Part Number: AM2432
Other Parts Discussed in Thread: AM2434
Hi Experts,
Currently, we are working on the board bring up process for the custom board that we created using the AM2432 BSFFHIALXR SOC.
We successfully parsed the sbl_null and sbl.ospi.cfg in UART mode after setting up the device in UART boot mode and first making sure the character "C" was present in the serial terminal.
After that, we returned to QSPI boot mode, however the serial terminal did not display the desired outcome. The configured serial port will not receive anything (such as "Hello world printing in loop").
The default flash that came with the AM2434 LP is what we are using it.
When switching back to the QSPI mode, we verified that the same application image that had been parsed to AM2434 LP produced the expected result. However the Custom board did not giving the expected result.
What do you suspect will be the problem in this case?
Chockalingam
