AM2634: DMA transfer copies wrong data
Part Number: AM2634
Dear TI support,
I have issue in copying data from external flash to RAM using DMA enabled flash MCAL.
Used package: MCAL_AM263x_09.01.00_Fls_Dma
Flash Range:  0xa0000--0xc0743
RAM Range: 0x70020000--0x7004073F
Difference in RAM and Flash contents always occur starting at 0x17400 offset.
Difference in RAM and Flash is also consistent which means rerunning same code produces same differences in data.
Danish
  • Hi Danish,
    Thanks for your query we are looking into this issue, please expect a dely in response as we our experts are on leave and will be back by 4th Nov.
  • Hello Danish,
    Can you re-confirm your MCAL package version? Because FLS in DMA mode is not supported in MCAL 09.01.00 (4.12. FLS — Platform MCAL Development - AM263 User Guide).
    Gunjan
  • Hi Gunjan,
    We received a pre-release that is why the version was still 9.1... Anyway i checked with 9.2 MCAL package and the issue persists so you can start using 9.2 MCAL version package to reproduce this issue. Do you need any additional information to continue investigation?
    One additional point to note is that issue may not happen if Read Length for above given use case is changed from 132,932 to 132,928.
    Danish
  • Hi Danish,
    Thanks for adding this point.
    I have tested MCAL FLS DMA functionality with data size as 132932, it is working fine for me.
    Can you share your Fls_Qspi.c file from location: "MCAL_install_path\mcal\Fls\V0\Fls_Qspi.c". I think at your end it is failing mostly for lengths which are not proper multiple of 8.
    Gunjan
    * Copyright (c) 2023 Texas Instruments Incorporated
    * All rights reserved not granted herein.
    * Limited License.
    * Texas Instruments Incorporated grants a world-wide, royalty-free, non-exclusive
    * license under copyrights and patents it now or hereafter owns or controls to make,
    * have made, use, import, offer to sell and sell ("Utilize") this software subject to the
    * terms herein.  With respect to the foregoing patent license, such license is granted
    * solely to the extent that any such patent is necessary to Utilize the software alone.
    * The patent license shall not apply to any combinations which include this software,
    * other than combinations with devices manufactured by or for TI ("TI Devices").
    * No hardware patent is licensed hereunder.
    * Redistributions must preserve existing copyright notices and reproduce this license
    * (including the above copyright notice and the disclaimer and (if applicable) source
    * code license limitations below) in the documentation and/or other materials provided
    * with the distribution
    * Redistribution and use in binary form, without modification, are permitted provided
    * that the following conditions are met:
    * No reverse engineering, decompilation, or disassembly of this software is
    * permitted with respect to any software provided in binary form.
    * any redistribution and use are licensed by TI for use only with TI Devices.
    * Nothing shall obligate TI to provide you with source code for the software
    * licensed and provided to you in object code.
    * If software source code is provided to you, modification and redistribution of the
    * source code are permitted provided that the following conditions are met:
    * any redistribution and use of the source code, including any resulting derivative
    * works, are licensed by TI for use only with TI Devices.
    * any redistribution and use of any object code compiled from the source code
    * and any resulting derivative works, are licensed by TI for use only with TI Devices.
    * Neither the name of Texas Instruments Incorporated nor the names of its suppliers
    * may be used to endorse or promote products derived from this software without
    * specific prior written permission.
    * DISCLAIMER.
    * THIS SOFTWARE IS PROVIDED BY TI AND TI'S LICENSORS "AS IS" AND ANY EXPRESS
    * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
    * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
    * IN NO EVENT SHALL TI AND TI'S LICENSORS BE LIABLE FOR ANY DIRECT, INDIRECT,
    * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
    * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
    * OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
    * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
    * OF THE POSSIBILITY OF SUCH DAMAGE.
     *  \file   Fls_QSPI.c
     *  \brief  QSPI  specific driver APIs implementation.
     *   This file contains the driver APIs for QSPI controller.
