Part Number: MSPM0G3507
Dear TI,
We are working on CAN bootloader and facing two major problems as mentioned below:
1. Jumping to application issue: We are unable to jump to the application from our customized bootloader. The program counter is not getting set as we noticed. We want a dummy code as it will help us to understand the flow if we are missing something as well as if there is some kind of configuration required for doing the same.
2. Unable to change the starting address of internal MCU flash : We tried disabling the auto linker generation and modified the starting address of the flash in the memory config section but after this we observed that our hex was inappropriate therefore leading us to a conclusion that there must be some other configuration changes or a process to achieve the same.
Hoping for a quick response.
