Part Number: MSP-EXP432E401Y
Other Parts Discussed in Thread: ADS131M08
I am checking a code to integrate ADS131M08 ADC, with the launchpad. The code is below.
#include <stdint.h>
#include <stdbool.h>
#include "ti/devices/msp432e4/driverlib/driverlib.h"
#include "ads131m0x.h"
uint32_t systemClock;
uint16_t register_value;
#define SSI_BASE_ADDR (SSI3_BASE)
// The error routine that is called if the driver library encounters an error.
//#ifdef DEBUG
//void
//__error__(char *pcFilename, uint32_t ui32Line)
// while(1);
//#endif
// Main Function. All other functions are written down
int
main(void)
InitSPI();
adcStartup();
return 0;
//! Configures the MCU's SPI peripheral, for interfacing with the ADC.
//! \fn void InitSPI(void)
//! \return None.
void InitSPI(void)
// Enable the clock to SSI-3 module and configure the SSI Master
MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_SSI3);
while(!(MAP_SysCtlPeripheralReady(SYSCTL_PERIPH_SSI3)))
// Enable clocks to GPIO Port Q and configure pins as SSI
MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOQ);
while(!(MAP_SysCtlPeripheralReady(SYSCTL_PERIPH_GPIOQ)))
MAP_GPIOPinConfigure(GPIO_PQ0_SSI3CLK);
//MAP_GPIOPinConfigure(GPIO_PA3_SSI0FSS); // Using GPIO for nCS instead of the FSS pin.
MAP_GPIOPinConfigure(GPIO_PQ2_SSI3XDAT0);
MAP_GPIOPinConfigure(GPIO_PQ3_SSI3XDAT1);
MAP_GPIOPinTypeSSI(GPIO_PORTQ_BASE, (GPIO_PIN_0 | GPIO_PIN_2 | GPIO_PIN_3));
/* Configure the system clock for 120 MHz */
systemClock = MAP_SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ | SYSCTL_OSC_MAIN |
SYSCTL_USE_PLL | SYSCTL_CFG_VCO_480),
120000000);
// Configure: SPI MODE 1, 5 MHz SCLK, 8-bits per frame
MAP_SSIConfigSetExpClk(SSI_BASE_ADDR, systemClock, SSI_FRF_MOTO_MODE_1, \
SSI_MODE_MASTER, (systemClock/24), 8);
//MAP_SSIEnable(SSI_BASE_ADDR);
// Enable the SSI2 module.
SSIAdvModeSet(SSI_BASE_ADDR, SSI_ADV_MODE_READ_WRITE);
SSIAdvFrameHoldDisable(SSI_BASE_ADDR);
// Read any residual data from the SSI port. This makes sure the receive
// FIFOs are empty, so we don't read any unwanted junk. This is done here
// because the SPI SSI mode is full-duplex, which allows you to send and
// receive at the same time. The SSIDataGetNonBlocking function returns
// "true" when data was returned, and "false" when no data was returned.
// The "non-blocking" function checks if there is any data in the receive
// FIFO and does not "hang" if there isn't.
uint32_t junk;
while(MAP_SSIDataGetNonBlocking(SSI_BASE_ADDR, &junk));
//! Start up sequence for the ADS131M0x.
//! \fn void adcStartup(void)
//! Before calling this function, the device must be powered,
//! the SPI/GPIO pins of the MCU must have already been configured,
//! and (if applicable) the external clock source should be provided to CLKIN.
//! \return None.
/* (OPTIONAL) Provide additional delay time for power supply settling */
delay_ms(100);
/* (REQUIRED) Set nRESET pin high for ADC operation */
setSYNC_RESET(HIGH);
delay_ms(20);
/* (OPTIONAL) Toggle nRESET pin to ensure default register settings. */
/* NOTE: This also ensures that the device registers are unlocked. */
toggleRESET();
delay_ms(20);
/* (REQUIRED) Initialize internal 'registerMap' array with device default settings */
restoreRegisterDefaults();
/* (OPTIONAL) Validate first response word when beginning SPI communication: (0xFF20 | CHANCNT) */
//uint16_t response = sendCommand(OPCODE_NULL);
/* (OPTIONAL) Define your initial register settings here */
//writeSingleRegister(CLOCK_ADDRESS, (CLOCK_DEFAULT & ~CLOCK_OSR_MASK) | CLOCK_OSR_256);
/* (REQUIRED) Configure MODE register settings
* NOTE: This function call is required here for this particular code implementation to work.
* This function will enforce the MODE register settings as selected in the 'ads131m0x.h' header file.
writeSingleRegister(MODE_ADDRESS, MODE_DEFAULT);
/* (OPTIONAL) Read back all registers */
/* (OPTIONAL) Check STATUS register for faults */
//! Provides a timing delay with 'ms' resolution.
//! \fn void delay_ms(const uint32_t delay_time_ms)
//! \param delay_time_ms is the number of milliseconds to delay.
//! \return None.
const uint32_t cycles_per_loop = 3;
MAP_SysCtlDelay( delay_time_ms * systemClock / (cycles_per_loop * 1000u) );
//! Controls the state of the nSYNC/nRESET GPIO pin.
//! \fn void setSYNC_RESET(const bool state)
//! \param state boolean indicating which state to set the nSYNC/nRESET pin (0=low, 1=high)
//! NOTE: The 'HIGH' and 'LOW' macros defined in hal.h can be passed to this
//! function for the 'state' parameter value.
//! \return None.
uint8_t value = (uint8_t) (state ? nSYNC_nRESET_PIN : 0);
MAP_GPIOPinWrite(nSYNC_nRESET_PORT, nSYNC_nRESET_PIN, value);
//! Toggles the "nSYNC/nRESET" pin to trigger a reset
//! (LOW, delay 2 ms, then HIGH).
//! \fn void toggleRESET(void)
//! \return None.
MAP_GPIOPinWrite(nSYNC_nRESET_PORT, nSYNC_nRESET_PIN, 0);
// Minimum /RESET pulse width (tSRLRST) equals 2,048 CLKIN periods (1 ms @ 2.048 MHz)
delay_ms(20);
delay_ms(20);
MAP_GPIOPinWrite(nSYNC_nRESET_PORT, nSYNC_nRESET_PIN, nSYNC_nRESET_PIN);
// tREGACQ delay before communicating with the device again
delay_ms(20);
// NOTE: The ADS131M0x's next response word should be (0xFF20 | CHANCNT).
// A different response may be an indication that the device did not reset.
// Update register array
//restoreRegisterDefaults();
// Write to MODE register to enforce mode settings
//writeSingleRegister(MODE_ADDRESS, MODE_DEFAULT);
//! Updates the registerMap[] array to its default values.
//! \fn void restoreRegisterDefaults(void)
//! NOTES:
//! - If the MCU keeps a copy of the ADS131M0x register settings in memory,
//! then it is important to ensure that these values remain in sync with the
//! actual hardware settings. In order to help facilitate this, this function
//! should be called after powering up or resetting the device (either by
//! hardware pin control or SPI software command).
//! - Reading back all of the registers after resetting the device can
//! accomplish the same result; however, this might be problematic if the
//! device was previously in CRC mode or the WLENGTH was modified, since
//! resetting the device exits these modes. If the MCU is not aware of this
//! mode change, then read register commands will return invalid data due to
//! the expectation of data appearing in a different byte position.
//! \return None.
registerMap[ID_ADDRESS] = 0x00; /* NOTE: This a read-only register */
registerMap[STATUS_ADDRESS] = STATUS_DEFAULT;
registerMap[MODE_ADDRESS] = MODE_DEFAULT;
registerMap[CLOCK_ADDRESS] = CLOCK_DEFAULT;
registerMap[GAIN1_ADDRESS] = GAIN1_DEFAULT;
registerMap[GAIN2_ADDRESS] = GAIN2_DEFAULT;
registerMap[CFG_ADDRESS] = CFG_DEFAULT;
registerMap[THRSHLD_MSB_ADDRESS] = THRSHLD_MSB_DEFAULT;
registerMap[THRSHLD_LSB_ADDRESS] = THRSHLD_LSB_DEFAULT;
registerMap[CH0_CFG_ADDRESS] = CH0_CFG_DEFAULT;
registerMap[CH0_OCAL_MSB_ADDRESS] = CH0_OCAL_MSB_DEFAULT;
registerMap[CH0_OCAL_LSB_ADDRESS] = CH0_OCAL_LSB_DEFAULT;
registerMap[CH0_GCAL_MSB_ADDRESS] = CH0_GCAL_MSB_DEFAULT;
registerMap[CH0_GCAL_LSB_ADDRESS] = CH0_GCAL_LSB_DEFAULT;
#if (CHANNEL_COUNT > 1)
registerMap[CH1_CFG_ADDRESS] = CH1_CFG_DEFAULT;
registerMap[CH1_OCAL_MSB_ADDRESS] = CH1_OCAL_MSB_DEFAULT;
registerMap[CH1_OCAL_LSB_ADDRESS] = CH1_OCAL_LSB_DEFAULT;
registerMap[CH1_GCAL_MSB_ADDRESS] = CH1_GCAL_MSB_DEFAULT;
registerMap[CH1_GCAL_LSB_ADDRESS] = CH1_GCAL_LSB_DEFAULT;
#endif
#if (CHANNEL_COUNT > 2)
registerMap[CH2_CFG_ADDRESS] = CH2_CFG_DEFAULT;
registerMap[CH2_OCAL_MSB_ADDRESS] = CH2_OCAL_MSB_DEFAULT;
registerMap[CH2_OCAL_LSB_ADDRESS] = CH2_OCAL_LSB_DEFAULT;
registerMap[CH2_GCAL_MSB_ADDRESS] = CH2_GCAL_MSB_DEFAULT;
registerMap[CH2_GCAL_LSB_ADDRESS] = CH2_GCAL_LSB_DEFAULT;
#endif
#if (CHANNEL_COUNT > 3)
registerMap[CH3_CFG_ADDRESS] = CH3_CFG_DEFAULT;
registerMap[CH3_OCAL_MSB_ADDRESS] = CH3_OCAL_MSB_DEFAULT;
registerMap[CH3_OCAL_LSB_ADDRESS] = CH3_OCAL_LSB_DEFAULT;
registerMap[CH3_GCAL_MSB_ADDRESS] = CH3_GCAL_MSB_DEFAULT;
registerMap[CH3_GCAL_LSB_ADDRESS] = CH3_GCAL_LSB_DEFAULT;
#endif
#if (CHANNEL_COUNT > 4)
registerMap[CH4_CFG_ADDRESS] = CH4_CFG_DEFAULT;
registerMap[CH4_OCAL_MSB_ADDRESS] = CH4_OCAL_MSB_DEFAULT;
registerMap[CH4_OCAL_LSB_ADDRESS] = CH4_OCAL_LSB_DEFAULT;
registerMap[CH4_GCAL_MSB_ADDRESS] = CH4_GCAL_MSB_DEFAULT;
registerMap[CH4_GCAL_LSB_ADDRESS] = CH4_GCAL_LSB_DEFAULT;
#endif
#if (CHANNEL_COUNT > 5)
registerMap[CH5_CFG_ADDRESS] = CH5_CFG_DEFAULT;
registerMap[CH5_OCAL_MSB_ADDRESS] = CH5_OCAL_MSB_DEFAULT;
registerMap[CH5_OCAL_LSB_ADDRESS] = CH5_OCAL_LSB_DEFAULT;
registerMap[CH5_GCAL_MSB_ADDRESS] = CH5_GCAL_MSB_DEFAULT;
registerMap[CH5_GCAL_LSB_ADDRESS] = CH5_GCAL_LSB_DEFAULT;
#endif
#if (CHANNEL_COUNT > 6)
registerMap[CH6_CFG_ADDRESS] = CH6_CFG_DEFAULT;
registerMap[CH6_OCAL_MSB_ADDRESS] = CH6_OCAL_MSB_DEFAULT;
registerMap[CH6_OCAL_LSB_ADDRESS] = CH6_OCAL_LSB_DEFAULT;
registerMap[CH6_GCAL_MSB_ADDRESS] = CH6_GCAL_MSB_DEFAULT;
registerMap[CH6_GCAL_LSB_ADDRESS] = CH6_GCAL_LSB_DEFAULT;
#endif
#if (CHANNEL_COUNT > 7)
registerMap[CH7_CFG_ADDRESS] = CH7_CFG_DEFAULT;
registerMap[CH7_OCAL_MSB_ADDRESS] = CH7_OCAL_MSB_DEFAULT;
registerMap[CH7_OCAL_LSB_ADDRESS] = CH7_OCAL_LSB_DEFAULT;
registerMap[CH7_GCAL_MSB_ADDRESS] = CH7_GCAL_MSB_DEFAULT;
registerMap[CH7_GCAL_LSB_ADDRESS] = CH7_GCAL_LSB_DEFAULT;
#endif
registerMap[REGMAP_CRC_ADDRESS] = REGMAP_CRC_DEFAULT;
//! Writes data to a single register.