    /*                             Include Files                                  */
    #include "string.h"
    #include "Fls_Qspi.h"
    #include "Fls_Brd_Nor.h"
    #include "hal_stdtypes.h"
    #include "Fls_Qspi_Edma.h"
    /* This is needed for memset/memcpy */
    /*                           Macros & Typedefs                                */
    /** \brief    QSPI Command default Length in SPI words */
    #define QSPI_CMD_LEN            (1U)
    /** \brief    QSPI Address default Length in SPI words */
    #define QSPI_ADDR_LEN            (1U)
    /** \brief    QSPI Operation mode- Configuration or memory mapped mode */
    #define QSPI_MEM_MAP_PORT_SEL_CFG_PORT          \
                                    (QSPI_SPI_SWITCH_REG_MMPT_S_SEL_CFG_PORT)
    #define QSPI_MEM_MAP_PORT_SEL_MEM_MAP_PORT      \
                                    (QSPI_SPI_SWITCH_REG_MMPT_S_SEL_MM_PORT)
    /** \brief    QSPI Read Type - Single, Dual or Quad */
    #define QSPI_MEM_MAP_READ_TYPE_NORMAL               \
                                    (QSPI_SPI_SETUP0_REG_READ_TYPE_NORMAL_READ)
    #define QSPI_MEM_MAP_READ_TYPE_DUAL                 \
                                    (QSPI_SPI_SETUP0_REG_READ_TYPE_DUAL_READ)
    #define QSPI_MEM_MAP_READ_TYPE_NORMAL_READTYPE      \
                                    (QSPI_SPI_SETUP0_REG_READ_TYPE_NORMAL_READ_TYPE)
    #define QSPI_MEM_MAP_READ_TYPE_QUAD                 \
                                    (QSPI_SPI_SETUP0_REG_READ_TYPE_QUAD_READ)
    /*                         Structure Declarations                             */
    typedef struct
        sint32                count;
        /**< [IN] Number of frames for this transaction */
        void                   *buf;
        /**< [IN] void * to a buffer to receive/send data */
        uint32                wlen;
        /**< [IN] word length to be used for this transaction. */
        uint32                cmdRegVal;
        /**< [IN] cmd register value to be written. */
    } QSPI_ConfigAccess;
    /*                          Function Declarations                             */
    /* Internal functions */
    static Std_ReturnType Fls_Qspi_WaitIdle(QSPI_Handle handle);
    static Std_ReturnType Fls_Qspi_MemMapRead(QSPI_Handle handle);
    static void Fls_Qspi_MemMapRead_sub(void);
    static Std_ReturnType Fls_Qspi_ConfigRead(QSPI_Handle handle, QSPI_ConfigAccess *cfgAccess);
    static Std_ReturnType Fls_Qspi_ConfigWrite(QSPI_Handle handle, QSPI_ConfigAccess *cfgAccess);
    static void Fls_Qspi_ConfigWrite_sub(QSPI_Handle handle, QSPI_ConfigAccess *cfgAccess, uint32 wordLenBytes);
    static Std_ReturnType Fls_Qspi_ProgramInstance(QSPI_Config *config);
    static Std_ReturnType Fls_Qspi_ReadData(QSPI_Handle handle, uint32 *data, uint32 length);
    static Std_ReturnType Fls_Qspi_WriteData(QSPI_Handle handle, const uint32 *data, uint32 length);
    static void QSPI_delay(uint32 delay);
    /*                            Global Variables                                */
    #define FLS_START_SEC_VAR_NO_INIT_UNSPECIFIED
    #include "Fls_MemMap.h"
    /** \brief Driver object */
    VAR(QSPI_Object, FLS_VAR_NO_INIT) Fls_QspiObjects[1];
    #define FLS_STOP_SEC_VAR_NO_INIT_UNSPECIFIED
    #define FLS_START_SEC_VAR_INIT_UNSPECIFIED
    /* QSPI driver configuration */
    VAR(QSPI_Config, FLS_VAR_INIT) Fls_QspiConfig[1] =
            &Fls_QspiObjects[0]
    #define FLS_STOP_SEC_VAR_INIT_UNSPECIFIED
    #define FLS_START_SEC_VAR_INIT_32
    VAR(uint32, FLS_VAR_INIT) Fls_QspiConfigNum = 1;
    #define FLS_STOP_SEC_VAR_INIT_32
    /*                          Function Definitions                              */
    #define FLS_START_SEC_CODE
     *  \Function Name: Fls_hwi
     *  This function check the Hardware interrupt status register. if interrupt is
     *  occured then perform the corresponding operation and this function call is
     *  in Fls_Irq.c file.
