Part Number: TMS570LS1227
Other Parts Discussed in Thread: HALCOGEN,
I’ve integrated the Mongoose Ethernet stack, and it's working fine. However, I’m encountering an issue with the Dp83640LinkStatusGet() API used to check the link status.
Working:
- When I dump the code, the link is established, and ping works. It also functions correctly if I remove and reconnect the cable multiple times without a power cycle.
Not Working:
- After a power cycle, the link does not come up. The
Dp83640LinkStatusGet()function is called, but the link remains down.
IDE Details:
- Code Composer Studio: Version 12.7.1.00001
- HALCoGen: Version 04.07.01
Boards details:
EVK: Hercules texas intruments
Controller: TMS570LS1227
link: https://www.digikey.in/en/products/detail/texas-instruments/TMDS570LS12HDK/5067066?cur=INR&lang=en
Note: I generated the code as outlined in the HALCoGen IDE under: Help -> Help Topics -> Examples -> example_EMAC_Loopback_TxRx.c. I have verified the configurations are same.
Any suggestions on how to resolve the issue?
Sandeep C
FILES:
