Part Number: SM470R1B1M-HT
Hello, I am a junior engineer, and I have been working with this ARM processor. We have been running into issues when programming and this has been a reoccurring issue since its design. The unit is being programmed via JTAG port and the programming software we are using are Laturbach and Trace32. This is a fairly old design, but we have always experienced inconsistencies when programming the unit. About 1 out of every 5 units turn out with this same issue. Generally, replacing the ARM processor has showed a 50 percent success chance. We would have the failed units x-rayed and it showed no solder bridges or other manufacturing defects.
I am unsure what else to look into. I have checked for proper clock signals, proper power, there are no shorts. I have also unlimited the current from the power supply after verifying that there are no shorts. I have attached a schematic of the circuit here.