    void Fls_hwi(void)
        #if (STD_ON == FLS_USE_INTERRUPTS)
            uint32 intrStatus = 0u;
            intrStatus = HW_RD_REG32(FLS_QSPI_CTRL_BASE_ADDR+INTR_STATUS_RAW_SET);
            if((uint32)QSPI_INTR_STATUS_MASK == (uint32)(intrStatus & QSPI_INTR_STATUS_MASK))
                if(Fls_DrvObj.jobType != FLS_JOB_NONE)
                    /* Process the job. */
                    processJobs(Fls_DrvObj.jobType);
                    Fls_QspiIntDisable((QSPI_INTR_ENABLE_SET_REG_FIRQ_ENA_SET_MASK |
                                        QSPI_INTR_ENABLE_SET_REG_WIRQ_ENA_SET_MASK));
                    Fls_QspiIntClear((QSPI_INTR_ENABLE_SET_REG_FIRQ_ENA_SET_MASK |
                    /* Check if , job is none. */
                        Fls_QspiIntEnable((QSPI_INTR_ENABLE_SET_REG_FIRQ_ENA_SET_MASK |
            else
                /* disable and clear the interrupts */
        #endif
     *  \Function Name: Fls_QspiHwInit
     *   This function initializes the QSPI module
    void Fls_QspiHwInit(void)
        QSPI_Object *qspi_Obj;
        qspi_Obj = Fls_QspiConfig[0].object;
        memset(qspi_Obj, 0, sizeof(QSPI_Object));
    	qspi_Obj->isOpen = FALSE;
     *  \Function Name: Fls_QspiOpen
     *   This function opens a given QSPI peripheral.
    QSPI_Handle Fls_QspiOpen(uint32 index)
        Std_ReturnType retVal = E_OK;
        QSPI_Handle handle = NULL;
        QSPI_Config *config = NULL;
        QSPI_Object *obj = NULL;
        /* Check for valid index */
        if(index >= Fls_QspiConfigNum)
            retVal = E_NOT_OK;
        else
            config = &Fls_QspiConfig[index];
        if(E_OK == retVal)
            obj = config->object;
            if(TRUE == obj->isOpen)
                /* Handle already opened */
                retVal = E_NOT_OK;
        if(E_OK == retVal)
            obj->handle = (QSPI_Handle)config;
            /* Program QSPI instance according the user config */
            retVal = Fls_Qspi_ProgramInstance(config);
        if(E_OK == retVal)
            obj->isOpen = TRUE;
            handle = (QSPI_Handle) config;
        if(E_OK != retVal)
            if(NULL != config)
                Fls_QspiClose((QSPI_Handle) config);
        return handle;
     *  \Function Name: Fls_QspiClose
     *   Function to close a QSPI peripheral specified by the QSPI handle.
    void Fls_QspiClose(QSPI_Handle handle)
        if(handle != NULL_PTR)
            QSPI_Object *obj = ((QSPI_Config *)handle)->object;
            obj->isOpen = FALSE;
        return;
     *  \Function Name: Fls_Qspi_ProgramInstance
     *   Function configure QSPI Parameter such as QSPI pin and baudrate
        QSPI_Object *obj = config->object;
        QSPI_Handle handle = (QSPI_Handle)config;
        uint32 regVal;
        obj->rxLines  = Fls_DrvObj.Fls_Mode;
        /* Set the idle mode value */
        HW_WR_FIELD32(((uint32)(FLS_QSPI_CTRL_BASE_ADDR+SYSCONFIG)), QSPI_SYSCONFIG_IDLE_MODE,
                       QSPI_SYSCONFIG_IDLE_MODE_NO_IDLE);
        regVal = HW_RD_REG32(FLS_QSPI_CTRL_BASE_ADDR+SPI_DC_REG);
        regVal &= (uint32)(~((FLS_QSPI_FF_POL1_PHA1) << (8U * FLS_QSPI_CS0)));
        regVal |= (FLS_QSPI_FF_POL0_PHA0 << (8U * FLS_QSPI_CS0));
        regVal &= (uint32)(~((FLS_QSPI_CS_POL_ACTIVE_HIGH) << (QSPI_SPI_DC_REG_CSP0_SHIFT +
                                         (8U * FLS_QSPI_CS0))));
        regVal |= (FLS_QSPI_CS_POL_ACTIVE_LOW << (QSPI_SPI_DC_REG_CSP0_SHIFT +
        regVal &= (uint32)(~((FLS_QSPI_DATA_DELAY_3) << (QSPI_SPI_DC_REG_DD0_SHIFT +
