Part Number: MSPM0L1306
CLK_OUT is set in syscfg as shown in the attached image. The pins used are "PA9/14".
In this case, is it possible to set the initial setting for "PA9/14" when power is applied as a GPIO output, and then set "PA9/14" to CLK_OUT at a certain timing?
The operation is as follows.
-Power ON → "PA9/14" set to output → "PA9/14" output inverted when input is detected → "PA9/14" set to CLK_OUT when it has been inverted 10 times.