//! \fn void writeSingleRegister(uint8_t address, uint16_t data)
//! \param address is the address of the register to write to.
//! \param data is the value to write.
//! This command will be ignored if device registers are locked.
//! \return None.
/* Check that the register address is in range */
assert(address < NUM_REGISTERS);
// (OPTIONAL) Enforce certain register field values when
// writing to the MODE register to fix the operation mode
if (MODE_ADDRESS == address)
data = enforce_selected_device_modes(data);
// Build TX and RX byte array
#ifdef ENABLE_CRC_IN
uint8_t dataTx[12] = { 0 }; // 3 words, up to 4 bytes each = 12 bytes maximum
uint8_t dataRx[12] = { 0 };
#else
uint8_t dataTx[8] = { 0 }; // 2 words, up to 4 bytes long = 8 bytes maximum
uint8_t dataRx[8] = { 0 };
#endif
uint16_t opcodes[2];
opcodes[0] = OPCODE_WREG | (((uint16_t) address) << 7);
opcodes[1] = data;
uint8_t numberOfBytes = buildSPIarray(&opcodes[0], 2, dataTx);
// Send command
spiSendReceiveArrays(dataTx, dataRx, numberOfBytes);
// Update internal array
registerMap[address] = data;
// (RECOMMENDED) Read back register to confirm register write was successful
register_value = readSingleRegister(address);
// NOTE: Enabling the CRC words in the SPI command will NOT prevent an invalid W
//! Modifies MODE register data to maintain device operation according to
//! preselected mode(s) (RX_CRC_EN, WLENGTH, etc.).
//! \fn uint16_t enforce_selected_device_mode(uint16_t data)
//! \param data uint16_t register data.
//! \return uint16_t modified register data.
uint16_t enforce_selected_device_modes(uint16_t data)
// Enforce RX_CRC_EN setting
// When writing to the MODE register, ensure RX_CRC_EN bit is ALWAYS set
data |= MODE_RX_CRC_EN_ENABLED;
#else
// When writing to the MODE register, ensure RX_CRC_EN bit is NEVER set
data &= ~MODE_RX_CRC_EN_ENABLED;
#endif // ENABLE_CRC_IN
// Enforce WLENGH setting
#ifdef WORD_LENGTH_24BIT
// When writing to the MODE register, ensure WLENGTH bits are ALWAYS set to 01b
data = (data & ~MODE_WLENGTH_MASK) | MODE_WLENGTH_24BIT;
#elif defined WORD_LENGTH_32BIT_SIGN_EXTEND
// When writing to the MODE register, ensure WLENGH bits are ALWAYS set to 11b
data = (data & ~MODE_WLENGTH_MASK) | MODE_WLENGTH_32BIT_MSB_SIGN_EXT;
#elif defined WORD_LENGTH_32BIT_ZERO_PADDED
// When writing to the MODE register, ensure WLENGH bits are ALWAYS set to 10b
data = (data & ~MODE_WLENGTH_MASK) | MODE_WLENGTH_32BIT_LSB_ZEROES;
#elif defined WORD_LENGTH_16BIT_TRUNCATED
// When writing to the MODE register, ensure WLENGH bits are ALWAYS set to 00b
data = (data & ~MODE_WLENGTH_MASK) | MODE_WLENGTH_16BIT;
#endif
// Enforce DRDY_FMT setting
#ifdef DRDY_FMT_PULSE
// When writing to the MODE register, ensure DRDY_FMT bit is ALWAYS set
data = (data & ~MODE_DRDY_FMT_MASK) | MODE_DRDY_FMT_NEG_PULSE_FIXED_WIDTH;
#else
// When writing to the MODE register, ensure DRDY_FMT bit is NEVER set
data = (data & ~MODE_DRDY_FMT_MASK) | MODE_DRDY_FMT_LOGIC_LOW;
#endif
// Enforce CRC_TYPE setting
#ifdef CRC_CCITT
// When writing to the MODE register, ensure CRC_TYPE bit is NEVER set
data = (data & ~STATUS_CRC_TYPE_MASK) | STATUS_CRC_TYPE_16BIT_CCITT;
#elif defined CRC_ANSI
// When writing to the MODE register, ensure CRC_TYPE bit is ALWAYS set
data = (data & ~STATUS_CRC_TYPE_MASK) | STATUS_CRC_TYPE_16BIT_ANSI;
#endif
// Return modified register data
return data;
//! Builds SPI TX data arrays according to number of opcodes provided and
//! currently programmed device word length.
//! \fn uint8_t buildSPIarray(const uint16_t opcodeArray[], uint8_t numberOpcodes, uint8_t byteArray[])
//! \param opcodeArray[] pointer to an array of 16-bit opcodes to use in the SPI command.
//! \param numberOpcodes the number of opcodes provided in opcodeArray[].
//! \param byteArray[] pointer to an array of 8-bit SPI bytes to send to the device.
//! NOTE: The calling function must ensure it reserves sufficient memory for byteArray[]!
//! \return number of bytes added to byteArray[].
* Frame size = opcode word(s) + optional CRC word
* Number of bytes per word = 2, 3, or 4
* Total bytes = bytes per word * number of words
uint8_t numberWords = numberOpcodes + (SPI_CRC_ENABLED ? 1 : 0);
uint8_t bytesPerWord = getWordByteLength();
uint8_t numberOfBytes = numberWords * bytesPerWord;
int i;
for (i = 0; i < numberOpcodes; i++)
// NOTE: Be careful not to accidentally overflow the array here.
// The array and opcodes are defined in the calling function, so
// we are trusting that no mistakes were made in the calling function!
byteArray[(i*bytesPerWord) + 0] = upperByte(opcodeArray[i]);
byteArray[(i*bytesPerWord) + 1] = lowerByte(opcodeArray[i]);
// Calculate CRC and put it into TX array
uint16_t crcWord = calculateCRC(&byteArray[0], numberOfBytes, 0xFFFF);
byteArray[(i*bytesPerWord) + 0] = upperByte(crcWord);
byteArray[(i*bytesPerWord) + 1] = lowerByte(crcWord);
#endif
return numberOfBytes;
//! Getter function to access registerMap array from outside of this module.
//! \fn uint16_t getRegisterValue(uint8_t address)
//! NOTE: The internal registerMap arrays stores the last know register value,
//! since the last read or write operation to that register. This function
//! does not communicate with the device to retrieve the current register value.
//! For the most up-to-date register data or retrieving the value of a hardware
//! controlled register, it is recommend to use readSingleRegister() to read the
//! current register value.
//! \return unsigned 16-bit register value.
return registerMap[address];
//! Returns the ADS131M0x configured word length used for SPI communication.
//! \fn uint8_t getWordByteLength(void)
//! NOTE: It is important that the MODE register value stored in registerMap[]
//! remains in sync with the device. If these values get out of sync then SPI
//! communication may fail!
//! \return SPI word byte length (2, 3, or 4)
return wlength_byte_values[WLENGTH];
// Helper functions
//! Takes a 16-bit word and returns the most-significant byte.
//! \fn uint8_t upperByte(uint16_t uint16_Word)
//! \param temp_word is the original 16-bit word.
//! \return 8-bit most-significant byte.
uint8_t msByte;
msByte = (uint8_t) ((uint16_Word >> 8) & 0x00FF);
return msByte;
//! Takes a 16-bit word and returns the least-significant byte.
//! \fn uint8_t lowerByte(uint16_t uint16_Word)
//! \return 8-bit least-significant byte.
uint8_t lsByte;
lsByte = (uint8_t) (uint16_Word & 0x00FF);
return lsByte;
//! Takes two 8-bit words and returns a concatenated 16-bit word.
//! \fn uint16_t combineBytes(uint8_t upperByte, uint8_t lowerByte)
//! \param upperByte is the 8-bit value that will become the MSB of the 16-bit word.
//! \param lowerByte is the 8-bit value that will become the LSB of the 16-bit word.
//! \return concatenated 16-bit word.
uint16_t combinedValue;
combinedValue = ((uint16_t) upperByte << 8) | ((uint16_t) lowerByte);
return combinedValue;
//! Sends SPI byte array on MOSI pin and captures MISO data to a byte array.
//! \fn void spiSendReceiveArrays(const uint8_t dataTx[], uint8_t dataRx[], const uint8_t byteLength)
//! \param const uint8_t dataTx[] byte array of SPI data to send on MOSI.
//! \param uint8_t dataRx[] byte array of SPI data captured on MISO.
//! \param uint8_t byteLength number of bytes to send & receive.
//! NOTE: Make sure 'dataTx[]' and 'dataRx[]' contain at least as many bytes of data,
//! as indicated by 'byteLength'.
//! \return None.
* This function should send and receive multiple bytes over the SPI.
* A typical SPI send/receive sequence may look like the following:
* 1) Make sure SPI receive buffer is empty
* 2) Set the /CS pin low (if controlled by GPIO)
* 3) Send command bytes to SPI transmit buffer
* 4) Wait for SPI receive interrupt
* 5) Retrieve data from SPI receive buffer
* 6) Set the /CS pin high (if controlled by GPIO)
// Require that dataTx and dataRx are not NULL pointers
assert(dataTx && dataRx);
// Set the nCS pin LOW
setCS(LOW);
// Send all dataTx[] bytes on MOSI, and capture all MISO bytes in dataRx[]
int i;
for (i = 0; i < byteLength; i++)
dataRx[i] = spiSendReceiveByte(dataTx[i]);
// Set the nCS pin HIGH
setCS(HIGH);
//! Controls the state of the /CS GPIO pin.
//! \fn void setCS(const bool state)
//! \param state boolean indicating which state to set the /CS pin (0=low, 1=high)
//! \return None.
// td(CSSC) delay
if(state) { SysCtlDelay(2); }
uint8_t value = (uint8_t) (state ? nCS_PIN : 0);
MAP_GPIOPinWrite(nCS_PORT, nCS_PIN, value);
// td(SCCS) delay
if(!state) { SysCtlDelay(2); }
//! Sends SPI byte on MOSI pin and captures MISO return byte value.
//! \fn uint8_t spiSendReceiveByte(const uint8_t dataTx)
//! \param const uint8_t dataTx data byte to send on MOSI pin.
//! NOTE: This function is called by spiSendReceiveArrays(). If it is called
//! directly, then the /CS pin must also be directly controlled.
//! \return Captured MISO response byte.
* This function should send and receive single bytes over the SPI.
* NOTE: This function does not control the /CS pin to allow for
* more programming flexibility.
// Remove any residual or old data from the receive FIFO
uint32_t junk;
while (SSIDataGetNonBlocking(SSI_BASE_ADDR, &junk));
// SSI TX & RX
uint8_t dataRx;
MAP_SSIDataPut(SSI_BASE_ADDR, (uint32_t) dataTx);
MAP_SSIDataGet(SSI_BASE_ADDR, (uint32_t *) &dataRx);
return dataRx;
//! Reads the contents of a single register at the specified address.
//! \fn uint16_t readSingleRegister(uint8_t address)
//! \param address is the 8-bit address of the register to read.
//! \return Returns the 8-bit register read result.
uint8_t dataTx[8] = { 0 }; // 2 words, up to 4 bytes each = 8 bytes maximum
#else
uint8_t dataTx[4] = { 0 }; // 1 word, up to 4 bytes long = 4 bytes maximum
uint8_t dataRx[4] = { 0 };
#endif
uint16_t opcode = OPCODE_RREG | (((uint16_t) address) << 7);
uint8_t numberOfBytes = buildSPIarray(&opcode, 1, dataTx);
// [FRAME 1] Send RREG command
// [FRAME 2] Send NULL command to retrieve the register data
registerMap[address] = sendCommand(OPCODE_NULL);
//! Sends the specified SPI command to the ADC (NULL, STANDBY, or WAKEUP).
//! \fn uint16_t sendCommand(uint16_t opcode)
//! \param opcode SPI command byte.
//! NOTE: Other commands have their own dedicated functions to support
//! additional functionality.
//! \return ADC response byte (typically the STATUS byte).
