Part Number: AM2431
We are using sysconfig 1.17 and I'm trying to add a MCSPI port to talk to 2 devices.
I see in the datasheet there are pins that can be used for CS0, CS1, CS2 & CS3
In sysconfig, you can define a CS pin under the MCSPI Channel Configuration, but it won't let you add any more (it says Instance limit has been reached.
Is there a way to add more CS pins to the SPI configuration?
