Part Number: AM2434
Other Parts Discussed in Thread: CC2538, SYSCONFIG
Hello Expert,
I am creating a Docker container for CI/CD purposes, and I need to have it build the code with CCS. I am facing two issues with unattended CCS installation in the Docker Container:
Issue 1 - Failure to Download Component
The Docker container successfully downloads the web installer as but it fails to execute the ccs_setup_xxxxx.run file. Specifically, it fails to download the PF_SITARA component.
Command used: ./ccs_setup_12.1.0.00007.run --mode unattended --prefix /opt --enable-components PF_SITARA
Install log is attached; screenshot below:
Log started 08/08/2024 at 21:32:26 Preferred installation mode : unattended Trying to init installer in mode unattended Mode unattended successfully initialized [21:32:26] CCS_INFO: Installer timestamp 20240808213226 [21:32:26] Installer arguments --mode unattended --prefix /opt --enable-components PF_SITARA [21:32:27] CCS_INFO: Initialization sets components_download_url to http://software-dl.ti.com/ccs/esd/CCSv12/CCS12.1.0.00007_linux-x64/components [21:32:27] createshortcuts set to true [21:32:27] CCS_INFO: Temporary folder set to /tmp/ccs_86b626a0-0a6e-4612-7439-c54e61eebbd8 [21:32:27] CCS_INFO: Product families available: PF_MSP430,PF_MSP432,PF_CC2X,PF_CC3X,PF_CC2538,PF_C28,PF_TM4C,PF_HERCULES,PF_SITARA,PF_SITARA_MCU,PF_OMAPL,PF_DAVINCI,PF_OMAP,PF_TDA_DRA,PF_C55,PF_C6000SC,PF_C66AK_KEYSTONE,PF_MMWAVE,PF_C64MC,PF_DIGITAL_POWER,PF_PGA [21:32:27] CCS_INFO: Components available: ARM_CGT_HELP,C2000_CGT_HELP,C6000_CGT_HELP,CCS_DOC,CCS_LAUNCHER,CCS_UTILS,CGT_DEFAULTLIBS_C2800,CGT_DEFAULTLIBS_C6000_V8P,CGT_DEFAULTLIBS_MSP430,CGT_DEFAULTLIBS_TMS470,CLOUDAGENT,DEV_SUPPORT_AUTOMOTIVE,DEV_SUPPORT_C55XX,DEV_SUPPORT_C6000,DEV_SUPPORT_CC2538,DEV_SUPPORT_CC26XX,DEV_SUPPORT_CC3220,DEV_SUPPORT_CC3230,DEV_SUPPORT_CC32XX,DEV_SUPPORT_CC32XX_COMMON,DEV_SUPPORT_DAVINCI,DEV_SUPPORT_INTEGRA,DEV_SUPPORT_MMWAVE,DEV_SUPPORT_OMAP,DEV_SUPPORT_PGA,DEV_SUPPORT_SHARED,DEV_SUPPORT_SITARA,DEV_SUPPORT_SITARA_MCU,DEV_SUPPORT_UCD31XX,DMED,DS,DS_FLASH,DVT,ECLIPSE,EMU_BH,EMU_C2000,EMU_C2000_FLASH,EMU_HERCULES,EMU_TI,IDE,IDE_CHROME,IDE_GC,IDE_TOOLS_COMMON,INSTALLER,JRE,KEYSTONE2,MSP430_BUILD_DEBUG,MSP430_CGT_HELP,MSP430_GCC_SUPPORT,MSP432_BUILD_DEBUG,MSPM0,NODEJS,P2APP,P2TOOLS,SEGGER_J_LINK,SYSCONFIG,TARGETDB_DEF_PROPS,TARGET_CONTENT_CORE,TIREX,TIREX4,TIVA_STELLARIS_DRIVERS,TIVA_TM4C,TIVA_TM4E,TI_ARM_CLANG,USERGUIDE,core [21:32:27] PFsToBeInstalled: PF_SITARA [21:32:27] Running in unattended mode, must validate system. Executing /tmp/ccs_86b626a0-0a6e-4612-7439-c54e61eebbd8/util/dependency-checker/check_depends.sh Script exit code: 0 Script output: Installed versions of glibc and glibcxx: 2.31, N/A Required versions of glibc and glibcxx: 2.18, GLIBCXX_3.4.28 GLIBC_INSTALLED: 2.31 GLIBC_REQUIRED: 2.18 Checking availability of libraries in ext-depends.txt ... Done. Script stderr: [21:32:28] CCS_INFO:GLIBC installed: 2.31 [21:32:28] CCS_INFO: GLIBC required: 2.18 [21:32:28] CCS_INFO: Missing dependencies: [] [21:32:28] CCS_WARNING: OK Executing /tmp/ccs_86b626a0-0a6e-4612-7439-c54e61eebbd8/util/dependency-checker/ldcheck Script exit code: 0 Script output: Script stderr: [21:32:29] CCS_INFO: Running in