TMS570LS3137: TMS570LS3137 MRAM MR25H40 Configuration
Part Number: TMS570LS3137
The clock should continue as long as the cs pin is low, but the clock continues only for the duration of the message we sent. Can you help with the spi configuration required for this situation?
  • Hi Ataberk,
    The clock from master will be generated till the data gets shift out of the Master out line only. If you want to generate the more clock, then you should need to send some dummy bytes.
    And same thing applicable for CS line as well, the CS line will be in active until the data gets shift out of the master out line. If you want CS to be active more time, than we should send some dummy data from the master.
    Thanks & Regards,
    Jagadish.
