Part Number: PROCESSOR-SDK-AM68
Other Parts Discussed in Thread: AM68
dell@dell-Inspiron-5558:~/ti-processor-sdk-linux-j721s2-evm-09_02_00_04$ sudo ./setup.sh
[sudo] password for dell:
TISDK setup script
This script will set up your development host for SDK development.
Parts of this script require administrator priviliges (sudo access).
Verifying Linux host distribution
Ubuntu 22.04 LTS is being used, continuing..
Starting with Ubuntu 12.04 serial devices are only accessible by members of the 'dialout' group.
A user must be apart of this group to have the proper permissions to access a serial device.
Are you running this script using sudo? The detected username is 'root'.
Verify and enter your Linux username below
[ root ]
User 'root' is already apart of the 'dialout' group
Do you wish to install required host packages (Press (Y) to run, (n) to skip)?
setup package script
This script will make sure you have the proper host support packages installed
This script requires administrator priviliges (sudo access) if packages are to be installed.
System has required packages!
System has required python3 packages!
Package verification and installation successfully completed
Do you wish to run nfs setup (Press (Y) to run, (n) to skip) ?
In which directory do you want to install the target filesystem?(if this directory does not exist it will be created)
[ /home/dell/ti-processor-sdk-linux-j721s2-evm-09_02_00_04/targetNFS ]
This step will extract the target filesystem to /home/dell/ti-processor-sdk-linux-j721s2-evm-09_02_00_04/targetNFS
Note! This command requires you to have administrator priviliges (sudo access)
on your host.
Press return to continue
/home/dell/ti-processor-sdk-linux-j721s2-evm-09_02_00_04/targetNFS already exists
(r) rename existing filesystem (o) overwrite existing filesystem (s) skip filesystem extraction
[r] s
Skipping filesystem extraction
WARNING! Keeping the previous filesystem may cause compatibility problems if you are upgrading the SDK
This step will set up the SDK to install binaries in to:
/home/dell/ti-processor-sdk-linux-j721s2-evm-09_02_00_04/targetNFS/home/root/j721s2-evm
The files will be available from /home/root/j721s2-evm on the target.
This setting can be changed later by editing Rules.make and changing the
ROOTFS_PART variable.
Rules.make edited successfully..
This step will export your target filesystem for NFS access.
on your host.
/home/dell/ti-processor-sdk-linux-j721s2-evm-09_02_00_04/targetNFS already NFS exported, skipping..
Stopping nfs-kernel-server (via systemctl): nfs-kernel-server.service.
Starting nfs-kernel-server (via systemctl): nfs-kernel-server.service.
Do you wish to run tftp setup (Press (Y) to run, (n) to skip) ?
Which directory do you want to be your tftp root directory?(if this directory does not exist it will be created for you)
[ /tftpboot ]
This step will set up the tftp server in the /tftpboot directory.
on your host.
/tftpboot already exists, not creating..
/tftpboot/*Image-j721s2-evm.bin already exists. The existing installed file can be renamed and saved under the new name.
(r) rename (o) overwrite (s) skip copy
[r] s
Skipping copy of *Image-j721s2-evm.bin, existing version will be used
Successfully copied k3-am68-sk-base-board.dtb to tftp root directory /tftpboot
Successfully copied k3-j721s2-common-proc-board.dtb to tftp root directory /tftpboot
Successfully copied u-boot.dtb to tftp root directory /tftpboot
Successfully copied k3-am68-sk-bb-csi2-ov5640.dtbo to tftp root directory /tftpboot
Successfully copied k3-am68-sk-bb-rpi-cam-imx219.dtbo to tftp root directory /tftpboot
Successfully copied k3-am68-sk-fpdlink-fusion.dtbo to tftp root directory /tftpboot
Successfully copied k3-am68-sk-rpi-hdr-ehrpwm.dtbo to tftp root directory /tftpboot
Successfully copied k3-am68-sk-som-ddr-mem-carveout.dtbo to tftp root directory /tftpboot
Successfully copied k3-am68-sk-v3link-fusion.dtbo to tftp root directory /tftpboot
Successfully copied k3-fpdlink-imx390-rcm-0-0.dtbo to tftp root directory /tftpboot
