Part Number: MCU-PLUS-SDK-AM263X
Hi, I'm trying to build a custom SBL, but I've run into a number of basic problems.
How can I debug a SBL example or a custom SBL??
Hi Joseito,
Our boot expert will be out on holiday tomorrow, please except a short delay in reply due to this.
Ralph Jacobi
Hi Joseíto Júnior,
Feasibility of both the methods are possible. It comes with its own pros and cons.
Are you trying and testing the FAQ in QSPI (0010) boot mode ? Are you able to load the symbols and find the same software ?
Aakash
Hi Aakash, thanks for your reply.
It took me a while to reply because I was doing some tests first.
The problem was the boot mode, the switch was set to 0010, but the console didn't indicate this as QSPI mode. It worked after changing the switch to 1101, indicating "QSPI - 1S Functional boot mode" on the console. Apparently the logic level is inverted on the launchpad.
Joseíto.
Hi Joseíto Júnior,
The logic is same but the dip switch is kind-of inverted - https://dev.ti.com/tirex/explore/node?node=A__AX8xN-dPKKXfZ0gxKkK5Kg__AM26X-ACADEMY__t0CaxbG__LATESTI.
Aakash
