Part Number: AM2634
Hello. Dear TI team,
I want to create an empty project and check the operation of the 5 cores in the UART log.
UART logs for r5fss0-0 are output, but UART logs for other cores are not output.
I am using terminal software to check the UART log. I also tried the CCS log, but there is no output.
What am I missing?
e2e.ti.com/.../am2634-sysconfig-enable-uart-log-for-multiple-cores
I referred to this, but could not resolve the issue.
environment:
*CCS12.7.0
*AM243x MCU+SDK 09.02.01.05
*LP-AM2434
We confirmed in advance that the UART log of the IPC sample is output.
I tried importing IPC samples r5fss0-0 and r5f1-1 into my empty project, but no UART logs other than r5fss0-0 are output.
The example.syscfg and CCS build settings should be the same as the IPC sample, but the UART log is not output.
IPC sample logs have CORE names appended to them.
[r5f1-1] 6.801416s : 2024.07.11.1948[R5F][1-1][IPC] [IPC NOTIFY ECHO] Remote core has echoed all messages !!!
I think it is added in the UART log driver.
I think there is probably a setting to enable UART logging.
Thank you and looking forward for your response.
Yoshiki Koide
