I would like to flash my program to the flash memory and to run my application program.
Actually I don't need SBL. I just want to execute my application program.
If the SBL is need to run program, Should I do the coding for SBL ?
Then should I make me understood about the SBL and the detailed ?
Please let me know the method to run my program from flash memory.
When I try to make the example project of the SDK, it result an error.
- project name: sbl_qspi_am273x-evm_r5fss0-0_nortos_ti-arm-clang
- error name: makefile_ccs_bootimage_gen:65: recipe for target 'all' failed
then contents of this file is as next
# Auto generated makefile
# Below variables need to be defined outside this file or via command line
# - MCU_PLUS_SDK_PATH
# - PROFILE
# - CG_TOOL_ROOT
# - OUTNAME
# - CCS_INSTALL_DIR
# - CCS_IDE_MODE
CCS_PATH=$(CCS_INSTALL_DIR)
include $(MCU_PLUS_SDK_PATH)/imports.mak
include $(MCU_PLUS_SDK_PATH)/devconfig/devconfig.mak
STRIP=$(CG_TOOL_ROOT)/bin/tiarmstrip
OBJCOPY=$(CG_TOOL_ROOT)/bin/tiarmobjcopy
ifeq ($(OS), Windows_NT)
PYTHON=python
else
PYTHON=python3
endif
OUTFILE=$(PROFILE)/$(OUTNAME).out
BOOTIMAGE_PATH=$(abspath ${PROFILE})
BOOTIMAGE_NAME_GP:=$(BOOTIMAGE_PATH)/$(OUTNAME).tiimage
BOOTIMAGE_NAME_HS:=sbl_qspi.$(PROFILE).hs.tiimage
BOOTIMAGE_NAME_HS_FS:=sbl_qspi.$(PROFILE).hs_fs.tiimage
ifeq ($(DEVICE_TYPE),HS)
BOOTIMAGE_NAME=$(BOOTIMAGE_NAME_HS)
else
BOOTIMAGE_NAME=$(BOOTIMAGE_NAME_GP)
endif
BOOTIMAGE_BIN_NAME:=$(BOOTIMAGE_PATH)/$(OUTNAME).bin
# Generation of boot image which can be loaded by ROM Boot Loader (RBL)
ifeq ($(OS),Windows_NT)
EXE_EXT=.exe
endif
BOOTIMAGE_CERT_GEN_CMD=powershell -executionpolicy unrestricted -command $(MCU_PLUS_SDK_PATH)/tools/boot/signing/x509CertificateGen.ps1
else
BOOTIMAGE_CERT_GEN_CMD=$(MCU_PLUS_SDK_PATH)/tools/boot/signing/x509CertificateGen.sh
endif
BOOTIMAGE_TEMP_OUT_FILE=$(PROFILE)/temp_stdout_$(PROFILE).txt
BOOTIMAGE_CERT_KEY=$(APP_SIGNING_KEY)
else
BOOTIMAGE_CERT_KEY=$(MCU_PLUS_SDK_PATH)/tools/boot/signing/mcu_gpkey.pem
endif
BOOTIMAGE_CERT_GEN_CMD=$(PYTHON) $(MCU_PLUS_SDK_PATH)/tools/boot/signing/mcu_rom_image_gen.py
SBL_RUN_ADDRESS=0x10200000
SBL_PREBUILT_PATH=$(MCU_PLUS_SDK_PATH)/tools/boot/sbl_prebuilt/am273x-evm
all:
ifeq ($(CCS_IDE_MODE),cloud)
# No post build steps
else
@echo Boot image: am273x:r5fss0-0:nortos:ti-arm-clang $(BOOTIMAGE_NAME) ...
$(OBJCOPY) --strip-all -O binary $(OUTFILE) $(BOOTIMAGE_BIN_NAME)
ifeq ($(DEBUG_TIFS), yes)
ifeq ($(ENC_SBL_ENABLED),yes)
$(BOOTIMAGE_CERT_GEN_CMD) --sbl-enc --enc-key $(APP_ENCRYPTION_KEY) --image-bin $(BOOTIMAGE_BIN_NAME) --core R5 --swrv 1 --loadaddr $(SBL_RUN_ADDRESS) --sign-key $(BOOTIMAGE_CERT_KEY) --kd-salt $(KD_SALT) --out-image $(BOOTIMAGE_NAME)
else
$(BOOTIMAGE_CERT_GEN_CMD) --image-bin $(BOOTIMAGE_BIN_NAME) --core R5 --swrv 1 --loadaddr $(SBL_RUN_ADDRESS) --sign-key $(BOOTIMAGE_CERT_KEY) --out-image $(BOOTIMAGE_NAME)
endif
else
$(BOOTIMAGE_CERT_GEN_CMD) --sbl-enc --enc-key $(APP_ENCRYPTION_KEY) --image-bin $(BOOTIMAGE_BIN_NAME) --core R5 --swrv 1 --loadaddr $(SBL_RUN_ADDRESS) --sign-key $(BOOTIMAGE_CERT_KEY) --kd-salt $(KD_SALT) --out-image $(BOOTIMAGE_NAME) --debug $(DEBUG_OPTION)
else
$(BOOTIMAGE_CERT_GEN_CMD) --image-bin $(BOOTIMAGE_BIN_NAME) --core R5 --swrv 1 --loadaddr $(SBL_RUN_ADDRESS) --sign-key $(BOOTIMAGE_CERT_KEY) --out-image $(BOOTIMAGE_NAME) --debug $(DEBUG_OPTION)
endif
endif
else
$(BOOTIMAGE_CERT_GEN_CMD) --image-bin $(BOOTIMAGE_BIN_NAME) --core R5 --swrv 1 --loadaddr $(SBL_RUN_ADDRESS) --sign-key $(BOOTIMAGE_CERT_KEY) --out-image $(BOOTIMAGE_NAME) --debug DBG_SOC_DEFAULT
@echo Boot image: am273x:r5fss0-0:nortos:ti-arm-clang $(BOOTIMAGE_NAME) Done !!!
@echo .
endif
endif
Can this example apply to my project?