/* Assert if this function is used to send any of the following opcodes */
assert(OPCODE_RREG != opcode); /* Use "readSingleRegister()" */
assert(OPCODE_WREG != opcode); /* Use "writeSingleRegister()" */
assert(OPCODE_LOCK != opcode); /* Use "lockRegisters()" */
assert(OPCODE_UNLOCK != opcode); /* Use "unlockRegisters()" */
assert(OPCODE_RESET != opcode); /* Use "resetDevice()" */
#else
#endif
/* Set the nCS pin LOW */
setCS(LOW);
// Send the opcode (and crc word, if enabled)
int i;
for (i = 0; i < numberOfBytes; i++)
/* Set the nCS pin HIGH */
setCS(HIGH);
// Combine response bytes and return as a 16-bit word
uint16_t adcResponse = combineBytes(dataRx[0], dataRx[1]);
return adcResponse;
On line 192, stepping at it, shows the code running, but then after pausing, I see that the code gets to an infinite loop inside another code 'startup_mspe401y_ccs.c', at line 340, in the code below.
* Copyright (C) 2017 Texas Instruments Incorporated - http://www.ti.com/
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <stdint.h>
/* External declaration for the reset handler that is to be called when the */
/* processor is started */
extern void _c_int00(void);
/* External declaration for system initialization function */
extern void SystemInit(void);
/* Linker variable that marks the top of the stack. */
extern uint32_t __STACK_TOP;
/* Forward declaration of the default fault handlers. */
void Default_Handler (void) __attribute__((weak));
extern void Reset_Handler (void) __attribute__((weak));
/* Cortex-M4 Processor Exceptions */
extern void NMI_Handler (void) __attribute__((weak, alias("Default_Handler")));
extern void HardFault_Handler (void) __attribute__((weak, alias("Default_Handler")));
extern void MemManage_Handler (void) __attribute__((weak, alias("Default_Handler")));
extern void BusFault_Handler (void) __attribute__((weak, alias("Default_Handler")));
extern void UsageFault_Handler (void) __attribute__((weak, alias("Default_Handler")));
extern void SVC_Handler (void) __attribute__((weak, alias("Default_Handler")));
extern void DebugMon_Handler (void) __attribute__((weak, alias("Default_Handler")));
extern void PendSV_Handler (void) __attribute__((weak, alias("Default_Handler")));
extern void SysTick_Handler (void) __attribute__((weak, alias("Default_Handler")));
/* device specific interrupt handler */
extern void GPIOA_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOB_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOC_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOD_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOE_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void UART0_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void UART1_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void SSI0_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void I2C0_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void PWM0_FAULT_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void PWM0_0_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void PWM0_1_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void PWM0_2_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void QEI0_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void ADC0SS0_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void ADC0SS1_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void ADC0SS2_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void ADC0SS3_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void WATCHDOG_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void TIMER0A_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void TIMER0B_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void TIMER1A_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void TIMER1B_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void TIMER2A_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void TIMER2B_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void COMP0_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void COMP1_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void COMP2_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void SYSCTL_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void FLASH_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOF_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOG_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOH_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void UART2_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void SSI1_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void TIMER3A_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void TIMER3B_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void I2C1_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void CAN0_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void CAN1_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void EMAC0_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void HIBERNATE_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void USB0_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void PWM0_3_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void UDMA_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void UDMAERR_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void ADC1SS0_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void ADC1SS1_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void ADC1SS2_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void ADC1SS3_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void EPI0_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOJ_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOK_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOL_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void SSI2_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void SSI3_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void UART3_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void UART4_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void UART5_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void UART6_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void UART7_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void I2C2_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void I2C3_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void TIMER4A_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void TIMER4B_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void TIMER5A_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void TIMER5B_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void SYSEXC_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void I2C4_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void I2C5_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOM_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPION_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void TAMPER0_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOP0_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOP1_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOP2_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOP3_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOP4_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOP5_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOP6_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOP7_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOQ0_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOQ1_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOQ2_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOQ3_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOQ4_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOQ5_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOQ6_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void GPIOQ7_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void SHA0_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void AES0_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void DES0_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void TIMER6A_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void TIMER6B_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void TIMER7A_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void TIMER7B_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void I2C6_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void I2C7_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void I2C8_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
extern void I2C9_IRQHandler (void) __attribute__((weak, alias("Default_Handler")));
/* Interrupt vector table. Note that the proper constructs must be placed on this to */
/* ensure that it ends up at physical address 0x0000.0000 or at the start of */
/* the program if located at a start address other than 0. */
#ifdef __TI_ARM__
#pragma RETAIN(interruptVectors)
#pragma DATA_SECTION(interruptVectors, ".intvecs")
void (* const interruptVectors[])(void) =
#elif defined(__ti_version__)
void (* const interruptVectors[])(void) __attribute((used)) __attribute__((section (".intvecs"))) =
#else
#error "Compiler is not supported!"
#endif
(void (*)(void))((uint32_t)&__STACK_TOP),
/* The initial stack pointer */
Reset_Handler, /* The reset handler */
NMI_Handler, /* The NMI handler */
HardFault_Handler, /* The hard fault handler */
MemManage_Handler, /* The MPU fault handler */
BusFault_Handler, /* The bus fault handler */
UsageFault_Handler, /* The usage fault handler */
0, /* Reserved */
0, /* Reserved */
0, /* Reserved */
0, /* Reserved */
SVC_Handler, /* SVCall handler */
DebugMon_Handler, /* Debug monitor handler */
0, /* Reserved */
PendSV_Handler, /* The PendSV handler */
SysTick_Handler, /* The SysTick handler */
GPIOA_IRQHandler, /* GPIO Port A */
GPIOB_IRQHandler, /* GPIO Port B */
GPIOC_IRQHandler, /* GPIO Port C */
GPIOD_IRQHandler, /* GPIO Port D */
GPIOE_IRQHandler, /* GPIO Port E */
UART0_IRQHandler, /* UART0 Rx and Tx */
UART1_IRQHandler, /* UART1 Rx and Tx */
SSI0_IRQHandler, /* SSI0 Rx and Tx */
I2C0_IRQHandler, /* I2C0 Master and Slave */
PWM0_FAULT_IRQHandler, /* PWM Fault */
PWM0_0_IRQHandler, /* PWM Generator 0 */
PWM0_1_IRQHandler, /* PWM Generator 1 */
PWM0_2_IRQHandler, /* PWM Generator 2 */
QEI0_IRQHandler, /* Quadrature Encoder 0 */
ADC0SS0_IRQHandler, /* ADC Sequence 0 */
ADC0SS1_IRQHandler, /* ADC Sequence 1 */
ADC0SS2_IRQHandler, /* ADC Sequence 2 */
ADC0SS3_IRQHandler, /* ADC Sequence 3 */
WATCHDOG_IRQHandler, /* Watchdog timer */
TIMER0A_IRQHandler, /* Timer 0 subtimer A */
TIMER0B_IRQHandler, /* Timer 0 subtimer B */
TIMER1A_IRQHandler, /* Timer 1 subtimer A */
TIMER1B_IRQHandler, /* Timer 1 subtimer B */
TIMER2A_IRQHandler, /* Timer 2 subtimer A */
TIMER2B_IRQHandler, /* Timer 2 subtimer B */
COMP0_IRQHandler, /* Analog Comparator 0 */
COMP1_IRQHandler, /* Analog Comparator 1 */
COMP2_IRQHandler, /* Analog Comparator 2 */
SYSCTL_IRQHandler, /* System Control */
FLASH_IRQHandler, /* FLASH Control */
GPIOF_IRQHandler, /* GPIO Port F */
GPIOG_IRQHandler, /* GPIO Port G */
GPIOH_IRQHandler, /* GPIO Port H */
UART2_IRQHandler, /* UART2 Rx and Tx */
SSI1_IRQHandler, /* SSI1 Rx and Tx */
TIMER3A_IRQHandler, /* Timer 3 subtimer A */
TIMER3B_IRQHandler, /* Timer 3 subtimer B */
I2C1_IRQHandler, /* I2C1 Master and Slave */
CAN0_IRQHandler, /* CAN0 */
CAN1_IRQHandler, /* CAN1 */
EMAC0_IRQHandler, /* Ethernet */
HIBERNATE_IRQHandler, /* Hibernate */
USB0_IRQHandler, /* USB0 */
PWM0_3_IRQHandler, /* PWM Generator 3 */
UDMA_IRQHandler, /* uDMA Software Transfer */
UDMAERR_IRQHandler, /* uDMA Error */
ADC1SS0_IRQHandler, /* ADC1 Sequence 0 */
ADC1SS1_IRQHandler, /* ADC1 Sequence 1 */
ADC1SS2_IRQHandler, /* ADC1 Sequence 2 */
ADC1SS3_IRQHandler, /* ADC1 Sequence 3 */
EPI0_IRQHandler, /* External Bus Interface 0 */
GPIOJ_IRQHandler, /* GPIO Port J */
GPIOK_IRQHandler, /* GPIO Port K */
GPIOL_IRQHandler, /* GPIO Port L */
SSI2_IRQHandler, /* SSI2 Rx and Tx */
SSI3_IRQHandler, /* SSI3 Rx and Tx */
UART3_IRQHandler, /* UART3 Rx and Tx */
UART4_IRQHandler, /* UART4 Rx and Tx */
UART5_IRQHandler, /* UART5 Rx and Tx */
UART6_IRQHandler, /* UART6 Rx and Tx */
UART7_IRQHandler, /* UART7 Rx and Tx */
I2C2_IRQHandler, /* I2C2 Master and Slave */
I2C3_IRQHandler, /* I2C3 Master and Slave */
TIMER4A_IRQHandler, /* Timer 4 subtimer A */
TIMER4B_IRQHandler, /* Timer 4 subtimer B */
TIMER5A_IRQHandler, /* Timer 5 subtimer A */
TIMER5B_IRQHandler, /* Timer 5 subtimer B */
SYSEXC_IRQHandler, /* FPU */
0, /* Reserved */
0, /* Reserved */
I2C4_IRQHandler, /* I2C4 Master and Slave */
I2C5_IRQHandler, /* I2C5 Master and Slave */
GPIOM_IRQHandler, /* GPIO Port M */
GPION_IRQHandler, /* GPIO Port N */
0, /* Reserved */
TAMPER0_IRQHandler, /* Tamper */
GPIOP0_IRQHandler, /* GPIO Port P(Summary or P0)*/
GPIOP1_IRQHandler, /* GPIO Port P1 */
GPIOP2_IRQHandler, /* GPIO Port P2 */
GPIOP3_IRQHandler, /* GPIO Port P3 */
GPIOP4_IRQHandler, /* GPIO Port P4 */
GPIOP5_IRQHandler, /* GPIO Port P5 */
GPIOP6_IRQHandler, /* GPIO Port P6 */
GPIOP7_IRQHandler, /* GPIO Port P7 */
GPIOQ0_IRQHandler, /* GPIO Port Q(Summary or Q0)*/
GPIOQ1_IRQHandler, /* GPIO Port Q1 */
GPIOQ2_IRQHandler, /* GPIO Port Q2 */
GPIOQ3_IRQHandler, /* GPIO Port Q3 */
GPIOQ4_IRQHandler, /* GPIO Port Q4 */
GPIOQ5_IRQHandler, /* GPIO Port Q5 */
GPIOQ6_IRQHandler, /* GPIO Port Q6 */
GPIOQ7_IRQHandler, /* GPIO Port Q7 */
0, /* Reserved */
0, /* Reserved */
SHA0_IRQHandler, /* SHA/MD5 0 */
AES0_IRQHandler, /* AES 0 */
DES0_IRQHandler, /* DES3DES 0 */
0, /* Reserved */
TIMER6A_IRQHandler, /* Timer 6 subtimer A */
TIMER6B_IRQHandler, /* Timer 6 subtimer B */
TIMER7A_IRQHandler, /* Timer 7 subtimer A */
TIMER7B_IRQHandler, /* Timer 7 subtimer B */
I2C6_IRQHandler, /* I2C6 Master and Slave */
I2C7_IRQHandler, /* I2C7 Master and Slave */
0, /* Reserved */
0, /* Reserved */
0, /* Reserved */
0, /* Reserved */
0, /* Reserved */
I2C8_IRQHandler, /* I2C8 Master and Slave */
I2C9_IRQHandler, /* I2C9 Master and Slave */
0, /* Reserved */
0, /* Reserved */
0, /* Reserved */
/* This is the code that gets called when the processor first starts execution */
/* following a reset event. Only the absolutely necessary set is performed, */
/* after which the application supplied entry() routine is called. Any fancy */
/* actions (such as making decisions based on the reset cause register, and */
/* resetting the bits in that register) are left solely in the hands of the */
/* application. */
void Reset_Handler(void)
SystemInit();
/* Jump to the CCS C Initialization Routine. */
__asm(" .global _c_int00\n"
" b.w _c_int00");
/* This is the code that gets called when the processor receives an unexpected */
/* interrupt. This simply enters an infinite loop, preserving the system state */
/* for examination by a debugger. */
void Default_Handler(void)
/* Fault trap exempt from ULP advisor */
#ifdef __TI_ARM__
#pragma diag_push
#pragma CHECK_ULP("-2.1")
#endif
/* Enter an infinite loop. */
while(1)
#ifdef __TI_ARM__
#pragma diag_pop
#endif
Am I doing something wrong?I am also attaching the .h file here, if anyone needs to check with a launchpad. Please help.
