Part Number: AM2432
The am2432 is dev mode. why this problem?
Hello, this is the current issue. I am not using the EVM but rather the AM2432ALV. What could be the problem? My operating mode is dev mode.
Hello Wenjun,
Thanks for providing the above details.
Can you please confirm which device type are you using? Is it a GP device or HSFS?
Please refer faq-am6xx-how-to-check-if-device-type-is-hs-se-hs-fs-or-gp.
Tushar
I cannot confirm; my PCB does not have the UART pins exposed, but my chip model is AM2432ALV
Hello Wenjun,
Can you please confirm, does the above error occurs every time or it is happening randomly?
Have you tried the same process with another AM243x ALV chip? Is that working? Is it failing for only single AM243x chip or is it failing for all?
Tushar
