Part Number: MCU-PLUS-SDK-AM243X
In the ESI files for EtherCAT slave examples, there are several elements ImageData16x14.
Could you share with me how these elements are generated and related reference documents?
May I know which EtherCAT example you are using and also the corresponding SDK version?
Aaron
It is this example ethercat_slave_simple_demo_am243x-lp_r5fss0-0_freertos_ti-arm-clang from Industrial communication sdk 9.2.0.8.
However, I found some tutorial else about drawing the bitmap format file. Does TI have some ready-to-use tool/script to convert an existing image to values that can be copy/pasted into ImageData16x13 field of ESI file?
Thank you for the details. I will get back to you regarding your queries by tomorrow.
Aaron