#ifndef ADS131M0X_H_
#define ADS131M0X_H_
// Standard libraries
#include <assert.h>
// Select the device variant to use...
#define CHANNEL_COUNT (8) // ADS131M08 -> 8 Channels
#if ((CHANNEL_COUNT < 1) || (CHANNEL_COUNT > 8))
#error Invalid channel count configured in 'ads131m0x.h'.
#endif
// Select the desired MODE register settings...
// NOTE: These settings will be enforced and not modifiable during runtime!
/* Pick one (and only one) mode to use... */
//#define WORD_LENGTH_16BIT_TRUNCATED
#define WORD_LENGTH_24BIT
//#define WORD_LENGTH_32BIT_SIGN_EXTEND
//#define WORD_LENGTH_32BIT_ZERO_PADDED
/* Enable this define statement to use the DRDY pulse format... */
#define DRDY_FMT_PULSE
/* Enable this define statement to use CRC on DIN... */
//#define ENABLE_CRC_IN
/* Select CRC type */
#define CRC_CCITT
//#define CRC_ANSI
/* Disable assertions when not in the CCS "Debug" configuration */
#ifndef _DEBUG
#define NDEBUG
#endif
// Validation
// Throw an error if no WORD_LENGTH mode was selected above
#if !defined WORD_LENGTH_16BIT_TRUNCATED && \
!defined WORD_LENGTH_24BIT && \
!defined WORD_LENGTH_32BIT_SIGN_EXTEND && \
!defined WORD_LENGTH_32BIT_ZERO_PADDED
#error Must define at least one WORD_LENGTH mode
#endif
// Throw an error if none or both CRC types are selected
#if !defined CRC_CCITT && !defined CRC_ANSI
#error Must define at least one CRC type
#endif
#if defined CRC_CCITT && defined CRC_ANSI
#error Must define only one CRC type
#endif
// Constants
#define NUM_REGISTERS ((uint8_t) 64)
// SPI command opcodes
#define OPCODE_NULL ((uint16_t) 0x0000)
#define OPCODE_RESET ((uint16_t) 0x0011)
#define OPCODE_RREG ((uint16_t) 0xA000)
#define OPCODE_WREG ((uint16_t) 0x6000)
#define OPCODE_STANDBY ((uint16_t) 0x0022)
#define OPCODE_WAKEUP ((uint16_t) 0x0033)
#define OPCODE_LOCK ((uint16_t) 0x0555)
#define OPCODE_UNLOCK ((uint16_t) 0x0655)
// Register definitions
/* NOTE: Whenever possible, macro names (defined below) were derived from
* datasheet defined names; however, updates to documentation may cause
* mismatches between names defined here in example code from those shown
* in the device datasheet.
/* Register 0x00 (ID) definition - READ ONLY
* | Bit 15 | Bit 14 | Bit 13 | Bit 12 | Bit 11 | Bit 10 | Bit 9 | Bit 8 | Bit 7 | Bit 6 | Bit 5 | Bit 4 | Bit 3 | Bit 2 | Bit 1 | Bit 0 |
* | RESERVED[3:0] | CHANCNT[3:0] | REVID[7:0] |
/* ID register address & default value */
#define ID_ADDRESS ((uint8_t) 0x00)
#define ID_DEFAULT ((uint16_t) 0x2000 | (CHANNEL_COUNT << 8)) // NOTE: May change with future device revisions!
/* RESERVED field mask */
#define ID_RESERVED_MASK ((uint16_t) 0xF000)
/* CHANCNT field mask & values */
#define ID_CHANCNT_MASK ((uint16_t) 0x0F00)
#define ID_CHANCNT_4CH ((uint16_t) 0x0004 << 8)
#define ID_CHANCNT_6CH ((uint16_t) 0x0006 << 8)
#define ID_CHANCNT_8CH ((uint16_t) 0x0008 << 8)
/* REVID field mask & values */
#define ID_REVID_MASK ((uint16_t) 0x00FF)
#define ID_REVID_REVA ((uint16_t) 0x0000 << 0) // DEFAULT
/* Register 0x01 (STATUS) definition - READ ONLY
* | LOCK | F_RESYNC | REG_MAP | CRC_ERR | CRC_TYPE | RESET | WLENGTH[1:0] | DRDY7 | DRDY6 | DRDY5 | DRDY4 | DRDY3 | DRDY2 | DRDY1 | DRDY0 |
* NOTE 1: Bits 0 through 7 are hardware controlled. Reading these values multiple times may return different results.
* NOTE 2: Bits 0 through 4 are RESERVED on the ADS131M04. These bits will always read 0.
/* STATUS register address & default value */
#define STATUS_ADDRESS ((uint8_t) 0x01)
#define STATUS_DEFAULT ((uint16_t) 0x0500)
/* LOCK field mask & values */
#define STATUS_LOCK_MASK ((uint16_t) 0x8000)
#define STATUS_LOCK_UNLOCKED ((uint16_t) 0x0000 << 15) // DEFAULT
#define STATUS_LOCK_LOCKED ((uint16_t) 0x0001 << 15)
/* F_RESYNC field mask & values */
#define STATUS_F_RESYNC_MASK ((uint16_t) 0x4000)
#define STATUS_F_RESYNC_NO_FAULT ((uint16_t) 0x0000 << 14) // DEFAULT
#define STATUS_F_RESYNC_FAULT ((uint16_t) 0x0001 << 14)
/* REG_MAP field mask & values */
#define STATUS_REG_MAP_MASK ((uint16_t) 0x2000)
#define STATUS_REG_MAP_NO_CHANGE_CRC ((uint16_t) 0x0000 << 13) // DEFAULT
#define STATUS_REG_MAP_CHANGED_CRC ((uint16_t) 0x0001 << 13)
/* CRC_ERR field mask & values */
#define STATUS_CRC_ERR_MASK ((uint16_t) 0x1000)
#define STATUS_CRC_ERR_NO_CRC_ERROR ((uint16_t) 0x0000 << 12) // DEFAULT
#define STATUS_CRC_ERR_INPUT_CRC_ERROR ((uint16_t) 0x0001 << 12)
/* CRC_TYPE field mask & values */
#define STATUS_CRC_TYPE_MASK ((uint16_t) 0x0800)
#define STATUS_CRC_TYPE_16BIT_CCITT ((uint16_t) 0x0000 << 11) // DEFAULT
#define STATUS_CRC_TYPE_16BIT_ANSI ((uint16_t) 0x0001 << 11)
/* RESET field mask & values */
#define STATUS_RESET_MASK ((uint16_t) 0x0400)
#define STATUS_RESET_NO_RESET ((uint16_t) 0x0000 << 10)
#define STATUS_RESET_RESET_OCCURRED ((uint16_t) 0x0001 << 10) // DEFAULT
/* WLENGTH field mask & values */
#define STATUS_WLENGTH_MASK ((uint16_t) 0x0300)
#define STATUS_WLENGTH_16BIT ((uint16_t) 0x0000 << 8)
#define STATUS_WLENGTH_24BIT ((uint16_t) 0x0001 << 8) // DEFAULT
#define STATUS_WLENGTH_32BIT_LSB_ZEROES ((uint16_t) 0x0002 << 8)
#define STATUS_WLENGTH_32BIT_MSB_SIGN_EXT ((uint16_t) 0x0003 << 8)
/* DRDY7 field mask & values */
#define STATUS_DRDY7_MASK ((uint16_t) 0x0080)
#define STATUS_DRDY7_NO_NEW_DATA ((uint16_t) 0x0000 << 7)
#define STATUS_DRDY7_NEW_DATA ((uint16_t) 0x0001 << 7)
#endif
/* DRDY6 field mask & values */
#define STATUS_DRDY6_MASK ((uint16_t) 0x0040)
#define STATUS_DRDY6_NO_NEW_DATA ((uint16_t) 0x0000 << 6)
#define STATUS_DRDY6_NEW_DATA ((uint16_t) 0x0001 << 6)
#endif
/* DRDY5 field mask & values */
#define STATUS_DRDY5_MASK ((uint16_t) 0x0020)
#define STATUS_DRDY5_NO_NEW_DATA ((uint16_t) 0x0000 << 5)
#define STATUS_DRDY5_NEW_DATA ((uint16_t) 0x0001 << 5)
#endif
/* DRDY4 field mask & values */
#define STATUS_DRDY4_MASK ((uint16_t) 0x0010)
#define STATUS_DRDY4_NO_NEW_DATA ((uint16_t) 0x0000 << 4)
#define STATUS_DRDY4_NEW_DATA ((uint16_t) 0x0001 << 4)
#endif
/* DRDY3 field mask & values */
#define STATUS_DRDY3_MASK ((uint16_t) 0x0008)
#define STATUS_DRDY3_NO_NEW_DATA ((uint16_t) 0x0000 << 3)
#define STATUS_DRDY3_NEW_DATA ((uint16_t) 0x0001 << 3)
#endif
/* DRDY2 field mask & values */
#define STATUS_DRDY2_MASK ((uint16_t) 0x0004)
#define STATUS_DRDY2_NO_NEW_DATA ((uint16_t) 0x0000 << 2)
#define STATUS_DRDY2_NEW_DATA ((uint16_t) 0x0001 << 2)
#endif
/* DRDY1 field mask & values */
#define STATUS_DRDY1_MASK ((uint16_t) 0x0002)
#define STATUS_DRDY1_NO_NEW_DATA ((uint16_t) 0x0000 << 1)
#define STATUS_DRDY1_NEW_DATA ((uint16_t) 0x0001 << 1)
#endif
/* DRDY0 field mask & values */
#define STATUS_DRDY0_MASK ((uint16_t) 0x0001)
#define STATUS_DRDY0_NO_NEW_DATA ((uint16_t) 0x0000 << 0)
#define STATUS_DRDY0_NEW_DATA ((uint16_t) 0x0001 << 0)
/* Register 0x02 (MODE) definition
* | RESERVED0[1:0] | REG_CRC_EN | RX_CRC_EN | CRC_TYPE | RESET | WLENGTH[1:0] | RESERVED1[2:0] | TIMEOUT | DRDY_SEL[1:0] | DRDY_HiZ | DRDY_FMT |
/* MODE register address & default value */
#define MODE_ADDRESS ((uint8_t) 0x02)
#define MODE_DEFAULT ((uint16_t) 0x0510)
/* RESERVED0 field mask */
#define MODE_RESERVED0_MASK ((uint16_t) 0xC000)
/* REG_CRC_EN field mask & values */
#define MODE_REG_CRC_EN_MASK ((uint16_t) 0x2000)
#define MODE_REG_CRC_EN_DISABLED ((uint16_t) 0x0000 << 13) // DEFAULT
#define MODE_REG_CRC_EN_ENABLED ((uint16_t) 0x0001 << 13)
/* RX_CRC_EN field mask & values */
#define MODE_RX_CRC_EN_MASK ((uint16_t) 0x1000)
#define MODE_RX_CRC_EN_DISABLED ((uint16_t) 0x0000 << 12) // DEFAULT
#define MODE_RX_CRC_EN_ENABLED ((uint16_t) 0x0001 << 12)
#define MODE_CRC_TYPE_MASK ((uint16_t) 0x0800)
#define MODE_CRC_TYPE_16BIT_CCITT ((uint16_t) 0x0000 << 11) // DEFAULT
#define MODE_CRC_TYPE_16BIT_ANSI ((uint16_t) 0x0001 << 11)
#define MODE_RESET_MASK ((uint16_t) 0x0400)
#define MODE_RESET_NO_RESET ((uint16_t) 0x0000 << 10)
#define MODE_RESET_RESET_OCCURRED ((uint16_t) 0x0001 << 10) // DEFAULT
#define MODE_WLENGTH_MASK ((uint16_t) 0x0300)
#define MODE_WLENGTH_16BIT ((uint16_t) 0x0000 << 8)
#define MODE_WLENGTH_24BIT ((uint16_t) 0x0001 << 8)
#define MODE_WLENGTH_32BIT_LSB_ZEROES ((uint16_t) 0x0002 << 8)
#define MODE_WLENGTH_32BIT_MSB_SIGN_EXT ((uint16_t) 0x0003 << 8)
/* RESERVED1 field mask */
#define MODE_RESERVED1_MASK ((uint16_t) 0x00E0)
/* TIMEOUT field mask & values */
#define MODE_TIMEOUT_MASK ((uint16_t) 0x0010)
#define MODE_TIMEOUT_DISABLED ((uint16_t) 0x0000 << 4)
#define MODE_TIMEOUT_ENABLED ((uint16_t) 0x0001 << 4) // DEFAULT
/* DRDY_SEL field mask & values */
#define MODE_DRDY_SEL_MASK ((uint16_t) 0x000C)
#define MODE_DRDY_SEL_MOST_LAGGING ((uint16_t) 0x0000 << 2) // DEFAULT
#define MODE_DRDY_SEL_LOGIC_OR ((uint16_t) 0x0001 << 2)
#define MODE_DRDY_SEL_MOST_LEADING ((uint16_t) 0x0002 << 2) // Alternative value: ((uint16_t) 0x0003 << 2)
/* DRDY_HiZ field mask & values */
#define MODE_DRDY_HiZ_MASK ((uint16_t) 0x0002)
#define MODE_DRDY_HiZ_LOGIC_HIGH ((uint16_t) 0x0000 << 1) // DEFAULT
#define MODE_DRDY_HiZ_HIGH_IMPEDANCE ((uint16_t) 0x0001 << 1)
/* DRDY_FMT field mask & values */
#define MODE_DRDY_FMT_MASK ((uint16_t) 0x0001)
#define MODE_DRDY_FMT_LOGIC_LOW ((uint16_t) 0x0000 << 0) // DEFAULT
#define MODE_DRDY_FMT_NEG_PULSE_FIXED_WIDTH ((uint16_t) 0x0001 << 0)
/* Register 0x03 (CLOCK) definition
* | CH7_EN | CH6_EN | CH5_EN | CH4_EN | CH3_EN | CH2_EN | CH1_EN | CH0_EN | RESERVED[2:0] | OSR[2:0] | PWR[1:0] |
* NOTE 1: Bits 12 through 15 are RESERVED on the ADS131M04.
