RM48L952: CMSIS DSP library compile warning
Part Number: RM48L952
I am trying to build the CMSIS DSP library with the CCS ti-cgt-arm_20.2.7.LTS.
I have encounter several problems which i am looking for your support:
For the moment, i have applied the same solution which comment the ligne in type_defs.h.
Just to be sure, Is this still the only solution ?
  • During the compile of the library, the warning "#2104-D: attribute "__packed__" does not apply here" have appeared several times on the lignes in the file arm_math.h (for example, ligne 4632).
    For the moment, I have suppressed the warning but is there a cleaner way to eliminate the warning?
Thank you for your support.
Hanlin YU
