack or the TCP application in the SDK.
    Shaunak
  • 1)
    I recorded a video running enet_loopback example in "external loopback" mode while probing on R212. I think I was holding the probe steady throughout the video.
    The oscilloscope is triggering on the rising edge of RX_CLK.
    Please review the attached video.
    2)
    Maybe I should've asked this earlier, but ...
    Is there any jumper, switches, on the Control Card that may affect Ethernet?
    Tollman
  • Hi Tollman,
    1. Thanks for Sharing the video, PHY Rx clock looks fine to me. But can you also share if the external loopback example worked? Did the logs seem fine?
    2. I'm not sure about this. Are you using any jumpers/switches on the control card?
    3. I think we will only be able to proceed with the debug on a call. I tried again today and was not able to reproduce it. I can set up a 1 hour call anytime between 9am EDT to 11am EDT. Please confirm the slot over email  and I can share the meeting invite
    4. Are you making any changes to the clock sources? Or on the board?
    5. Did you try the tcp client example with TCP NCAT server running before the client starts?
    Shaunak
  • Hi Shaunak,
    1.
    Regarding:
    “Thanks for Sharing the video, PHY Rx clock looks fine to me. But can you also share if the external loopback example worked? Did the logs seem fine?”
    Sorry, I thought I made a second post yesterday. I guess I did not actually send it.
    It seems that the TX Task works normally, but RX ISR never executes.
    i.e. This never executes:
    static void EnetApp_rxIsrFxn(void *appData)
        SemaphoreP_post(&gEnetLpbk.rxSemObj);
    2.
    Regarding:
    "I'm not sure about this. Are you using any jumpers/switches on the control card?"
    I see that SW14, SW15, and SW16 determine the routing of the Ethernet. I did not change any of these switches on either Control Card I have. However, I will investigate if they are in the correct position.
    3.
    Regarding:
    I look forward to troubleshooting with you.
    4.
    Regarding:
    I have not made any changes to the Control Card I am testing with.
    5.
    Regarding:
    As I mentioned before, I am afraid to install ncat on my test PC. I am afraid that it may break my Wireshark setup. I do not think this is beneficial, because Wireshark demonstrates that there is no packets reaching the test PC from the Control Card.
    Tollman
  • UPDATE:
    Sorry, I forgot to include the printf logs for item 1. Here they are:
    <CR><LF>
     0: Internal MAC loopback <CR><LF>
     1: External PHY loopback <CR><LF>
     <CR><LF>
     Enter option: 11<CR><LF>
    <CR><LF>
    =============================<CR><LF>
     Enet Loopback: Iteration 1 <CR><LF>
    CPSW_3G Test<CR><LF>
    EnetAppUtils_reduceCoreMacAllocation: Reduced Mac Address Allocation for CoreId:0 From 4 To 2 <CR><LF>
    PHY 0 is alive<CR><LF>
    initQs() txFreePktInfoQ initialized with 16 pkts<CR><LF>
    Transmitted 5000 packets <CR><LF>
    Delete EnetApp_txTask() and exit..<CR><LF>
    Tollman
  • Hi Shaunak,
    Good news. I found that SW15 was in the wrong position. It seems that both my EVKs were shipped with CPSW not routed to the on-board RJ45 connector.
    When I changed the position of SW15 to off and execute your 'static address TCP client' application, I see the packets on Wireshark.
    Tollman
  • Hi Tollman,
    Glad to hear that the issue is resolved now.
    There are hardware checks performed before shipping. This might have occurred during manual packaging after testing. This is a very rare occurrence and I apologize for the issues you faced. I have passed on this incident to our manufacturers to make sure this does not happen again.
    Shaunak
