Part Number: TM4C1294NCPDT
I want to use LM flasher via router, it work on direct ethernet connection but via router it does not work
Do you have two or more NICs (Network Interface Card) on your PC which is running LM flash programmer. If you do, disable all NICs except the one that is on the same network as the MCU. It is possible that your issue is similar to this post. https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/675608/tm4c1294kcpdt-lmflash-ethernet-update-bug---magic-packet-sent-on-wrong-interface. There is a bug in LM flash programmer where it would send the magic packet to the wrong NIC.
I have not heard back from you. I hope your problem is resolved. I will close the thread for now. If you have any update, you can write back to this post and the status will change to OPEN again.