/* CLOCK register address & default value */
#define CLOCK_ADDRESS ((uint8_t) 0x03)
#if (CHANNEL_COUNT == 8)
#define CLOCK_DEFAULT ((uint16_t) 0xFF0E)
#endif
#if (CHANNEL_COUNT == 7)
#define CLOCK_DEFAULT ((uint16_t) 0x7F0E)
#endif
#if (CHANNEL_COUNT == 6)
#define CLOCK_DEFAULT ((uint16_t) 0x3F0E)
#endif
#if (CHANNEL_COUNT == 5)
#define CLOCK_DEFAULT ((uint16_t) 0x1F0E)
#endif
#if (CHANNEL_COUNT == 4)
#define CLOCK_DEFAULT ((uint16_t) 0x0F0E)
#endif
#if (CHANNEL_COUNT == 3)
#define CLOCK_DEFAULT ((uint16_t) 0x070E)
#endif
#if (CHANNEL_COUNT == 2)
#define CLOCK_DEFAULT ((uint16_t) 0x030E)
#endif
#if (CHANNEL_COUNT == 1)
#define CLOCK_DEFAULT ((uint16_t) 0x010E)
#endif
/* CH7_EN field mask & values */
#define CLOCK_CH7_EN_MASK ((uint16_t) 0x8000)
#define CLOCK_CH7_EN_DISABLED ((uint16_t) 0x0000 << 15)
#define CLOCK_CH7_EN_ENABLED ((uint16_t) 0x0001 << 15)
#endif
/* CH6_EN field mask & values */
#define CLOCK_CH6_EN_MASK ((uint16_t) 0x4000)
#define CLOCK_CH6_EN_DISABLED ((uint16_t) 0x0000 << 14)
#define CLOCK_CH6_EN_ENABLED ((uint16_t) 0x0001 << 14)
#endif
/* CH5_EN field mask & values */
#define CLOCK_CH5_EN_MASK ((uint16_t) 0x2000)
#define CLOCK_CH5_EN_DISABLED ((uint16_t) 0x0000 << 13)
#define CLOCK_CH5_EN_ENABLED ((uint16_t) 0x0001 << 13)
#endif
/* CH4_EN field mask & values */
#define CLOCK_CH4_EN_MASK ((uint16_t) 0x1000)
#define CLOCK_CH4_EN_DISABLED ((uint16_t) 0x0000 << 12)
#define CLOCK_CH4_EN_ENABLED ((uint16_t) 0x0001 << 12)
#endif
/* CH3_EN field mask & values */
#define CLOCK_CH3_EN_MASK ((uint16_t) 0x0800)
#define CLOCK_CH3_EN_DISABLED ((uint16_t) 0x0000 << 11)
#define CLOCK_CH3_EN_ENABLED ((uint16_t) 0x0001 << 11)
#endif
/* CH2_EN field mask & values */
#define CLOCK_CH2_EN_MASK ((uint16_t) 0x0400)
#define CLOCK_CH2_EN_DISABLED ((uint16_t) 0x0000 << 10)
#define CLOCK_CH2_EN_ENABLED ((uint16_t) 0x0001 << 10)
#endif
/* CH1_EN field mask & values */
#define CLOCK_CH1_EN_MASK ((uint16_t) 0x0200)
#define CLOCK_CH1_EN_DISABLED ((uint16_t) 0x0000 << 9)
#define CLOCK_CH1_EN_ENABLED ((uint16_t) 0x0001 << 9)
#endif
/* CH0_EN field mask & values */
#define CLOCK_CH0_EN_MASK ((uint16_t) 0x0100)
#define CLOCK_CH0_EN_DISABLED ((uint16_t) 0x0000 << 8)
#define CLOCK_CH0_EN_ENABLED ((uint16_t) 0x0001 << 8) // DEFAULT
#define CLOCK_RESERVED_MASK ((uint16_t) 0x00E0)
/* OSR field mask & values */
#define CLOCK_OSR_MASK ((uint16_t) 0x001C)
#define CLOCK_OSR_128 ((uint16_t) 0x0000 << 2)
#define CLOCK_OSR_256 ((uint16_t) 0x0001 << 2)
#define CLOCK_OSR_512 ((uint16_t) 0x0002 << 2)
#define CLOCK_OSR_1024 ((uint16_t) 0x0003 << 2) // DEFAULT
#define CLOCK_OSR_2048 ((uint16_t) 0x0004 << 2)
#define CLOCK_OSR_4096 ((uint16_t) 0x0005 << 2)
#define CLOCK_OSR_8192 ((uint16_t) 0x0006 << 2)
#define CLOCK_OSR_16384 ((uint16_t) 0x0007 << 2)
/* PWR field mask & values */
#define CLOCK_PWR_MASK ((uint16_t) 0x0003)
#define CLOCK_PWR_VLP ((uint16_t) 0x0000 << 0)
#define CLOCK_PWR_LP ((uint16_t) 0x0001 << 0)
#define CLOCK_PWR_HR ((uint16_t) 0x0002 << 0) // DEFAULT, Alternative value: ((uint16_t) 0x0003 << 2)
/* Register 0x04 (GAIN1) definition
* | RESERVED0 | PGAGAIN3[2:0] | RESERVED1 | PGAGAIN2[2:0] | RESERVED2 | PGAGAIN1[2:0] | RESERVED3 | PGAGAIN0[2:0] |
/* GAIN1 register address & default value */
#define GAIN1_ADDRESS ((uint8_t) 0x04)
#define GAIN1_DEFAULT ((uint16_t) 0x0000)
/* RESERVED0 field mask & values */
#define GAIN1_RESERVED0_MASK ((uint16_t) 0x8000)
/* PGAGAIN3 field mask & values */
#define GAIN1_PGAGAIN3_MASK ((uint16_t) 0x7000)
#define GAIN1_PGAGAIN3_1 ((uint16_t) 0x0000 << 12) // DEFAULT
#define GAIN1_PGAGAIN3_2 ((uint16_t) 0x0001 << 12)
#define GAIN1_PGAGAIN3_4 ((uint16_t) 0x0002 << 12)
#define GAIN1_PGAGAIN3_8 ((uint16_t) 0x0003 << 12)
#define GAIN1_PGAGAIN3_16 ((uint16_t) 0x0004 << 12)
#define GAIN1_PGAGAIN3_32 ((uint16_t) 0x0005 << 12)
#define GAIN1_PGAGAIN3_64 ((uint16_t) 0x0006 << 12)
#define GAIN1_PGAGAIN3_128 ((uint16_t) 0x0007 << 12)
/* RESERVED1 field mask & values */
#define GAIN1_RESERVED1_MASK ((uint16_t) 0x0800)
/* PGAGAIN2 field mask & values */
#define GAIN1_PGAGAIN2_MASK ((uint16_t) 0x0700)
#define GAIN1_PGAGAIN2_1 ((uint16_t) 0x0000 << 8) // DEFAULT
#define GAIN1_PGAGAIN2_2 ((uint16_t) 0x0001 << 8)
#define GAIN1_PGAGAIN2_4 ((uint16_t) 0x0002 << 8)
#define GAIN1_PGAGAIN2_8 ((uint16_t) 0x0003 << 8)
#define GAIN1_PGAGAIN2_16 ((uint16_t) 0x0004 << 8)
#define GAIN1_PGAGAIN2_32 ((uint16_t) 0x0005 << 8)
#define GAIN1_PGAGAIN2_64 ((uint16_t) 0x0006 << 8)
#define GAIN1_PGAGAIN2_128 ((uint16_t) 0x0007 << 8)
/* RESERVED2 field mask & values */
#define GAIN1_RESERVED2_MASK ((uint16_t) 0x0080)
/* PGAGAIN1 field mask & values */
#define GAIN1_PGAGAIN1_MASK ((uint16_t) 0x0070)
#define GAIN1_PGAGAIN1_1 ((uint16_t) 0x0000 << 4) // DEFAULT
#define GAIN1_PGAGAIN1_2 ((uint16_t) 0x0001 << 4)
#define GAIN1_PGAGAIN1_4 ((uint16_t) 0x0002 << 4)
#define GAIN1_PGAGAIN1_8 ((uint16_t) 0x0003 << 4)
#define GAIN1_PGAGAIN1_16 ((uint16_t) 0x0004 << 4)
#define GAIN1_PGAGAIN1_32 ((uint16_t) 0x0005 << 4)
#define GAIN1_PGAGAIN1_64 ((uint16_t) 0x0006 << 4)
#define GAIN1_PGAGAIN1_128 ((uint16_t) 0x0007 << 4)
/* RESERVED3 field mask & values */
#define GAIN1_RESERVED3_MASK ((uint16_t) 0x0008)
/* PGAGAIN0 field mask & values */
#define GAIN1_PGAGAIN0_MASK ((uint16_t) 0x0007)
#define GAIN1_PGAGAIN0_1 ((uint16_t) 0x0000 << 0) // DEFAULT
#define GAIN1_PGAGAIN0_2 ((uint16_t) 0x0001 << 0)
#define GAIN1_PGAGAIN0_4 ((uint16_t) 0x0002 << 0)
#define GAIN1_PGAGAIN0_8 ((uint16_t) 0x0003 << 0)
#define GAIN1_PGAGAIN0_16 ((uint16_t) 0x0004 << 0)
#define GAIN1_PGAGAIN0_32 ((uint16_t) 0x0005 << 0)
#define GAIN1_PGAGAIN0_64 ((uint16_t) 0x0006 << 0)
#define GAIN1_PGAGAIN0_128 ((uint16_t) 0x0007 << 0)
/* Register 0x05 (GAIN2) definition
* | RESERVED0 | PGAGAIN7[2:0] | RESERVED1 | PGAGAIN6[2:0] | RESERVED2 | PGAGAIN5[2:0] | RESERVED3 | PGAGAIN4[2:0] |
* NOTE 1: This register is RESERVED on the ADS131M04. Only write 0x0000 to this register.
