TMS570LS3137: Unable to See Serial Port Output After Changing TI Device Serial Number with FTDI Program
Part Number: TMS570LS3137
Other Parts Discussed in Thread: TMDS570LS31HDK
I used the FTDI program to change the serial number of a Texas Instruments device, but I made a mistake. As a result, I had to install an XML file to reconnect to the device. However, now I cannot see any output from the serial port. When I open Device Manager in Windows, I can only see the device under Debug Probes, and it does not appear under COM ports. This means I can print the output on the console but not on the serial port in the terminal on Code Composer Studio. Could someone please help me fix this issue?
Thank you very much
