Part Number: MSPM0G3107
Other Parts Discussed in Thread: SYSCONFIG,
Hi team,
Could you please give feedback on the following questions from my customer?
1. We would like to ask you about clocks.
What is the difference between LFCLK and ULPCLK? I would like you to tell me how to use it properly.
Also, when is "MFCLK" used? Please tell me how to use it with "MCLK".
2. We would like to ask you a few questions about handling unused pins.
① As described in the Comment column below, do they have to assign output and input to GPIO for all unused pins? Or is it possible to simply not assign pins in SysConfig?
② What is the value of this resistor when internal pullup/pulldown is used?
③ Is it correct to understand that both internal pullup and pulldown are disabled (i.e. IO pin is Hi-Z) until the configuration of the user program?
④In the Japan version of the hardware development guide, it is written in the "Note" part of the table below that you can refer to the connection guidelines for unused pins of "PAx", but they could not find it.
Where can they check from?
Thank you in advance.
Kenley