/* GAIN2 register address & default value */
#define GAIN2_ADDRESS ((uint8_t) 0x05)
#define GAIN2_DEFAULT ((uint16_t) 0x0000)
#define GAIN2_RESERVED0_MASK ((uint16_t) 0x8000)
/* PGAGAIN7 field mask & values */
#define GAIN2_PGAGAIN7_MASK ((uint16_t) 0x7000)
#define GAIN2_PGAGAIN7_1 ((uint16_t) 0x0000 << 12) // DEFAULT
#define GAIN2_PGAGAIN7_2 ((uint16_t) 0x0001 << 12)
#define GAIN2_PGAGAIN7_4 ((uint16_t) 0x0002 << 12)
#define GAIN2_PGAGAIN7_8 ((uint16_t) 0x0003 << 12)
#define GAIN2_PGAGAIN7_16 ((uint16_t) 0x0004 << 12)
#define GAIN2_PGAGAIN7_32 ((uint16_t) 0x0005 << 12)
#define GAIN2_PGAGAIN7_64 ((uint16_t) 0x0006 << 12)
#define GAIN2_PGAGAIN7_128 ((uint16_t) 0x0007 << 12)
#define GAIN2_RESERVED1_MASK ((uint16_t) 0x0800)
/* PGAGAIN6 field mask & values */
#define GAIN2_PGAGAIN6_MASK ((uint16_t) 0x0700)
#define GAIN2_PGAGAIN6_1 ((uint16_t) 0x0000 << 8) // DEFAULT
#define GAIN2_PGAGAIN6_2 ((uint16_t) 0x0001 << 8)
#define GAIN2_PGAGAIN6_4 ((uint16_t) 0x0002 << 8)
#define GAIN2_PGAGAIN6_8 ((uint16_t) 0x0003 << 8)
#define GAIN2_PGAGAIN6_16 ((uint16_t) 0x0004 << 8)
#define GAIN2_PGAGAIN6_32 ((uint16_t) 0x0005 << 8)
#define GAIN2_PGAGAIN6_64 ((uint16_t) 0x0006 << 8)
#define GAIN2_PGAGAIN6_128 ((uint16_t) 0x0007 << 8)
#define GAIN2_RESERVED2_MASK ((uint16_t) 0x0080)
/* PGAGAIN5 field mask & values */
#define GAIN2_PGAGAIN5_MASK ((uint16_t) 0x0070)
#define GAIN2_PGAGAIN5_1 ((uint16_t) 0x0000 << 4) // DEFAULT
#define GAIN2_PGAGAIN5_2 ((uint16_t) 0x0001 << 4)
#define GAIN2_PGAGAIN5_4 ((uint16_t) 0x0002 << 4)
#define GAIN2_PGAGAIN5_8 ((uint16_t) 0x0003 << 4)
#define GAIN2_PGAGAIN5_16 ((uint16_t) 0x0004 << 4)
#define GAIN2_PGAGAIN5_32 ((uint16_t) 0x0005 << 4)
#define GAIN2_PGAGAIN5_64 ((uint16_t) 0x0006 << 4)
#define GAIN2_PGAGAIN5_128 ((uint16_t) 0x0007 << 4)
#define GAIN2_RESERVED3_MASK ((uint16_t) 0x0008)
/* PGAGAIN4 field mask & values */
#define GAIN2_PGAGAIN4_MASK ((uint16_t) 0x0007)
#define GAIN2_PGAGAIN4_1 ((uint16_t) 0x0000 << 0) // DEFAULT
#define GAIN2_PGAGAIN4_2 ((uint16_t) 0x0001 << 0)
#define GAIN2_PGAGAIN4_4 ((uint16_t) 0x0002 << 0)
#define GAIN2_PGAGAIN4_8 ((uint16_t) 0x0003 << 0)
#define GAIN2_PGAGAIN4_16 ((uint16_t) 0x0004 << 0)
#define GAIN2_PGAGAIN4_32 ((uint16_t) 0x0005 << 0)
#define GAIN2_PGAGAIN4_64 ((uint16_t) 0x0006 << 0)
#define GAIN2_PGAGAIN4_128 ((uint16_t) 0x0007 << 0)
#endif
/* Register 0x06 (CFG) definition
* | RESERVED0[2:0] | GC_DLY[3:0] | GC_EN | CD_ALLCH | CD_NUM[2:0] | CD_LEN[2:0] | CD_EN |
/* CFG register address & default value */
#define CFG_ADDRESS ((uint8_t) 0x06)
#define CFG_DEFAULT ((uint16_t) 0x0600)
#define CFG_RESERVED0_MASK ((uint16_t) 0xE000)
/* GC_DLY field mask & values */
#define CFG_GC_DLY_MASK ((uint16_t) 0x1E00)
#define CFG_GC_DLY_2 ((uint16_t) 0x0000 << 9)
#define CFG_GC_DLY_4 ((uint16_t) 0x0001 << 9)
#define CFG_GC_DLY_8 ((uint16_t) 0x0002 << 9)
#define CFG_GC_DLY_16 ((uint16_t) 0x0003 << 9) // DEFAULT
#define CFG_GC_DLY_32 ((uint16_t) 0x0004 << 9)
#define CFG_GC_DLY_64 ((uint16_t) 0x0005 << 9)
#define CFG_GC_DLY_128 ((uint16_t) 0x0006 << 9)
#define CFG_GC_DLY_256 ((uint16_t) 0x0007 << 9)
#define CFG_GC_DLY_512 ((uint16_t) 0x0008 << 9)
#define CFG_GC_DLY_1024 ((uint16_t) 0x0009 << 9)
#define CFG_GC_DLY_2048 ((uint16_t) 0x000A << 9)
#define CFG_GC_DLY_4096 ((uint16_t) 0x000B << 9)
#define CFG_GC_DLY_8192 ((uint16_t) 0x000C << 9)
#define CFG_GC_DLY_16484 ((uint16_t) 0x000D << 9)
#define CFG_GC_DLY_32768 ((uint16_t) 0x000E << 9)
#define CFG_GC_DLY_65536 ((uint16_t) 0x000F << 9)
/* GC_EN field mask & values */
#define CFG_GC_EN_MASK ((uint16_t) 0x0100)
#define CFG_GC_EN_DISABLED ((uint16_t) 0x0000 << 8) // DEFAULT
#define CFG_GC_EN_ENABLED ((uint16_t) 0x0001 << 8)
/* CD_ALLCH field mask & values */
#define CFG_CD_ALLCH_MASK ((uint16_t) 0x0080)
#define CFG_CD_ALLCH_ANY_CHANNEL ((uint16_t) 0x0000 << 7) // DEFAULT
#define CFG_CD_ALLCH_ALL_CHANNELS ((uint16_t) 0x0001 << 7)
/* CD_NUM field mask & values */
#define CFG_CD_NUM_MASK ((uint16_t) 0x0070)
#define CFG_CD_NUM_1 ((uint16_t) 0x0000 << 4) // DEFAULT
#define CFG_CD_NUM_2 ((uint16_t) 0x0001 << 4)
#define CFG_CD_NUM_4 ((uint16_t) 0x0002 << 4)
#define CFG_CD_NUM_8 ((uint16_t) 0x0003 << 4)
#define CFG_CD_NUM_16 ((uint16_t) 0x0004 << 4)
#define CFG_CD_NUM_32 ((uint16_t) 0x0005 << 4)
#define CFG_CD_NUM_64 ((uint16_t) 0x0006 << 4)
#define CFG_CD_NUM_128 ((uint16_t) 0x0007 << 4)
/* CD_LEN field mask & values */
#define CFG_CD_LEN_MASK ((uint16_t) 0x000E)
#define CFG_CD_LEN_128 ((uint16_t) 0x0000 << 1) // DEFAULT
#define CFG_CD_LEN_256 ((uint16_t) 0x0001 << 1)
#define CFG_CD_LEN_512 ((uint16_t) 0x0002 << 1)
#define CFG_CD_LEN_768 ((uint16_t) 0x0003 << 1)
#define CFG_CD_LEN_1280 ((uint16_t) 0x0004 << 1)
#define CFG_CD_LEN_1792 ((uint16_t) 0x0005 << 1)
#define CFG_CD_LEN_2560 ((uint16_t) 0x0006 << 1)
#define CFG_CD_LEN_3584 ((uint16_t) 0x0007 << 1)
/* CD_EN field mask & values */
#define CFG_CD_EN_MASK ((uint16_t) 0x0001)
#define CFG_CD_EN_DISABLED ((uint16_t) 0x0000 << 0) // DEFAULT
#define CFG_CD_EN_ENABLED ((uint16_t) 0x0001 << 0)
/* Register 0x07 (THRSHLD_MSB) definition
* | CD_TH_MSB[15:0] |
/* THRSHLD_MSB register address & default value */
#define THRSHLD_MSB_ADDRESS ((uint8_t) 0x07)
#define THRSHLD_MSB_DEFAULT ((uint16_t) 0x0000)
/* CD_TH_MSB field mask & values */
#define THRSHLD_MSB_CD_TH_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x08 (THRSHLD_LSB) definition
* | CD_TH_LSB[7:0] | RESERVED0[7:0] |
/* THRSHLD_LSB register address & default value */
#define THRSHLD_LSB_ADDRESS ((uint8_t) 0x08)
#define THRSHLD_LSB_DEFAULT ((uint16_t) 0x0000)
/* CD_TH_LSB field mask & values */
#define THRSHLD_LSB_CD_TH_LSB_MASK ((uint16_t) 0xFF00)
#define THRSHLD_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
/* Register 0x09 (CH0_CFG) definition
* | PHASE0[9:0] | RESERVED0[3:0] | MUX0[1:0] |
/* CH0_CFG register address & default value */
#define CH0_CFG_ADDRESS ((uint8_t) 0x09)
#define CH0_CFG_DEFAULT ((uint16_t) 0x0000)
/* PHASE0 field mask & values */
#define CH0_CFG_PHASE0_MASK ((uint16_t) 0xFFC0)
#define CH0_CFG_RESERVED0_MASK ((uint16_t) 0x003C)
/* MUX0 field mask & values */
#define CH0_CFG_MUX0_MASK ((uint16_t) 0x0003)
#define CH0_CFG_MUX0_AIN0P_AIN0N ((uint16_t) 0x0000 << 0) // DEFAULT
#define CH0_CFG_MUX0_ADC_INPUT_SHORT ((uint16_t) 0x0001 << 0)
#define CH0_CFG_MUX0_DC_DIAGNOSTIC ((uint16_t) 0x0002 << 0)
#define CH0_CFG_MUX0_AC_DIAGNOSTIC ((uint16_t) 0x0003 << 0)
/* Register 0x0A (CH0_OCAL_MSB) definition
* | OCAL0_MSB[15:0] |
/* CH0_OCAL_MSB register address & default value */
#define CH0_OCAL_MSB_ADDRESS ((uint8_t) 0x0A)
#define CH0_OCAL_MSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL0_MSB field mask & values */
#define CH0_OCAL_MSB_OCAL0_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x0B (CH0_OCAL_LSB) definition
* | OCAL0_LSB[7:0] | RESERVED0[7:0] |
/* CH0_OCAL_LSB register address & default value */
#define CH0_OCAL_LSB_ADDRESS ((uint8_t) 0x0B)
#define CH0_OCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL0_LSB field mask & values */
#define CH0_OCAL_LSB_OCAL0_LSB_MASK ((uint16_t) 0xFF00)
#define CH0_OCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
/* Register 0x0C (CH0_GCAL_MSB) definition
* | GCAL0_MSB[15:0] |
/* CH0_GCAL_MSB register address & default value */
#define CH0_GCAL_MSB_ADDRESS ((uint8_t) 0x0C)
#define CH0_GCAL_MSB_DEFAULT ((uint16_t) 0x8000)
/* GCAL0_MSB field mask & values */
#define CH0_GCAL_MSB_GCAL0_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x0D (CH0_GCAL_LSB) definition
* | GCAL0_LSB[7:0] | RESERVED0[7:0] |
/* CH0_GCAL_LSB register address & default value */
#define CH0_GCAL_LSB_ADDRESS ((uint8_t) 0x0D)
#define CH0_GCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* GCAL0_LSB field mask & values */
#define CH0_GCAL_LSB_GCAL0_LSB_MASK ((uint16_t) 0xFF00)
#define CH0_GCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
/* Register 0x0E (CH1_CFG) definition
* | PHASE1[9:0] | RESERVED0[3:0] | MUX1[1:0] |
/* CH1_CFG register address & default value */
#define CH1_CFG_ADDRESS ((uint8_t) 0x0E)
#define CH1_CFG_DEFAULT ((uint16_t) 0x0000)
/* PHASE1 field mask & values */
#define CH1_CFG_PHASE1_MASK ((uint16_t) 0xFFC0)
#define CH1_CFG_RESERVED0_MASK ((uint16_t) 0x003C)
/* MUX1 field mask & values */
#define CH1_CFG_MUX1_MASK ((uint16_t) 0x0003)
#define CH1_CFG_MUX1_AIN1P_AIN1N ((uint16_t) 0x0000 << 0) // DEFAULT
#define CH1_CFG_MUX1_ADC_INPUT_SHORT ((uint16_t) 0x0001 << 0)
#define CH1_CFG_MUX1_DC_DIAGNOSTIC ((uint16_t) 0x0002 << 0)
#define CH1_CFG_MUX1_AC_DIAGNOSTIC ((uint16_t) 0x0003 << 0)
/* Register 0x0F (CH1_OCAL_MSB) definition
* | OCAL1_MSB[15:0] |
/* CH1_OCAL_MSB register address & default value */
#define CH1_OCAL_MSB_ADDRESS ((uint8_t) 0x0F)
#define CH1_OCAL_MSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL1_MSB field mask & values */