Successfully copied k3-fpdlink-imx390-rcm-0-1.dtbo to tftp root directory /tftpboot
Successfully copied k3-fpdlink-imx390-rcm-0-2.dtbo to tftp root directory /tftpboot
Successfully copied k3-fpdlink-imx390-rcm-0-3.dtbo to tftp root directory /tftpboot
Successfully copied k3-fpdlink-imx390-rcm-1-0.dtbo to tftp root directory /tftpboot
Successfully copied k3-fpdlink-imx390-rcm-1-1.dtbo to tftp root directory /tftpboot
Successfully copied k3-fpdlink-imx390-rcm-1-2.dtbo to tftp root directory /tftpboot
Successfully copied k3-fpdlink-imx390-rcm-1-3.dtbo to tftp root directory /tftpboot
Successfully copied k3-fpdlink-imx390-rcm-2-0.dtbo to tftp root directory /tftpboot
Successfully copied k3-fpdlink-imx390-rcm-2-1.dtbo to tftp root directory /tftpboot
Successfully copied k3-fpdlink-imx390-rcm-2-2.dtbo to tftp root directory /tftpboot
Successfully copied k3-fpdlink-imx390-rcm-2-3.dtbo to tftp root directory /tftpboot
Successfully copied k3-fpdlink-ov2312-0-0.dtbo to tftp root directory /tftpboot
Successfully copied k3-fpdlink-ov2312-0-1.dtbo to tftp root directory /tftpboot
Successfully copied k3-fpdlink-ov2312-0-2.dtbo to tftp root directory /tftpboot
Successfully copied k3-fpdlink-ov2312-0-3.dtbo to tftp root directory /tftpboot
Successfully copied k3-j7200-evm-mcspi-loopback.dtbo to tftp root directory /tftpboot
Successfully copied k3-j721s2-evm-csi2-ov5640.dtbo to tftp root directory /tftpboot
Successfully copied k3-j721s2-evm-fusion.dtbo to tftp root directory /tftpboot
Successfully copied k3-j721s2-evm-gesi-exp-board.dtbo to tftp root directory /tftpboot
Successfully copied k3-j721s2-evm-pcie1-ep.dtbo to tftp root directory /tftpboot
/etc/xinetd.d/tftp already exists..
/tftpboot already exported for TFTP, skipping..
Restarting tftp server
Stopping xinetd (via systemctl): xinetd.service.
Starting xinetd (via systemctl): xinetd.service.
Do you wish to run minicom setup (Press (Y) to run, (n) to skip) ?
This step will set up minicom (serial communication application) for
SDK development
For boards that contain a USB-to-Serial converter on the board such as:
* BeagleBone
* Beaglebone Black
* AM335x EVM-SK
* AM57xx EVM
* K2H, K2L, and K2E EVMs
the port used for minicom will be automatically detected. By default Ubuntu
will not recognize this device. Setup will add a udev rule to
/etc/udev/ so that from now on it will be recognized as soon as the board is
plugged in.
For other boards, the serial will defualt to /dev/ttyUSB2. Please update based
on your setup.
NOTE: If your using any of the above boards simply hit enter
and the correct port will be determined automatically at a
later step. For all other boards select the serial port
that the board is connected to.
Which serial port do you want to use with minicom?
[ /dev/ttyUSB2 ]
Copied existing /root/.minirc.dfl to /root/.minirc.dfl.old
Configuration saved to /root/.minirc.dfl. You can change it further from inside
minicom, see the Software Development Guide for more information.
Do you wish to run uboot setup (Press (Y) to run, (n) to skip) ?
This step will set up the u-boot variables for booting the EVM.
Autodetected the following ip address of your host, correct it if necessary
[ 192.168.12.193
192.168.12.193 ]
Select Linux kernel location:
1: TFTP
2: SD card
[ 1 ]
Select root file system location:
1: NFS
2: SD card
[ 1 ]
Available kernel images in /tftpboot:
ti
Which kernel image do you want to boot from TFTP?
[ Image-j721s2-evm.bin ]
Successfully wrote minicom script with above parameters: /home/dell/ti-processor-sdk-linux-j721s2-evm-09_02_00_04/bin/setupBoard.minicom
Would you like to run the minicom script and boot the board? (y/n)?
[ y ]
Detecting connection to board... portdefault: /dev/ttyUSB2
cannot read device status, Resource temporarily unavailable (11)
Unable to detect which port the board is connected to.
Please reconnect your board.
Press 'y' to attempt to detect your board again or press 'n' to continue...
(y/n)^C
