Part Number: TMS570LS1224
Other Parts Discussed in Thread: HALCOGEN
The bootloader example but it gives some errors to build. But I'd like to be sure about smth. I guess I wasn't celar that The prolem not about application interrupt. I say this because you sended me (+) RM57L843: UART_Bootlader_RM57 Questions - Arm-based microcontrollers forum - Arm-based microcontrollers - TI E2E support forums this to check. My problem is in bootlodefr even before loading the app. Whenever I enable CAN interrupt and send a can message to bootloader it frooze.By the way I tested creating project step by step. It frooze after I include the link file. I don't undertand why. I would be really greatful if you could help me about it.
I also would like to say that when I checked your bootloader example I saw that you didn't enable the interrupt on CANMessageSetRx() function via usMsgCtrl = CAN_IFMCTL_UMASK | CAN_IFMCTL_EOB | CAN_IFMCTL_RXIE; So that might be the reason of your not having problem for intterrupt. And main funct,on you didn't enable the intterupt. I hope you could help me about it.
Thanks & Regards,
Zeynep
