LP-AM243: Power Error Fault
Part Number: LP-AM243
I’ve been trying to set up the AM243x LP and I’ve encountered a Power Error fault.
This is the second board it happens.
On the first board we edited the board in a way that cleared the Power Error fault, but then it failed on the Flash SOC initialization step (2-step process: passed the first load, failed the second load).
Regardless, both boards have a default Power Error fault. I tried connecting it directly to my PC (which the data sheet stated it is valid) and using a power supply while limited to 5V, 3A (again, information which was provided from the data sheet).
  • First board PCB#:              PROC109E3
  • Second board PCB#:        PROC109A
I’ve been following the steps described:
https://software-dl.ti.com/mcu-plus-sdk/esd/AM243X/latest/exports/docs/api_guide_am243x/EVM_SETUP_PAGE.html
And also, I’ve been looking at the data sheet & schematics provided here (5V 3A limitation, see suitable power options and guide for HW edit for the first board):
https://www.ti.com/tool/LP-AM243