unattended mode, must validate installdir /opt. [21:32:29] Logdir = /opt/ccs/install_logs/20240808213226 [21:32:29] CCS_INFO: CCStudio set to /opt/ccs/eclipse/ccstudio [21:32:30] installedProductFamilies = [21:32:30] CCS_INFO: Running fresh install in unattended mode, user provided components to be installed (PF_SITARA). [21:32:30] CCS_INFO: In selectAllComponents.xml PFList = PF_SITARA [21:32:30] PF_SITARA selected: 1 [21:32:30] EMU_TI selected: 1 [21:32:30] EMU_TI: Installed Version: NOTSET Current Version: 9.9.0.00040 [21:32:30] DEV_SUPPORT_SITARA selected: 1 [21:32:30] DEV_SUPPORT_SITARA: Installed Version: NOTSET Current Version: 1.6.2 [21:32:31] DEV_SUPPORT_SHARED selected: 1 [21:32:31] DEV_SUPPORT_SHARED: Installed Version: NOTSET Current Version: 1.1.7 [21:32:31] ARM_CGT_HELP selected: 1 [21:32:31] ARM_CGT_HELP: Installed Version: NOTSET Current Version: 18.1.0.20181119 [21:32:31] CGT_DEFAULTLIBS_TMS470 selected: 1 [21:32:31] CGT_DEFAULTLIBS_TMS470: Installed Version: NOTSET Current Version: 20.2.7.LTS [21:32:31] TI_ARM_CLANG selected: 1 [21:32:31] TI_ARM_CLANG: Installed Version: NOTSET Current Version: 2.1.2.LTS [21:32:31] DMED selected: 1 [21:32:31] DMED: Installed Version: NOTSET Current Version: 1.1.6 [21:32:31] C6000_CGT_HELP selected: 1 [21:32:31] C6000_CGT_HELP: Installed Version: NOTSET Current Version: 7.4.0.20150713 [21:32:32] CGT_DEFAULTLIBS_C6000_V8P selected: 1 [21:32:32] CGT_DEFAULTLIBS_C6000_V8P: Installed Version: NOTSET Current Version: 8.3.12 [21:32:32] CCS_INFO: setting project.component(ALL).component(core).selected to 1 [21:32:32] CCS_INFO: setting project.component(ALL).component(IDE).selected to 0 [21:32:32] CCS_INFO: setting project.component(ALL).component(DVT).selected to 0 [21:32:32] CCS_INFO: setting project.component(ALL).component(JRE).selected to 0 [21:32:32] CCS_INFO: setting project.component(ALL).component(IDE_GC).selected to 0 [21:32:32] CCS_INFO: setting project.component(ALL).component(IDE_CHROME).selected to 0 [21:32:32] CCS_INFO: setting project.component(ALL).component(IDE_TOOLS_COMMON).selected to 0 [21:32:32] CCS_INFO: setting project.component(ALL).component(P2APP).selected to 0 [21:32:32] CCS_INFO: setting project.component(ALL).component(P2TOOLS).selected to 0 [21:32:32] CCS_DOC NOTSET 12.1.0.00007 [21:32:32] CCS_DOC selected: 1 [21:32:32] CCS_DOC: Installed Version: NOTSET Current Version: 12.1.0.00007 [21:32:32] CCS_UTILS NOTSET 1.0.0.20190716 [21:32:32] CCS_UTILS selected: 1 [21:32:32] CCS_UTILS: Installed Version: NOTSET Current Version: 1.0.0.20190716 [21:32:32] CCS_LAUNCHER NOTSET 12.0.0.20220603 [21:32:32] CCS_LAUNCHER selected: 1 [21:32:32] CCS_LAUNCHER: Installed Version: NOTSET Current Version: 12.0.0.20220603 [21:32:32] TARGETDB_DEF_PROPS NOTSET 12.1.0.N202209041800 [21:32:32] TARGETDB_DEF_PROPS selected: 1 [21:32:32] TARGETDB_DEF_PROPS: Installed Version: NOTSET Current Version: 12.1.0.N202209041800 [21:32:32] INSTALLER NOTSET 12.1.0.00007 [21:32:32] INSTALLER selected: 1 [21:32:32] INSTALLER: Installed Version: NOTSET Current Version: 12.1.0.00007 [21:32:33] TARGET_CONTENT_CORE NOTSET 3.62.1.16 [21:32:33] TARGET_CONTENT_CORE selected: 1 [21:32:33] TARGET_CONTENT_CORE: Installed Version: NOTSET Current Version: 3.62.1.16 [21:32:33] TIREX NOTSET 3.8.0.201911142334 [21:32:33] TIREX selected: 1 [21:32:33] TIREX: Installed Version: NOTSET Current Version: 3.8.0.201911142334 [21:32:33] TIREX4 NOTSET 4.8.0.202106161344 [21:32:33] TIREX4 selected: 1 [21:32:33] TIREX4: Installed Version: NOTSET Current Version: 4.8.0.202106161344 [21:32:33] NODEJS NOTSET 14.16.0 [21:32:33] NODEJS selected: 1 [21:32:33] NODEJS: Installed Version: NOTSET Current Version: 14.16.0 [21:32:33] DS NOTSET 12.1.0.2855 [21:32:33] DS selected: 1 [21:32:33] DS: Installed Version: NOTSET Current Version: 12.1.0.2855 [21:32:33] DS_FLASH NOTSET 12.1.0.2855 [21:32:33] DS_FLASH selected: 1 [21:32:33] DS_FLASH: Installed Version: NOTSET Current Version: 12.1.0.2855 [21:32:33] CLOUDAGENT NOTSET 0.5.4055 [21:32:33] CLOUDAGENT selected: 1 [21:32:33] CLOUDAGENT: Installed Version: NOTSET Current Version: 0.5.4055 [21:32:33] SYSCONFIG NOTSET 1.14.0.2667 [21:32:33] SYSCONFIG selected: 1 [21:32:33] SYSCONFIG: Installed Version: NOTSET Current Version: 1.14.0.2667 [21:32:33] USERGUIDE NOTSET 12.1.0.202208311457 [21:32:33] USERGUIDE selected: 1 [21:32:33] USERGUIDE: Installed Version: NOTSET Current Version: 12.1.0.202208311457 [21:32:34] CCS_INFO: Installing PF_SITARA in /opt/ccs [21:32:34] CCS_INFO: Components default folder is set to /opt/components [21:32:34] CCS_INFO: Components override folder is set to /opt/components [21:32:34] CCS_INFO: Components default url is set to http://software-dl.ti.com/ccs/esd/CCSv12/CCS12.1.0.00007_linux-x64/components [21:32:34] CCS_INFO: Components download url is set to http://software-dl.ti.com/ccs/esd/CCSv12/CCS12.1.0.00007_linux-x64/components [21:32:34] CCS_INFO: Starting installation [21:32:34] Install Version : 12.1.0.00007 [21:32:34] Install Source : /opt [21:32:34] Install Temp : /tmp/ccs_86b626a0-0a6e-4612-7439-c54e61eebbd8 [21:32:34] Install Type : Web [21:32:34] OS : Linux [21:32:34] OS Name : Ubuntu 20.04.6 LTS [21:32:34] OS Version : 20.04 [21:32:34] OS Platform : linux-x64 64-bit [21:32:34] OSD : Ubuntu20.04.6LTS-64-bit [21:32:34] User ID : root [21:32:34] Timezone : UTC [21:32:34] InstallTime(GMT): 08/08/2024 21:32:26(GMT) [21:32:34] IPAddress : 172.17.0.2 [21:32:34] Update/Rerun : false [21:32:34] Install GUID : 86b626a0-0a6e-4612-7439-c54e61eebbd8 [21:32:34] Command line : --mode unattended --prefix /opt --enable-components PF_SITARA [21:32:34] CCS_INFO: Downloading http://software-dl.ti.com/ccs/esd/tia/CCS12.1.0.00007_tia_linux-x64_start_web.zip [21:34:44] CCS_INFO: Return values from downloadMarker http://software-dl.ti.com/ccs/esd/tia/CCS12.1.0.00007_tia_linux-x64_start_web.zip: [21:34:45] CCS_INFO: Components: [21:34:45] CCS_INFO: ARM_CGT_HELP: 1 [21:34:45] CCS_INFO: C2000_CGT_HELP: 0 [21:34:45] CCS_INFO: C6000_CGT_HELP: 1 [21:34:45] CCS_INFO: CCS_DOC: 1 [21:34:45] CCS_INFO: CCS_LAUNCHER: 1 [21:34:45] CCS_INFO: CCS_UTILS: 1 [21:34:45] CCS_INFO: CGT_DEFAULTLIBS_C2800: 0 [21:34:45] CCS_INFO: CGT_DEFAULTLIBS_C6000_V8P: 1 [21:34:45] CCS_INFO: CGT_DEFAULTLIBS_MSP430: 0 [21:34:45] CCS_INFO: CGT_DEFAULTLIBS_TMS470: 1 [21:34:45] CCS_INFO: CLOUDAGENT: 1 [21:34:45] CCS_INFO: DEV_SUPPORT_AUTOMOTIVE: 0 [21:34:45] CCS_INFO: DEV_SUPPORT_C55XX: 0 [21:34:45] CCS_INFO: DEV_SUPPORT_C6000: 0 [21:34:45] CCS_INFO: DEV_SUPPORT_CC2538: 0 [21:34:45] CCS_INFO: DEV_SUPPORT_CC26XX: 0 [21:34:45] CCS_INFO: DEV_SUPPORT_CC3220: 0 [21:34:45] CCS_INFO: DEV_SUPPORT_CC3230: 0 [21:34:45] CCS_INFO: DEV_SUPPORT_CC32XX: 0 [21:34:45] CCS_INFO: DEV_SUPPORT_CC32XX_COMMON: 0 [21:34:45] CCS_INFO: DEV_SUPPORT_DAVINCI: 0 [21:34:45] CCS_INFO: DEV_SUPPORT_INTEGRA: 0 [21:34:45] CCS_INFO: DEV_SUPPORT_MMWAVE: 0 [21:34:45] CCS_INFO: DEV_SUPPORT_OMAP: 0 [21:34:45] CCS_INFO: DEV_SUPPORT_PGA: 0 [21:34:45] CCS_INFO: DEV_SUPPORT_SHARED: 1 [21:34:45] CCS_INFO: DEV_SUPPORT_SITARA: 1 [21:34:45] CCS_INFO: DEV_SUPPORT_SITARA_MCU: 0 [21:34:45] CCS_INFO: DEV_SUPPORT_UCD31XX: 0 [21:34:45] CCS_INFO: DMED: 1 [21:34:45] CCS_INFO: DS: 1 [21:34:45] CCS_INFO: DS_FLASH: 1 [21:34:45] CCS_INFO: DVT: 0 [21:34:45] CCS_INFO: ECLIPSE: 0 [21:34:45] CCS_INFO: EMU_BH: 0 [21:34:45] CCS_INFO: EMU_C2000: 0 [21:34:45] CCS_INFO: EMU_C2000_FLASH: 0 [21:34:45] CCS_INFO: EMU_HERCULES: 0 [21:34:45] CCS_INFO: EMU_TI: 1 [21:34:45] CCS_INFO: IDE: 0 [21:34:45] CCS_INFO: IDE_CHROME: 0 [21:34:45] CCS_INFO: IDE_GC: 0 [21:34:45] CCS_INFO: IDE_TOOLS_COMMON: 0 [21:34:45] CCS_INFO: INSTALLER: 1 [21:34:45] CCS_INFO: JRE: 0 [21:34:45] CCS_INFO: KEYSTONE2: 0 [21:34:45] CCS_INFO: MSP430_BUILD_DEBUG: 0 [21:34:45] CCS_INFO: MSP430_CGT_HELP: 0 [21:34:45] CCS_INFO: MSP430_GCC_SUPPORT: 0 [21:34:45] CCS_INFO: MSP432_BUILD_DEBUG: 0 [21:34:45] CCS_INFO: MSPM0: 0 [21:34:45] CCS_INFO: NODEJS: 1 [21:34:45] CCS_INFO: P2APP: 0 [21:34:45] CCS_INFO: P2TOOLS: 0 [21:34:45] CCS_INFO: SEGGER_J_LINK: 0 [21:34:45] CCS_INFO: SYSCONFIG: 1 [21:34:45] CCS_INFO: TARGETDB_DEF_PROPS: 1 [21:34:45] CCS_INFO: TARGET_CONTENT_CORE: 1 [21:34:45] CCS_INFO: TIREX: 1 [21:34:45] CCS_INFO: TIREX4: 1 [21:34:45] CCS_INFO: TIVA_STELLARIS_DRIVERS: 0 [21:34:45] CCS_INFO: TIVA_TM4C: 0 [21:34:45] CCS_INFO: TIVA_TM4E: 0 [21:34:45] CCS_INFO: TI_ARM_CLANG: 1 [21:34:45] CCS_INFO: USERGUIDE: 1 [21:34:45] CCS_INFO: core: 1 [21:34:45] CCS_INFO: rerun/update: false Unable to download component Sitara™ AM3x, AM4x, AM5x and AM6x MPUs Automatically retrying download Unable to download component Sitara™ AM3x, AM4x, AM5x and AM6x MPUs Unable to download component Sitara™ AM3x, AM4x, AM5x and AM6x MPUs Aborting installation due to PF_SITARA download error [21:39:11] CCS_INFO: In installationAbortedActionList An issue was encountered while installing CCS. Would you like to submit the installation logs to help us diagnose and fix the issue? no [21:39:11] CCS_ERROR: Code Composer Studio 12.1.0.00007 failed to install. [21:39:11] CCS_INFO: Downloading http://software-dl.ti.com/ccs/esd/tia/CCS12.1.0.00007_tia_linux-x64_failed_web.zip [21:41:24] CCS_INFO: Return values from downloadMarker http://software-dl.ti.com/ccs/esd/tia/CCS12.1.0.00007_tia_linux-x64_failed_web.zip: [21:41:24] CCS_INFO: Deleting /opt/ccs? : !false [21:41:24] Moving logfile to /opt/ccs/install_logs/20240808213226/ccs_install_12.1.0.00007.log
Issue 2 - Failure to Write Post-install File
If I give up on Issue 1 above and simply bypass the PF_SITARA component with "--disable-components ALL", there is an error in the post-install involving a failure to write the CCSExternalReferences file. Despite the log showing "successful" installation, I cannot find the eclipse binary anywhere.