#define CH1_OCAL_MSB_OCAL1_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x10 (CH1_OCAL_LSB) definition
* | OCAL1_LSB[7:0] | RESERVED0[7:0] |
/* CH1_OCAL_LSB register address & default value */
#define CH1_OCAL_LSB_ADDRESS ((uint8_t) 0x10)
#define CH1_OCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL1_LSB field mask & values */
#define CH1_OCAL_LSB_OCAL1_LSB_MASK ((uint16_t) 0xFF00)
#define CH1_OCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
/* Register 0x11 (CH1_GCAL_MSB) definition
* | GCAL1_MSB[15:0] |
/* CH1_GCAL_MSB register address & default value */
#define CH1_GCAL_MSB_ADDRESS ((uint8_t) 0x11)
#define CH1_GCAL_MSB_DEFAULT ((uint16_t) 0x8000)
/* GCAL1_MSB field mask & values */
#define CH1_GCAL_MSB_GCAL1_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x12 (CH1_GCAL_LSB) definition
* | GCAL1_LSB[7:0] | RESERVED0[7:0] |
/* CH1_GCAL_LSB register address & default value */
#define CH1_GCAL_LSB_ADDRESS ((uint8_t) 0x12)
#define CH1_GCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* GCAL1_LSB field mask & values */
#define CH1_GCAL_LSB_GCAL1_LSB_MASK ((uint16_t) 0xFF00)
#define CH1_GCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
#endif
/* Register 0x13 (CH2_CFG) definition
* | PHASE2[9:0] | RESERVED0[3:0] | MUX2[1:0] |
/* CH2_CFG register address & default value */
#define CH2_CFG_ADDRESS ((uint8_t) 0x13)
#define CH2_CFG_DEFAULT ((uint16_t) 0x0000)
/* PHASE2 field mask & values */
#define CH2_CFG_PHASE2_MASK ((uint16_t) 0xFFC0)
#define CH2_CFG_RESERVED0_MASK ((uint16_t) 0x003C)
/* MUX2 field mask & values */
#define CH2_CFG_MUX2_MASK ((uint16_t) 0x0003)
#define CH2_CFG_MUX2_AIN2P_AIN2N ((uint16_t) 0x0000 << 0) // DEFAULT
#define CH2_CFG_MUX2_ADC_INPUT_SHORT ((uint16_t) 0x0001 << 0)
#define CH2_CFG_MUX2_DC_DIAGNOSTIC ((uint16_t) 0x0002 << 0)
#define CH2_CFG_MUX2_AC_DIAGNOSTIC ((uint16_t) 0x0003 << 0)
/* Register 0x14 (CH2_OCAL_MSB) definition
* | OCAL2_MSB[15:0] |
/* CH2_OCAL_MSB register address & default value */
#define CH2_OCAL_MSB_ADDRESS ((uint8_t) 0x14)
#define CH2_OCAL_MSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL2_MSB field mask & values */
#define CH2_OCAL_MSB_OCAL2_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x15 (CH2_OCAL_LSB) definition
* | OCAL2_LSB[7:0] | RESERVED0[7:0] |
/* CH2_OCAL_LSB register address & default value */
#define CH2_OCAL_LSB_ADDRESS ((uint8_t) 0x15)
#define CH2_OCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL2_LSB field mask & values */
#define CH2_OCAL_LSB_OCAL2_LSB_MASK ((uint16_t) 0xFF00)
#define CH2_OCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
/* Register 0x16 (CH2_GCAL_MSB) definition
* | GCAL2_MSB[15:0] |
/* CH2_GCAL_MSB register address & default value */
#define CH2_GCAL_MSB_ADDRESS ((uint8_t) 0x16)
#define CH2_GCAL_MSB_DEFAULT ((uint16_t) 0x8000)
/* GCAL2_MSB field mask & values */
#define CH2_GCAL_MSB_GCAL2_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x17 (CH2_GCAL_LSB) definition
* | GCAL2_LSB[7:0] | RESERVED0[7:0] |
/* CH2_GCAL_LSB register address & default value */
#define CH2_GCAL_LSB_ADDRESS ((uint8_t) 0x17)
#define CH2_GCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* GCAL2_LSB field mask & values */
#define CH2_GCAL_LSB_GCAL2_LSB_MASK ((uint16_t) 0xFF00)
#define CH2_GCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
#endif
/* Register 0x18 (CH3_CFG) definition
* | PHASE3[9:0] | RESERVED0[3:0] | MUX3[1:0] |
/* CH3_CFG register address & default value */
#define CH3_CFG_ADDRESS ((uint8_t) 0x18)
#define CH3_CFG_DEFAULT ((uint16_t) 0x0000)
/* PHASE3 field mask & values */
#define CH3_CFG_PHASE3_MASK ((uint16_t) 0xFFC0)
#define CH3_CFG_RESERVED0_MASK ((uint16_t) 0x003C)
/* MUX3 field mask & values */
#define CH3_CFG_MUX3_MASK ((uint16_t) 0x0003)
#define CH3_CFG_MUX3_AIN3P_AIN3N ((uint16_t) 0x0000 << 0) // DEFAULT
#define CH3_CFG_MUX3_ADC_INPUT_SHORT ((uint16_t) 0x0001 << 0)
#define CH3_CFG_MUX3_DC_DIAGNOSTIC ((uint16_t) 0x0002 << 0)
#define CH3_CFG_MUX3_AC_DIAGNOSTIC ((uint16_t) 0x0003 << 0)
/* Register 0x19 (CH3_OCAL_MSB) definition
* | OCAL3_MSB[15:0] |
/* CH3_OCAL_MSB register address & default value */
#define CH3_OCAL_MSB_ADDRESS ((uint8_t) 0x19)
#define CH3_OCAL_MSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL3_MSB field mask & values */
#define CH3_OCAL_MSB_OCAL3_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x1A (CH3_OCAL_LSB) definition
* | OCAL3_LSB[7:0] | RESERVED0[7:0] |
/* CH3_OCAL_LSB register address & default value */
#define CH3_OCAL_LSB_ADDRESS ((uint8_t) 0x1A)
#define CH3_OCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL3_LSB field mask & values */
#define CH3_OCAL_LSB_OCAL3_LSB_MASK ((uint16_t) 0xFF00)
#define CH3_OCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
/* Register 0x1B (CH3_GCAL_MSB) definition
* | GCAL3_MSB[15:0] |
/* CH3_GCAL_MSB register address & default value */
#define CH3_GCAL_MSB_ADDRESS ((uint8_t) 0x1B)
#define CH3_GCAL_MSB_DEFAULT ((uint16_t) 0x8000)
/* GCAL3_MSB field mask & values */
#define CH3_GCAL_MSB_GCAL3_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x1C (CH3_GCAL_LSB) definition
* | GCAL3_LSB[7:0] | RESERVED0[7:0] |
/* CH3_GCAL_LSB register address & default value */
#define CH3_GCAL_LSB_ADDRESS ((uint8_t) 0x1C)
#define CH3_GCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* GCAL3_LSB field mask & values */
#define CH3_GCAL_LSB_GCAL3_LSB_MASK ((uint16_t) 0xFF00)
#define CH3_GCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
#endif
/* Register 0x1D (CH4_CFG) definition
* | PHASE4[9:0] | RESERVED0[3:0] | MUX4[1:0] |
/* CH4_CFG register address & default value */
#define CH4_CFG_ADDRESS ((uint8_t) 0x1D)
#define CH4_CFG_DEFAULT ((uint16_t) 0x0000)
/* PHASE4 field mask & values */
#define CH4_CFG_PHASE4_MASK ((uint16_t) 0xFFC0)
#define CH4_CFG_RESERVED0_MASK ((uint16_t) 0x003C)
/* MUX4 field mask & values */
#define CH4_CFG_MUX4_MASK ((uint16_t) 0x0003)
#define CH4_CFG_MUX4_AIN4P_AIN4N ((uint16_t) 0x0000 << 0) // DEFAULT
#define CH4_CFG_MUX4_ADC_INPUT_SHORT ((uint16_t) 0x0001 << 0)
#define CH4_CFG_MUX4_DC_DIAGNOSTIC ((uint16_t) 0x0002 << 0)
#define CH4_CFG_MUX4_AC_DIAGNOSTIC ((uint16_t) 0x0003 << 0)
/* Register 0x1E (CH4_OCAL_MSB) definition
* | OCAL4_MSB[15:0] |
/* CH4_OCAL_MSB register address & default value */
#define CH4_OCAL_MSB_ADDRESS ((uint8_t) 0x1E)
#define CH4_OCAL_MSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL4_MSB field mask & values */
#define CH4_OCAL_MSB_OCAL4_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x1F (CH4_OCAL_LSB) definition
* | OCAL4_LSB[7:0] | RESERVED0[7:0] |
/* CH4_OCAL_LSB register address & default value */
#define CH4_OCAL_LSB_ADDRESS ((uint8_t) 0x1F)
#define CH4_OCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL4_LSB field mask & values */
#define CH4_OCAL_LSB_OCAL4_LSB_MASK ((uint16_t) 0xFF00)
#define CH4_OCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
/* Register 0x20 (CH4_GCAL_MSB) definition
* | GCAL4_MSB[15:0] |
/* CH4_GCAL_MSB register address & default value */
#define CH4_GCAL_MSB_ADDRESS ((uint8_t) 0x20)
#define CH4_GCAL_MSB_DEFAULT ((uint16_t) 0x8000)
/* GCAL4_MSB field mask & values */
#define CH4_GCAL_MSB_GCAL4_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x21 (CH4_GCAL_LSB) definition
* | GCAL4_LSB[7:0] | RESERVED0[7:0] |
/* CH4_GCAL_LSB register address & default value */
#define CH4_GCAL_LSB_ADDRESS ((uint8_t) 0x21)
#define CH4_GCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* GCAL4_LSB field mask & values */
#define CH4_GCAL_LSB_GCAL4_LSB_MASK ((uint16_t) 0xFF00)
#define CH4_GCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
#endif
#if (CHANNEL_COUNT > 5)
/* Register 0x22 (CH5_CFG) definition
* | PHASE5[9:0] | RESERVED0[3:0] | MUX5[1:0] |
/* CH5_CFG register address & default value */
#define CH5_CFG_ADDRESS ((uint8_t) 0x22)
#define CH5_CFG_DEFAULT ((uint16_t) 0x0000)
/* PHASE5 field mask & values */
#define CH5_CFG_PHASE5_MASK ((uint16_t) 0xFFC0)
#define CH5_CFG_RESERVED0_MASK ((uint16_t) 0x003C)
/* MUX5 field mask & values */
#define CH5_CFG_MUX5_MASK ((uint16_t) 0x0003)
#define CH5_CFG_MUX5_AIN5P_AIN5N ((uint16_t) 0x0000 << 0) // DEFAULT
#define CH5_CFG_MUX5_ADC_INPUT_SHORT ((uint16_t) 0x0001 << 0)
#define CH5_CFG_MUX5_DC_DIAGNOSTIC ((uint16_t) 0x0002 << 0)
#define CH5_CFG_MUX5_AC_DIAGNOSTIC ((uint16_t) 0x0003 << 0)
/* Register 0x23 (CH5_OCAL_MSB) definition
* | OCAL5_MSB[15:0] |
/* CH5_OCAL_MSB register address & default value */
#define CH5_OCAL_MSB_ADDRESS ((uint8_t) 0x23)
#define CH5_OCAL_MSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL5_MSB field mask & values */
#define CH5_OCAL_MSB_OCAL5_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x24 (CH5_OCAL_LSB) definition
* | OCAL5_LSB[7:0] | RESERVED0[7:0] |
/* CH5_OCAL_LSB register address & default value */
#define CH5_OCAL_LSB_ADDRESS ((uint8_t) 0x24)
