Part Number: MSPM0L1228
I have 2 questions.
1.
I have tried to PWM output in TIMG0, TIMG5 Timer with PA13 and PA14 Pin.
The PWM output is output at an irregular pulse in oscilloscope.
Other Pin(PA7 or PA8) would be normal PWM output with same settings.
Could you please give me some advice on what to do to solve this issue?
SysConfig setting and irregular pulse
2.
I started only the TIMG0 Timer on PA13,
but for some reason PWM pluse is also output from the PA14 pin.
Even if I start the PWM on PA14, PWM is also output from the PA13 pin.
I would appreciate any advice on solving this problem.
Both irregular pulse
Insang Chung
