MSPM0L1306: compiler/MSPM0l1306 : GHS compiler
Part Number: MSPM0L1306
 i m using MSPM0L1306 controller i want to use GSH compiler. how to add GHS compiler in CCS and how to create environment setup for GHS compiler.
or any Document available for GHS Compiler.
  • Hi Garima,
    Let me check with our SW team.
  • Hi Garima,
    I'm being told:
    I am not aware of CCS being able to recognize GHS tools(i.e. compiler/linker).
     I think in both CCS Eclipse and CCS Theia you could probably manually create a makefile or invoke an external build system that invokes GHS build tools and then start debugger and manually load generated programs. However, this would not provide the same type of integration as you get with TI or GCC tools. User would be responsible for manually adjusting the build files to make changes.
