Part Number: AM2634-Q1
Hi Team,
This is my Code
* Copyright (C) 2023 Texas Instruments Incorporated
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* This example demonstrates the UART RX and TX operation by echoing char
* that it recieves in blocking, interrupt mode of operation.
* When user types 'quit', the application ends.
#include <string.h>
#include <kernel/dpl/DebugP.h>
#include "ti_drivers_config.h"
#include "ti_drivers_open_close.h"
#include <kernel/dpl/HwiP.h>
#include <drivers/uart/v0/lld/uart_lld.h>
#include "ti_board_open_close.h"
#include <kernel/dpl/MutexArmP.h>
#include <kernel/nortos/dpl/r5/HwiP_armv7r_vim.h>
#define APP_UART_BUFSIZE (200U)
#define APP_UART_RECEIVE_BUFSIZE (8U)
#define APP_UART_ASSERT_ON_FAILURE(transferOK, transaction) \
do { \
if((SystemP_SUCCESS != (transferOK)) || (UART_TRANSFER_STATUS_SUCCESS != transaction.status)) \
DebugP_assert(FALSE); /* UART TX/RX failed!! */ \
} while(0) \
uint8_t gUartBuffer[APP_UART_BUFSIZE];
uint8_t gUartReceiveBuffer[APP_UART_RECEIVE_BUFSIZE];
volatile uint32_t gNumBytesRead = 0U, gNumBytesWritten = 0U;
uint32_t gMutexArmWrite = MUTEX_ARM_LOCKED;
uint32_t gMutexArmRead = MUTEX_ARM_LOCKED;
/* UART Driver handles */
UARTLLD_Handle gUartHandle0;
static __attribute__((target("arm"), aligned(4))) void App_UART_ISR(void);
uint32_t gUartVimStsAddr;
uint32_t gUartVimStsClrMask;
uint32_t intcBaseAddr;
uint32_t intrNum;
void uart_echo_dma_interrupt_lld(void *args)
int32_t transferOK;
UART_Transaction trans;
Drivers_open();
Board_driversOpen();
DebugP_log("[UART] Echo example started ...\r\n");
gUartObject[CONFIG_UART_CONSOLE].writeTransferMutex = &gMutexArmWrite;
gUartObject[CONFIG_UART_CONSOLE].readTransferMutex = &gMutexArmRead;
gUartObject[CONFIG_UART_CONSOLE].hUartInit->readReturnMode = UART_READ_RETURN_MODE_PARTIAL;
gUartHandle0 = &gUartObject[CONFIG_UART_CONSOLE];
intrNum = gUartInitObject[CONFIG_UART_CONSOLE].intrNum;
intcBaseAddr = gHwiConfig.intcBaseAddr;
gUartVimStsAddr = gHwiConfig.intcBaseAddr + (0x404u + (((intrNum)>> 5) & 0xFu) * 0x20u);
gUartVimStsClrMask = 0x1u << ((intrNum) & 0x1Fu);
HwiP_setVecAddr(intrNum, (uintptr_t)&App_UART_ISR);
HwiP_setPri(intrNum, gUartInitObject[CONFIG_UART_CONSOLE].intrPriority);
HwiP_enableInt(intrNum);
UART_lld_Transaction_init(&trans);
/* Sending in DMA mode */
/* Send entry string */
trans.buf = &gUartBuffer[0U];
strncpy(trans.buf,"This is uart echo test blocking mode\r\nReceives 8 characters then echo's back. Please input..\r\n", APP_UART_BUFSIZE);
trans.count = strlen(trans.buf);
CacheP_wb((void *)trans.buf, trans.count, CacheP_TYPE_ALL);
transferOK = UART_lld_writeDma(gUartHandle0, trans.buf, trans.count, NULL);
while(try_lock_mutex(gUartObject[CONFIG_UART_CONSOLE].writeTransferMutex) == MUTEX_ARM_LOCKED);
APP_UART_ASSERT_ON_FAILURE(transferOK, trans);
/* Receiving in interrupt mode */
/* Read 8 chars */
gNumBytesRead = 0U;
trans.buf = &gUartReceiveBuffer[0U];
trans.count = APP_UART_RECEIVE_BUFSIZE;
transferOK = UART_lld_readIntr(gUartHandleLld[CONFIG_UART_CONSOLE], trans.buf, trans.count, NULL);
while(try_lock_mutex(gUartObject[CONFIG_UART_CONSOLE].readTransferMutex) == MUTEX_ARM_LOCKED);
/* Echo chars entered */
transferOK = UART_lld_writeDma(gUartHandleLld[CONFIG_UART_CONSOLE], trans.buf, trans.count, NULL);
/* Send exit string */
/* Sending in interrupt mode */
strncpy(trans.buf, "\r\nAll tests have passed!!\r\n", APP_UART_BUFSIZE);
transferOK = UART_lld_writeIntr(gUartHandle0, trans.buf, trans.count, NULL);
DebugP_log("All tests have passed!!\r\n");
Board_driversClose();
Drivers_close();
return;
static __attribute__((noinline, naked, target("arm"), aligned(4))) void App_UART_ISR(void)
ISR_CALL_LEVEL_NONFLOAT_REENTRANT(UART_lld_controllerIsr, gUartHandle0, \
intrNum, gUartVimStsAddr, \
gUartVimStsClrMask, intcBaseAddr);
void UART_lld_writeCompleteCallback(void *args)
unlock_mutex(gUartObject[CONFIG_UART_CONSOLE].writeTransferMutex);
return;
void UART_lld_readCompleteCallback(void *args)
unlock_mutex(gUartObject[CONFIG_UART_CONSOLE].readTransferMutex);
return;
and this is my main function
* Copyright (C) 2018-2022 Texas Instruments Incorporated
* are met:
* distribution.
#include <stdlib.h>
#include "ti_board_config.h"
#include "uart_tx_rx.h"
* this is the testing of the Clang-Format with this current project having
* clang format with in the project directory
void uart_echo_dma(void *args);
int main(void) {
System_init();
Board_init();
while(1) {
uart_echo_dma(NULL);
Board_deinit();
System_deinit();
return 0;
i don't want to use this while function to communicate between 2 uart continuously i want these callback function handle the communication (I am using DMA mode)
