Part Number: MCU-PLUS-SDK-AM263X
Hi everyone,
I have the exact same problem found in this post.
e2e.ti.com/.../mcu-plus-sdk-am263x-fault-in-ipc-shared-memory-mutex-using-spinlock-example-project
As you can see from the image below (is mine debug session).
I tried the work around suggested as a solution in the post, but even with several attempts, I have the second core still blocked in HwiP_undefined_handler().
How can be fixed this issue, because is the project taken from the sdk, and it seem strange TI has release an example that not work.
kind regards and thanks for the help.
