Part Number: AM2634
I work on a project based on AM2634 MCU. At this point I'm investigation question of debugging HS-SE boards with secure certificate baked into OTP eFuses.
Using both methods from documentation ( SBl with DBG_FULL_ENABLE and TIFS debug authentication ) I can start debug session from CCS via TI XDS debugger without an issue. But when I try to start session from Lauterbach - it fails.
I'm using Lauterbach scripts provided by your side earlier. Typically they are used for re-flashing purposes and everything works fine on HS-FS boards.
Do you have any suggestions how to make Lauterbach work with secured board? Maybe some additional scripts or needed changes to existing ones?
