Part Number: TMS570LS3137
Dear All,
To send data as a PWM signal, Het1_31 Pin is used as a PWM Pin after Het1 driver enable and Init.
Then, can the remaining Het1 Pins be used as GIO pins?
IBLEE
Dear All,
IBLEE
Hi IBLEE,
Yes, you can use them. If you didn't enable the PWM functionality for the HET pins, then the corresponding pins can be used as GIO without any issue.
Thanks & Regards,
Jagadish.
So it's impossible to use Het1_31 Pin as PWM and other Het1 pins as GIO at the same time?
Not that what i mean.
You can use HET1_31 pin as PWM and other HET1 pins as GIO. There won't be any problem.
