Part Number: TMS570LC4357-EP
Hi
Of late I often have debug connectivity issues leading to inability to debug. Our hardware engineer think there is nothing wrong with connection. We use the software to drive the motor to open and close a door. When entering the debug mode main(), the door position is in closed mode. When I drive the motor to open, the debug mode is ok. When I drive the motor to close, it will encounter connectivity issues. Thereafter I can't debug my code. Below is the error code printed:
CortexR5: GEL Output: Memory Map Setup for Flash @ Address 0x0 due to System Reset
Dap: Error: (Error -242 @ 0x0) A router subpath could not be accessed. The board configuration file is probably incorrect. (Emulation package 9.6.0.00172)
CortexR5: Error: (Error -2063 @ 0x0) Unable to reset device. Power-cycle the board. If error persists, confirm configuration and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 9.6.0.00172)
CortexR5: Trouble Halting Target CPU: (Error -2064 @ 0x0) Unable to read device status. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 9.6.0.00172)
CortexR5: Error: (Error -1170 @ 0x0) Unable to access the DAP. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 9.6.0.00172)
