Part Number: MSPM0L2228
Could you please tell me how to prevent wake-up by RTCRDY interrupt while in standby mode?
To achieve this, I wrote 0xA9000100h to the RTC.CLKCFG register and enabled the RTCRDY interrupt as shown below:
1. Write 0xA9000100h to the RTC.CLKCFG register
using the TI sample (rtc_a_tamper_timestamp_event) and Add RTC_A->GPRCM.CLKCFG = 0xA9000100U; to line 44.
* Copyright (c) 2021, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "ti/devices/msp/peripherals/hw_rtc.h"
#include "ti_msp_dl_config.h"
volatile bool gCheckTSEVT = false;
volatile uint32_t counter = 0;
volatile uint8_t gBlink;
int main(void)
/* Initialization */
SYSCFG_DL_init();
/* Enable the RTC interrupt at NVIC */
NVIC_EnableIRQ(RTC_A_INT_IRQn);
/* Start RTC clock */
DL_RTC_A_enableClockControl(RTC_A);
while (1) {
__WFI();
/* Wait in a while() loop until the time stamp interrupt triggers - Trigger a tamper event externally */
while (gCheckTSEVT == false)
/* Blink LED a number of times equal to amount of time stamp events detected */
if (DL_RTC_A_getTimeStampEventCause(
RTC_A, DL_RTC_A_TIME_STAMP_EVENT_CAUSE_TIO_0) ==
DL_RTC_A_TIME_STAMP_EVENT_CAUSE_TIO_0) {
for (gBlink = 0; gBlink < (2 * counter); gBlink++) {
DL_GPIO_togglePins(GPIO_LEDS_PORT, GPIO_LEDS_USER_LED_1_PIN);
delay_cycles(16000000);
void LFSS_IRQHandler()
switch (DL_RTC_A_getPendingInterrupt(RTC_A)) {
case DL_RTC_A_IIDX_TSEVT:
counter++;
gCheckTSEVT = true;
default:
break;
2. Enable the RTCRDY interrupt.
However, the Default_Handler was called when the registers were set.
Are there any correct settings or other methods?
Sho Takayama
