Part Number: LP-AM243
Other Parts Discussed in Thread: AM2434, UNIFLASH
Hi Ti-experts,
I am stuck at this point, while i am try to upload the code in Am243x-lp
MAIN_Cortex_R5_0_1: AM2434_ALX
MAIN_Cortex_R5_0_1: GEL Output: CPU reset (soft reset) has been issued through GEL.
MAIN_Cortex_R5_0_1: Trouble Writing Memory Block at 0x0 on Page 0 of Length 0x140: (Error -1065 @ 0x140) Unable to access device memory. Verify that the memory address is in valid memory. If error persists, confirm configuration, power-cycle board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 12.8.0.00189)
MAIN_Cortex_R5_0_1: File Loader: Verification failed: Target failed to write 0x00000000
MAIN_Cortex_R5_0_1: GEL: File: D:\27-09-2024-2\hello_world_am243x-lp_m4fss0-0_freertos_ti-arm-clang\Debug\hello_world_am243x-lp_m4fss0-0_freertos_ti-arm-clang.out: Load failed.
I tried with 2 diff. Power supply which have 5v 3A.
My debug point,
1) Green light working:- Means power done
2) xds110 uart port shows in device manager
3) Targe set :-AM243x_LAUNCHPAD in target configuration
4) I tried with pin set 11100000(UART mode),USB-dfu 01010000 and 01000100(QSPI mode). All cases got same error.
(pin set 12345678).
Considered Ref. URL :-
1)https://software-dl.ti.com/mcu-plus-sdk/esd/AM243X/latest/exports/docs/api_guide_am243x/EVM_SETUP_PAGE.html#EVM_CABLES
2)https://software-dl.ti.com/mcu-plus-sdk/esd/AM243X/latest/exports/docs/api_guide_am243x/EXAMPLES_DRIVERS_SBL_DFU_UNIFLASH.html
3) https://software-dl.ti.com/mcu-plus-sdk/esd/AM243X/latest/exports/docs/api_guide_am243x/EXAMPLES_USB_DFU.html
4)https://software-dl.ti.com/mcu-plus-sdk/esd/AM243X/latest/exports/docs/api_guide_am243x/EVM_SETUP_PAGE.html#CCS_UART_TERMINAL
5)https://software-dl.ti.com/mcu-plus-sdk/esd/AM243X/latest/exports/docs/api_guide_am243x/EVM_SETUP_PAGE.html#EVM_FLASH_SOC_INIT
6)https://software-dl.ti.com/mcu-plus-sdk/esd/AM243X/latest/exports/docs/api_guide_am243x/TOOLS_FLASH.html#TOOLS_FLASH_ERROR_MESSAGES
Thanks in Advance.
