Other Parts Discussed in Thread: HALCOGEN
I am currently using the HalCoGen 04.07.01 with the TI LaunchpadXL2-RM57Lx. I am new to this and need help trying to synchronize the HET1 timer with the HET2 timer using the master-slave configuration. My HET1 timer is currently set to master mode and my HET2 timer is currently set to slave mode. I need help figuring out how to send the signal from the master to activate the slave. I am currently trying to synchronize a PWM interrupt for both HET timers.
I saw that on the RM57Lx technical reference manual, the N2HET2 uses the N2HET1_LOOP_SYNC signal to synchronize its own time base to the N2HET1. How do I accomplish this in either HalCoGen or Code Composer Studio? How can I make the N2HET1 module output the N2HET1_LOOP_SYNC signal so that the N2HET2 module can synchronize its PWM interrupt to the N2HET1?
Thank you,
James Li
