Part Number: LP-AM243
Hello;
I received my Lp-243 Sitara board and I did all installation with following of TI pages. But when I try to debug hello_world_am243-lp_m4fss0_nortos project from the mcu plus sdk, I have followiing error below;
Error connecting to the target:
(Error -1170 @ 0x0)
Unable to access the DAP. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK).
(Emulation package 12.7.0.00130)
When I try to use ters connection button that is on target configurations, I get following error below;
This error is generated by TI's USCIF driver or utilities.
The value is '-233' (0xffffff17).
The title is 'SC_ERR_PATH_BROKEN'.
The explanation is:
The JTAG IR and DR scan-paths cannot circulate bits, they may be broken.
An attempt to scan the JTAG scan-path has failed.
The target's JTAG scan-path appears to be broken
with a stuck-at-ones or stuck-at-zero fault.
And when I try to read memory with UniFlash, I get error message below;
Error connecting to the target: (Error -1170 @ 0x0) Unable to access the DAP. Reset the device,
Could you please support me on this?
Kadir
