Part Number: TMDSEMU110-U
Hi
After we upgraded this product according to the prompt, it cannot be used. Please help confirm the cause
How to solve it
Thank you
Hi
How to solve it
Thank you
It sounds like it prompted you to update the firmware on it, did the seem to be successful? Typically the only issues I've seen were from when it is unplugged mid-update, did that happen?
What happens when you try and program with it? Do you get any errors?
JD
Does the XDS110 still show up in the computer's device manager? If so, you can try using Uniflash and see it it will detect and update it again.
If not, then there are some emergency steps of opening the case up and trying to reflash the XDS manually. Some details in this thread here and it points you to the XDS support document inside the CCS files: https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1210827/tmdscncd263-how-to-recover-xds110-firmware
Hope this helps.
JD
Hi
Attached is the re-upgrade operation according to the above way you provided, please confirm whether the interface is correct
