TMS570LS0914: Not able to jump from Application to Boot
Part Number: TMS570LS0914
Not able to jump from Application to Boot in few of the boards, but after the same is working perfectly fine after reflashing the boot loader using JTAG.
  • Hi Saurav Kumar,
    Sorry, i need more details about the issue.
    1. Are you about the jump from application to boot. Actually, bootloader will reside at start of the flash and then application will be present. So usually after reset the bootloader code will get call and then from bootloader the application will get call.
    But here you are saying jump from application to boot, i just got little confused.
    So, please clarify this.
    2. Exactly which bootloader code you are using?
    Thanks & regards,
    Jagadish.
