Part Number: TM4C129ENCPDT
I have a question.During serial connection on the USB0DM and USB0DP pins, a reset occurred several times, after which the surface temperature of the device became much higher than normal and the current consumption was also much higher.
The WDT count was 0 mom when the resets occurred.
Serial connection was then disabled, and PP0, PP1, SSI0CLK, PA3, SSI0XDAT0, and SSI0XDAT1 also stopped functioning. Has such a phenomenon ever been reported? What could be the cause?Thank you in advance for your understanding.