Command used: ./ccs_setup_12.1.0.00007.run --mode unattended --prefix /opt --disable-components ALL
Log started 08/08/2024 at 21:22:52 Preferred installation mode : unattended Trying to init installer in mode unattended Mode unattended successfully initialized [21:22:53] CCS_INFO: Installer timestamp 20240808212253 [21:22:53] Installer arguments --mode unattended --prefix /opt --disable-components ALL [21:22:53] CCS_INFO: Initialization sets components_download_url to http://software-dl.ti.com/ccs/esd/CCSv12/CCS12.1.0.00007_linux-x64/components [21:22:53] createshortcuts set to true [21:22:53] CCS_INFO: Temporary folder set to /tmp/ccs_4c98bb37-db14-4b59-58f3-f8d3d2a22e14 [21:22:53] CCS_INFO: Product families available: PF_MSP430,PF_MSP432,PF_CC2X,PF_CC3X,PF_CC2538,PF_C28,PF_TM4C,PF_HERCULES,PF_SITARA,PF_SITARA_MCU,PF_OMAPL,PF_DAVINCI,PF_OMAP,PF_TDA_DRA,PF_C55,PF_C6000SC,PF_C66AK_KEYSTONE,PF_MMWAVE,PF_C64MC,PF_DIGITAL_POWER,PF_PGA [21:22:53] CCS_INFO: Components available: ARM_CGT_HELP,C2000_CGT_HELP,C6000_CGT_HELP,CCS_DOC,CCS_LAUNCHER,CCS_UTILS,CGT_DEFAULTLIBS_C2800,CGT_DEFAULTLIBS_C6000_V8P,CGT_DEFAULTLIBS_MSP430,CGT_DEFAULTLIBS_TMS470,CLOUDAGENT,DEV_SUPPORT_AUTOMOTIVE,DEV_SUPPORT_C55XX,DEV_SUPPORT_C6000,DEV_SUPPORT_CC2538,DEV_SUPPORT_CC26XX,DEV_SUPPORT_CC3220,DEV_SUPPORT_CC3230,DEV_SUPPORT_CC32XX,DEV_SUPPORT_CC32XX_COMMON,DEV_SUPPORT_DAVINCI,DEV_SUPPORT_INTEGRA,DEV_SUPPORT_MMWAVE,DEV_SUPPORT_OMAP,DEV_SUPPORT_PGA,DEV_SUPPORT_SHARED,DEV_SUPPORT_SITARA,DEV_SUPPORT_SITARA_MCU,DEV_SUPPORT_UCD31XX,DMED,DS,DS_FLASH,DVT,ECLIPSE,EMU_BH,EMU_C2000,EMU_C2000_FLASH,EMU_HERCULES,EMU_TI,IDE,IDE_CHROME,IDE_GC,IDE_TOOLS_COMMON,INSTALLER,JRE,KEYSTONE2,MSP430_BUILD_DEBUG,MSP430_CGT_HELP,MSP430_GCC_SUPPORT,MSP432_BUILD_DEBUG,MSPM0,NODEJS,P2APP,P2TOOLS,SEGGER_J_LINK,SYSCONFIG,TARGETDB_DEF_PROPS,TARGET_CONTENT_CORE,TIREX,TIREX4,TIVA_STELLARIS_DRIVERS,TIVA_TM4C,TIVA_TM4E,TI_ARM_CLANG,USERGUIDE,core [21:22:53] PFsToBeInstalled: PF_MSP430 PF_MSP432 PF_CC2X PF_CC3X PF_CC2538 PF_C28 PF_TM4C PF_HERCULES PF_SITARA PF_SITARA_MCU PF_OMAPL PF_DAVINCI PF_OMAP PF_TDA_DRA PF_C55 PF_C6000SC PF_C66AK_KEYSTONE PF_MMWAVE PF_C64MC PF_DIGITAL_POWER PF_PGA [21:22:53] Running in unattended mode, must validate system. Executing /tmp/ccs_4c98bb37-db14-4b59-58f3-f8d3d2a22e14/util/dependency-checker/check_depends.sh Script exit code: 0 Script output: Installed versions of glibc and glibcxx: 2.31, N/A Required versions of glibc and glibcxx: 2.18, GLIBCXX_3.4.28 GLIBC_INSTALLED: 2.31 GLIBC_REQUIRED: 2.18 Checking availability of libraries in ext-depends.txt ... Done. Script stderr: [21:22:54] CCS_INFO:GLIBC installed: 2.31 [21:22:54] CCS_INFO: GLIBC required: 2.18 [21:22:54] CCS_INFO: Missing dependencies: [] [21:22:54] CCS_WARNING: OK Executing /tmp/ccs_4c98bb37-db14-4b59-58f3-f8d3d2a22e14/util/dependency-checker/ldcheck Script exit code: 0 Script output: Script stderr: [21:22:55] CCS_INFO: Running in unattended mode, must validate installdir /opt. [21:22:55] Logdir = /opt/ccs/install_logs/20240808212253 [21:22:55] CCS_INFO: CCStudio set to /opt/ccs/eclipse/ccstudio [21:22:55] installedProductFamilies = [21:22:55] CCS_INFO: Running fresh install in unattended mode, user provided components to be installed (PF_MSP430 PF_MSP432 PF_CC2X PF_CC3X PF_CC2538 PF_C28 PF_TM4C PF_HERCULES PF_SITARA PF_SITARA_MCU PF_OMAPL PF_DAVINCI PF_OMAP PF_TDA_DRA PF_C55 PF_C6000SC PF_C66AK_KEYSTONE PF_MMWAVE PF_C64MC PF_DIGITAL_POWER PF_PGA). [21:22:55] CCS_INFO: In selectAllComponents.xml PFList = PF_MSP430 PF_MSP432 PF_CC2X PF_CC3X PF_CC2538 PF_C28 PF_TM4C PF_HERCULES PF_SITARA PF_SITARA_MCU PF_OMAPL PF_DAVINCI PF_OMAP PF_TDA_DRA PF_C55 PF_C6000SC PF_C66AK_KEYSTONE PF_MMWAVE PF_C64MC PF_DIGITAL_POWER PF_PGA [21:22:56] CCS_INFO: setting project.component(ALL).component(core).selected to 1 [21:22:56] CCS_INFO: setting project.component(ALL).component(IDE).selected to 0 [21:22:56] CCS_INFO: setting project.component(ALL).component(DVT).selected to 0 [21:22:56] CCS_INFO: setting project.component(ALL).component(JRE).selected to 0 [21:22:56] CCS_INFO: setting project.component(ALL).component(IDE_GC).selected to 0 [21:22:56] CCS_INFO: setting project.component(ALL).component(IDE_CHROME).selected to 0 [21:22:56] CCS_INFO: setting project.component(ALL).component(IDE_TOOLS_COMMON).selected to 0 [21:22:56] CCS_INFO: setting project.component(ALL).component(P2APP).selected to 0 [21:22:56] CCS_INFO: setting project.component(ALL).component(P2TOOLS).selected to 0 [21:22:56] CCS_DOC NOTSET 12.1.0.00007 [21:22:56] CCS_DOC selected: 1 [21:22:56] CCS_DOC: Installed Version: NOTSET Current Version: 12.1.0.00007 [21:22:56] CCS_UTILS NOTSET 1.0.0.20190716 [21:22:56] CCS_UTILS selected: 1 [21:22:56] CCS_UTILS: Installed Version: NOTSET Current Version: 1.0.0.20190716 [21:22:56] CCS_LAUNCHER NOTSET 12.0.0.20220603 [21:22:56] CCS_LAUNCHER selected: 1 [21:22:56] CCS_LAUNCHER: Installed Version: NOTSET Current Version: 12.0.0.20220603 [21:22:56] TARGETDB_DEF_PROPS NOTSET 12.1.0.N202209041800 [21:22:56] TARGETDB_DEF_PROPS selected: 1 [21:22:56] TARGETDB_DEF_PROPS: Installed Version: NOTSET Current Version: 12.1.0.N202209041800 [21:22:56] INSTALLER NOTSET 12.1.0.00007 [21:22:56] INSTALLER selected: 1 [21:22:56] INSTALLER: Installed Version: NOTSET Current Version: 12.1.0.00007 [21:22:56] TARGET_CONTENT_CORE NOTSET 3.62.1.16 [21:22:56] TARGET_CONTENT_CORE selected: 1 [21:22:56] TARGET_CONTENT_CORE: Installed Version: NOTSET Current Version: 3.62.1.16 [21:22:56] TIREX NOTSET 3.8.0.201911142334 [21:22:57] TIREX selected: 1 [21:22:57] TIREX: Installed Version: NOTSET Current Version: 3.8.0.201911142334 [21:22:57] TIREX4 NOTSET 4.8.0.202106161344 [21:22:57] TIREX4 selected: 1 [21:22:57] TIREX4: Installed Version: NOTSET Current Version: 4.8.0.202106161344 [21:22:57] NODEJS NOTSET 14.16.0 [21:22:57] NODEJS selected: 1 [21:22:57] NODEJS: Installed Version: NOTSET Current Version: 14.16.0 [21:22:57] DS NOTSET 12.1.0.2855 [21:22:57] DS selected: 1 [21:22:57] DS: Installed Version: NOTSET Current Version: 12.1.0.2855 [21:22:57] DS_FLASH NOTSET 12.1.0.2855 [21:22:57] DS_FLASH selected: 1 [21:22:57] DS_FLASH: Installed Version: NOTSET Current Version: 12.1.0.2855 [21:22:57] CLOUDAGENT NOTSET 0.5.4055 [21:22:57] CLOUDAGENT selected: 1 [21:22:57] CLOUDAGENT: Installed Version: NOTSET Current Version: 0.5.4055 [21:22:57] SYSCONFIG NOTSET 1.14.0.2667 [21:22:57] SYSCONFIG selected: 1 [21:22:57] SYSCONFIG: Installed Version: NOTSET Current Version: 1.14.0.2667 [21:22:57] USERGUIDE NOTSET 12.1.0.202208311457 [21:22:57] USERGUIDE selected: 1 [21:22:57] USERGUIDE: Installed Version: NOTSET Current Version: 12.1.0.202208311457 [21:22:57] CCS_INFO: Installing PF_MSP430 PF_MSP432 PF_CC2X PF_CC3X PF_CC2538 PF_C28 PF_TM4C PF_HERCULES PF_SITARA PF_SITARA_MCU PF_OMAPL PF_DAVINCI PF_OMAP PF_TDA_DRA PF_C55 PF_C6000SC PF_C66AK_KEYSTONE PF_MMWAVE PF_C64MC PF_DIGITAL_POWER PF_PGA in /opt/ccs [21:22:57] CCS_INFO: Components default folder is set to /opt/components [21:22:58] CCS_INFO: Components override folder is set to /opt/components [21:22:58] CCS_INFO: Components default url is set to http://software-dl.ti.com/ccs/esd/CCSv12/CCS12.1.0.00007_linux-x64/components [21:22:58] CCS_INFO: Components download url is set to http://software-dl.ti.com/ccs/esd/CCSv12/CCS12.1.0.00007_linux-x64/components [21:22:58] CCS_INFO: Starting installation [21:22:58] Install Version : 12.1.0.00007 [21:22:58] Install Source : /opt [21:22:58] Install Temp : /tmp/ccs_4c98bb37-db14-4b59-58f3-f8d3d2a22e14 [21:22:58] Install Type : Web [21:22:58] OS : Linux [21:22:58] OS Name : Ubuntu 20.04.6 LTS [21:22:58] OS Version : 20.04 [21:22:58] OS Platform : linux-x64 64-bit [21:22:58] OSD : Ubuntu20.04.6LTS-64-bit [21:22:58] User ID : root [21:22:58] Timezone : UTC [21:22:58] InstallTime(GMT): 08/08/2024 21:22:53(GMT) [21:22:58] IPAddress : 172.17.0.2 [21:22:58] Update/Rerun : false [21:22:58] Install GUID : 4c98bb37-db14-4b59-58f3-f8d3d2a22e14 [21:22:58] Command line : --mode unattended --prefix /opt --disable-components ALL [21:22:58] CCS_INFO: Downloading http://software-dl.ti.com/ccs/esd/tia/CCS12.1.0.00007_tia_linux-x64_start_web.zip [21:25:11] CCS_INFO: Return values from downloadMarker http://software-dl.ti.com/ccs/esd/tia/CCS12.1.0.00007_tia_linux-x64_start_web.zip: [21:25:11] CCS_INFO: Components: [21:25:11] CCS_INFO: ARM_CGT_HELP: 0 [21:25:11] CCS_INFO: C2000_CGT_HELP: 0 [21:25:11] CCS_INFO: C6000_CGT_HELP: 0 [21:25:11] CCS_INFO: CCS_DOC: 1 [21:25:11] CCS_INFO: CCS_LAUNCHER: 1 [21:25:11] CCS_INFO: CCS_UTILS: 1 [21:25:11] CCS_INFO: CGT_DEFAULTLIBS_C2800: 0 [21:25:11] CCS_INFO: CGT_DEFAULTLIBS_C6000_V8P: 0 [21:25:11] CCS_INFO: CGT_DEFAULTLIBS_MSP430: 0 [21:25:11] CCS_INFO: CGT_DEFAULTLIBS_TMS470: 0 [21:25:11] CCS_INFO: CLOUDAGENT: 1 [21:25:11] CCS_INFO: DEV_SUPPORT_AUTOMOTIVE: 0 [21:25:11] CCS_INFO: DEV_SUPPORT_C55XX: 0 [21:25:11] CCS_INFO: DEV_SUPPORT_C6000: 0 [21:25:11] CCS_INFO: DEV_SUPPORT_CC2538: 0 [21:25:11] CCS_INFO: DEV_SUPPORT_CC26XX: 0 [21:25:11] CCS_INFO: DEV_SUPPORT_CC3220: 0 [21:25:11] CCS_INFO: DEV_SUPPORT_CC3230: 0 [21:25:11] CCS_INFO: DEV_SUPPORT_CC32XX: 0 [21:25:11] CCS_INFO: DEV_SUPPORT_CC32XX_COMMON: 0 [21:25:11] CCS_INFO: DEV_SUPPORT_DAVINCI: 0 [21:25:11] CCS_INFO: DEV_SUPPORT_INTEGRA: 0 [21:25:11] CCS_INFO: DEV_SUPPORT_MMWAVE: 0 [21:25:11] CCS_INFO: DEV_SUPPORT_OMAP: 0 [21:25:11] CCS_INFO: DEV_SUPPORT_PGA: 0 [21:25:11] CCS_INFO: DEV_SUPPORT_SHARED: 0 [21:25:11] CCS_INFO: DEV_SUPPORT_SITARA: 0 [21:25:11] CCS_INFO: DEV_SUPPORT_SITARA_MCU: 0 [21:25:11] CCS_INFO: DEV_SUPPORT_UCD31XX: 0 [21:25:11] CCS_INFO: DMED: 0 [21:25:11] CCS_INFO: DS: 1 [21:25:11] CCS_INFO: DS_FLASH: 1 [21:25:11] CCS_INFO: DVT: 0 [21:25:11] CCS_INFO: ECLIPSE: 0 [21:25:11] CCS_INFO: EMU_BH: 0 [21:25:11] CCS_INFO: EMU_C2000: 0 [21:25:11] CCS_INFO: EMU_C2000_FLASH: 0 [21:25:11] CCS_INFO: EMU_HERCULES: 0 [21:25:11] CCS_INFO: EMU_TI: 0 [21:25:11] CCS_INFO: IDE: 0 [21:25:11] CCS_INFO: IDE_CHROME: 0 [21:25:12] CCS_INFO: IDE_GC: 0 [21:25:12] CCS_INFO: IDE_TOOLS_COMMON: 0 [21:25:12] CCS_INFO: INSTALLER: 1 [21:25:12] CCS_INFO: JRE: 0 [21:25:12] CCS_INFO: KEYSTONE2: 0 [21:25:12] CCS_INFO: MSP430_BUILD_DEBUG: 0 [21:25:12] CCS_INFO: MSP430_CGT_HELP: 0 [21:25:12] CCS_INFO: MSP430_GCC_SUPPORT: 0 [21:25:12] CCS_INFO: MSP432_BUILD_DEBUG: 0 [21:25:12] CCS_INFO: MSPM0: 0 [21:25:12] CCS_INFO: NODEJS: 1 [21:25:12] CCS_INFO: P2APP: 0 [21:25:12] CCS_INFO: P2TOOLS: 0 [21:25:12] CCS_INFO: SEGGER_J_LINK: 0 [21:25:12] CCS_INFO: SYSCONFIG: 1 [21:25:12] CCS_INFO: TARGETDB_DEF_PROPS: 1 [21:25:12] CCS_INFO: TARGET_CONTENT_CORE: 1 [21:25:12] CCS_INFO: TIREX: 1 [21:25:12] CCS_INFO: TIREX4: 1 [21:25:12] CCS_INFO: TIVA_STELLARIS_DRIVERS: 0 [21:25:12] CCS_INFO: TIVA_TM4C: 0 [21:25:12] CCS_INFO: TIVA_TM4E: 0 [21:25:12] CCS_INFO: TI_ARM_CLANG: 0 [21:25:12] CCS_INFO: USERGUIDE: 1 [21:25:12] CCS_INFO: core: 1 [21:25:12] CCS_INFO: rerun/update: false Preparing to Install Preparing to Install [21:25:12] CCS_INFO: Done installing all components, doing postinstall now [21:25:12] CCS_INFO: Writing /opt/ccs/eclipse/ccs.properties [21:25:12] CCS_WARNING: Can't create CCSExternalReferences file /root/ti/CCSExternalReferences/12_1_0_00007: Error writing file /root/ti/CCSExternalReferences/12_1_0_00007 Problem running post-install step. Installation may not complete correctly Error writing file /root/ti/CCSExternalReferences/12_1_0_00007 Problem running post-install step. Installation may not complete correctly Error writing file /root/ti/CCSExternalReferences/12_1_0_00007 Creating Uninstaller Creating uninstaller 25% Creating uninstaller 50% Creating uninstaller 75% Creating uninstaller 100% Installation completed [21:25:20] CCS_INFO: Code Composer Studio 12.1.0.00007 installed successfully. [21:25:20] CCS_INFO: Downloading http://software-dl.ti.com/ccs/esd/tia/CCS12.1.0.00007_tia_linux-x64_complete_web.zip [21:27:34] CCS_INFO: Return values from downloadMarker http://software-dl.ti.com/ccs/esd/tia/CCS12.1.0.00007_tia_linux-x64_complete_web.zip: [21:27:34] Moving logfile to /opt/ccs/install_logs/20240808212253/ccs_install_12.1.0.00007.log
Experts, I need assistance in getting CCS to successfully install in my Docker Container. I have run out of ideas in tackling these two issues.