#define CH5_OCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL5_LSB field mask & values */
#define CH5_OCAL_LSB_OCAL5_LSB_MASK ((uint16_t) 0xFF00)
#define CH5_OCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
/* Register 0x25 (CH5_GCAL_MSB) definition
* | GCAL5_MSB[15:0] |
/* CH5_GCAL_MSB register address & default value */
#define CH5_GCAL_MSB_ADDRESS ((uint8_t) 0x25)
#define CH5_GCAL_MSB_DEFAULT ((uint16_t) 0x8000)
/* GCAL5_MSB field mask & values */
#define CH5_GCAL_MSB_GCAL5_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x26 (CH5_GCAL_LSB) definition
* | GCAL5_LSB[7:0] | RESERVED0[7:0] |
/* CH5_GCAL_LSB register address & default value */
#define CH5_GCAL_LSB_ADDRESS ((uint8_t) 0x26)
#define CH5_GCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* GCAL5_LSB field mask & values */
#define CH5_GCAL_LSB_GCAL5_LSB_MASK ((uint16_t) 0xFF00)
#define CH5_GCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
#endif
#if (CHANNEL_COUNT > 6)
/* Register 0x27 (CH6_CFG) definition
* | PHASE6[9:0] | RESERVED0[3:0] | MUX6[1:0] |
/* CH6_CFG register address & default value */
#define CH6_CFG_ADDRESS ((uint8_t) 0x27)
#define CH6_CFG_DEFAULT ((uint16_t) 0x0000)
/* PHASE6 field mask & values */
#define CH6_CFG_PHASE6_MASK ((uint16_t) 0xFFC0)
#define CH6_CFG_RESERVED0_MASK ((uint16_t) 0x003C)
/* MUX6 field mask & values */
#define CH6_CFG_MUX6_MASK ((uint16_t) 0x0003)
#define CH6_CFG_MUX6_AIN6P_AIN6N ((uint16_t) 0x0000 << 0) // DEFAULT
#define CH6_CFG_MUX6_ADC_INPUT_SHORT ((uint16_t) 0x0001 << 0)
#define CH6_CFG_MUX6_DC_DIAGNOSTIC ((uint16_t) 0x0002 << 0)
#define CH6_CFG_MUX6_AC_DIAGNOSTIC ((uint16_t) 0x0003 << 0)
/* Register 0x28 (CH6_OCAL_MSB) definition
* | OCAL6_MSB[15:0] |
/* CH6_OCAL_MSB register address & default value */
#define CH6_OCAL_MSB_ADDRESS ((uint8_t) 0x28)
#define CH6_OCAL_MSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL6_MSB field mask & values */
#define CH6_OCAL_MSB_OCAL6_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x29 (CH6_OCAL_LSB) definition
* | OCAL6_LSB[7:0] | RESERVED0[7:0] |
/* CH6_OCAL_LSB register address & default value */
#define CH6_OCAL_LSB_ADDRESS ((uint8_t) 0x29)
#define CH6_OCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL6_LSB field mask & values */
#define CH6_OCAL_LSB_OCAL6_LSB_MASK ((uint16_t) 0xFF00)
#define CH6_OCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
/* Register 0x2A (CH6_GCAL_MSB) definition
* | GCAL6_MSB[15:0] |
/* CH6_GCAL_MSB register address & default value */
#define CH6_GCAL_MSB_ADDRESS ((uint8_t) 0x2A)
#define CH6_GCAL_MSB_DEFAULT ((uint16_t) 0x8000)
/* GCAL6_MSB field mask & values */
#define CH6_GCAL_MSB_GCAL6_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x2B (CH6_GCAL_LSB) definition
* | GCAL6_LSB[7:0] | RESERVED0[7:0] |
/* CH6_GCAL_LSB register address & default value */
#define CH6_GCAL_LSB_ADDRESS ((uint8_t) 0x2B)
#define CH6_GCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* GCAL6_LSB field mask & values */
#define CH6_GCAL_LSB_GCAL6_LSB_MASK ((uint16_t) 0xFF00)
#define CH6_GCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
#endif
#if (CHANNEL_COUNT > 7)
/* Register 0x2C (CH7_CFG) definition
* | PHASE7[9:0] | RESERVED0[3:0] | MUX7[1:0] |
/* CH7_CFG register address & default value */
#define CH7_CFG_ADDRESS ((uint8_t) 0x2C)
#define CH7_CFG_DEFAULT ((uint16_t) 0x0000)
/* PHASE7 field mask & values */
#define CH7_CFG_PHASE7_MASK ((uint16_t) 0xFFC0)
#define CH7_CFG_RESERVED0_MASK ((uint16_t) 0x003C)
/* MUX7 field mask & values */
#define CH7_CFG_MUX7_MASK ((uint16_t) 0x0003)
#define CH7_CFG_MUX7_AIN7P_AIN7N ((uint16_t) 0x0000 << 0) // DEFAULT
#define CH7_CFG_MUX7_ADC_INPUT_SHORT ((uint16_t) 0x0001 << 0)
#define CH7_CFG_MUX7_DC_DIAGNOSTIC ((uint16_t) 0x0002 << 0)
#define CH7_CFG_MUX7_AC_DIAGNOSTIC ((uint16_t) 0x0003 << 0)
/* Register 0x2D (CH7_OCAL_MSB) definition
* | OCAL7_MSB[15:0] |
/* CH7_OCAL_MSB register address & default value */
#define CH7_OCAL_MSB_ADDRESS ((uint8_t) 0x2D)
#define CH7_OCAL_MSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL7_MSB field mask & values */
#define CH7_OCAL_MSB_OCAL7_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x2E (CH7_OCAL_LSB) definition
* | OCAL7_LSB[7:0] | RESERVED0[7:0] |
/* CH7_OCAL_LSB register address & default value */
#define CH7_OCAL_LSB_ADDRESS ((uint8_t) 0x2E)
#define CH7_OCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* OCAL7_LSB field mask & values */
#define CH7_OCAL_LSB_OCAL7_LSB_MASK ((uint16_t) 0xFF00)
#define CH7_OCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
/* Register 0x2F (CH7_GCAL_MSB) definition
* | GCAL7_MSB[15:0] |
/* CH7_GCAL_MSB register address & default value */
#define CH7_GCAL_MSB_ADDRESS ((uint8_t) 0x2F)
#define CH7_GCAL_MSB_DEFAULT ((uint16_t) 0x8000)
/* GCAL7_MSB field mask & values */
#define CH7_GCAL_MSB_GCAL7_MSB_MASK ((uint16_t) 0xFFFF)
/* Register 0x30 (CH7_GCAL_LSB) definition
* | GCAL7_LSB[7:0] | RESERVED0[7:0] |
/* CH7_GCAL_LSB register address & default value */
#define CH7_GCAL_LSB_ADDRESS ((uint8_t) 0x30)
#define CH7_GCAL_LSB_DEFAULT ((uint16_t) 0x0000)
/* GCAL7_LSB field mask & values */
#define CH7_GCAL_LSB_GCAL7_LSB_MASK ((uint16_t) 0xFF00)
#define CH7_GCAL_LSB_RESERVED0_MASK ((uint16_t) 0x00FF)
#endif
/* Register 0x3E (REGMAP_CRC) definition
* | REG_CRC[15:0] |
/* REGMAP_CRC register address & default value */
#define REGMAP_CRC_ADDRESS ((uint8_t) 0x3E)
#define REGMAP_CRC_DEFAULT ((uint16_t) 0x0000)
/* REG_CRC field mask & values */
#define REGMAP_CRC_REG_CRC_MASK ((uint16_t) 0xFFFF)
// Channel data structure
typedef struct
uint16_t response;
uint16_t crc;
int32_t channel0;
#if (CHANNEL_COUNT > 1)
int32_t channel1;
#endif
#if (CHANNEL_COUNT > 2)
int32_t channel2;
#endif
#if (CHANNEL_COUNT > 3)
int32_t channel3;
#endif
#if (CHANNEL_COUNT > 4)
int32_t channel4;
#endif
int32_t channel5;
#endif
int32_t channel6;
#endif
int32_t channel7;
#endif
} adc_channel_data;
// Internal variables
// Array used to recall device register map configurations */
static uint16_t registerMap[NUM_REGISTERS];
// Array of SPI word lengths
const static uint8_t wlength_byte_values[] = {2, 3, 4, 4};
// Function prototypes
void adcStartup(void);
void InitSPI(void);
void delay_ms(const uint32_t delay_time_ms);
void setSYNC_RESET(const bool state);
void toggleRESET(void);
void restoreRegisterDefaults(void);
void writeSingleRegister(uint8_t address, uint16_t data);
void spiSendReceiveArrays(const uint8_t DataTx[], uint8_t DataRx[], const uint8_t byteLength);
void setCS(const bool state);
uint8_t spiSendReceiveByte(const uint8_t dataTx);
uint16_t readSingleRegister(uint8_t address);
uint16_t sendCommand(uint16_t op_code);
// Getter functions
uint16_t getRegisterValue(uint8_t address);
// Helper functions
uint8_t upperByte(uint16_t uint16_Word);
uint8_t lowerByte(uint16_t uint16_Word);
uint16_t combineBytes(uint8_t upperByte, uint8_t lowerByte);
int32_t signExtend(const uint8_t dataBytes[]);
// Internal function prototypes
uint8_t buildSPIarray(const uint16_t opcodeArray[], uint8_t numberOpcodes, uint8_t byteArray[]);
uint16_t enforce_selected_device_modes(uint16_t data);
uint8_t getWordByteLength(void);
// Register macros
/** Returns Number of Channels */
#define CHANCNT ((uint8_t) ((getRegisterValue(ID_ADDRESS) & ID_CHANCNT_MASK) >> 8))
/** Revision ID bits */
#define REVISION_ID ((uint8_t) ((getRegisterValue(ID_ADDRESS) & ID_REVID_MASK) >> 0))
/** Returns true if SPI interface is locked */
#define SPI_LOCKED ((bool) (getRegisterValue(STATUS_ADDRESS) & STATUS_LOCK_LOCKED))
/** Returns SPI Communication Word Format*/
#define WLENGTH ((uint8_t) ((getRegisterValue(MODE_ADDRESS) & STATUS_WLENGTH_MASK) >> 8))
/** Returns true if Register Map CRC byte enable bit is set */
#define REGMAP_CRC_ENABLED ((bool) (getRegisterValue(MODE_ADDRESS) & MODE_REG_CRC_EN_ENABLED))
/** Returns true if SPI CRC byte enable bit is set */
#define SPI_CRC_ENABLED ((bool) (getRegisterValue(MODE_ADDRESS) & MODE_RX_CRC_EN_ENABLED))
/** Returns false for CCITT and true for ANSI CRC type */
#define SPI_CRC_TYPE ((bool) (getRegisterValue(MODE_ADDRESS) & MODE_CRC_TYPE_MASK))
/** Data rate register field setting */
#define OSR_INDEX ((uint8_t) ((getRegisterValue(CLOCK_ADDRESS) & CLOCK_OSR_MASK) >> 2))
#define POWER_MODE ((uint8_t) ((getRegisterValue(CLOCK_ADDRESS) & CLOCK_PWR_MASK) >> 0))
// Pin definitions (MSP432E401Y)
#define nDRDY_PORT (GPIO_PORTM_BASE)
#define nDRDY_PIN (GPIO_PIN_0)
#define nDRDY_INT (INT_GPIOM)
#define nCS_PORT (GPIO_PORTK_BASE)
#define nCS_PIN (GPIO_PIN_5)
#define nSYNC_nRESET_PORT (GPIO_PORTK_BASE)
#define nSYNC_nRESET_PIN (GPIO_PIN_4)
// Macros
/** Alias used for setting GPIOs pins to the logic "high" state */
#define HIGH ((bool) true)
/** Alias used for setting GPIOs pins to the logic "low" state */
#define LOW ((bool) false)
#endif /* ADS131M0X_H_ */
Ram.