        regVal |= (FLS_QSPI_DATA_DELAY_0 << (QSPI_SPI_DC_REG_DD0_SHIFT +
        retVal = Fls_Qspi_WaitIdle(handle);
    	if(retVal == E_OK)
    		HW_WR_REG32(FLS_QSPI_CTRL_BASE_ADDR+SPI_DC_REG, regVal);
    		/* Enable clock and set divider value */
    		if (Fls_Qspi_SetPreScaler(handle, Fls_DrvObj.flsBaudRateDiv) == E_OK)
    			/* Clear the interrupts and interrupt status */
    		else
    			retVal = E_NOT_OK;
    		HW_WR_FIELD32(FLS_QSPI_CTRL_BASE_ADDR+SPI_SWITCH_REG, QSPI_SPI_SWITCH_REG_MMPT_S,
                        QSPI_MEM_MAP_PORT_SEL_MEM_MAP_PORT);
    	else
    		retVal = E_NOT_OK;
        return retVal;
     *  \Function Name: Fls_Qspi_SetPreScaler
     *   Function Set the QSPI clock register divider value
    Std_ReturnType Fls_Qspi_SetPreScaler(QSPI_Handle handle, uint32 clkDividerVal)
        Std_ReturnType status = E_OK;
            uint32 regVal;
            /* Read the value of Clock control register */
            regVal = HW_RD_REG32(FLS_QSPI_CTRL_BASE_ADDR+SPI_CLOCK_CNTRL_REG);
            /* wait for QSPI to be idle */
            status = Fls_Qspi_WaitIdle(handle);
            /* turn off QSPI data clock */
            HW_SET_FIELD32(regVal, QSPI_SPI_CLOCK_CNTRL_REG_CLKEN,
                QSPI_SPI_CLOCK_CNTRL_REG_CLKEN_DCLOCK_OFF);
            /* Set the value of QSPI clock control register */
            HW_WR_REG32(FLS_QSPI_CTRL_BASE_ADDR+SPI_CLOCK_CNTRL_REG, regVal);
            /* Set the QSPI clock divider bit field value*/
            HW_SET_FIELD32(regVal, QSPI_SPI_CLOCK_CNTRL_REG_DCLK_DIV,
                clkDividerVal);
            /* Enable the QSPI data clock */
                        QSPI_SPI_CLOCK_CNTRL_REG_CLKEN_DCLOCK_ON);
        else
            status = E_NOT_OK;
        return status;
     *  \Function Name: Fls_Qspi_WaitIdle
     *   Wait while QSPI is busy
    	uint32 timeout = FLS_MAX_WRITE_TIME;
            /* wait while QSPI is busy */
           do
    			if(((HW_RD_REG32(FLS_QSPI_CTRL_BASE_ADDR+SPI_STATUS_REG) & QSPI_SPI_STATUS_REG_BUSY_MASK) !=
                QSPI_SPI_STATUS_REG_BUSY_BUSY))
    				break;
    			timeout--;
            }while(timeout != 0U);
    		if(timeout == 0U)
    			status = E_NOT_OK;
        else
            status = E_NOT_OK;
        return status;
     *  \Function Name: Fls_QspiIntEnable
     *   This function is used to enable word or frame complete interrupt
    void Fls_QspiIntEnable(uint32 intFlag)
        uint32 regVal;
        regVal = HW_RD_REG32(FLS_QSPI_CTRL_BASE_ADDR+QSPI_INTR_STATUS_RAW_SET);
        regVal |= ( QSPI_SPI_CMD_REG_WIRQ_WORD_COUNT_IRQ_ENABLE << 1 ) |QSPI_SPI_CMD_REG_FIRQ_FRAME_COUNT_IRQ_ENABLE;
        HW_WR_REG32((FLS_QSPI_CTRL_BASE_ADDR+QSPI_INTR_STATUS_RAW_SET), regVal);
        regVal = HW_RD_REG32(FLS_QSPI_CTRL_BASE_ADDR+QSPI_INTR_ENABLE_SET_REG);
        regVal |= intFlag;
        HW_WR_REG32((FLS_QSPI_CTRL_BASE_ADDR+INTR_ENABLE_SET_REG), regVal);
     *  \Function Name: Fls_QspiIntDisable
     *   This function is used to disable word or frame complete interrupt
    void Fls_QspiIntDisable(uint32 intFlag)
        uint32 regVal;
        regVal = HW_RD_REG32(FLS_QSPI_CTRL_BASE_ADDR+INTR_ENABLE_CLEAR_REG);
        regVal |= intFlag;
        HW_WR_REG32((FLS_QSPI_CTRL_BASE_ADDR+INTR_ENABLE_CLEAR_REG), regVal);
     *  \Function Name: Fls_QspiIntClear
     *   This function is used to clear word or frame complete interrupt
    void Fls_QspiIntClear(uint32 intFlag)
        uint32 regVal;
        regVal = HW_RD_REG32(FLS_QSPI_CTRL_BASE_ADDR+INTR_STATUS_ENABLED_CLEAR);
        regVal |= intFlag;
        HW_WR_REG32(FLS_QSPI_CTRL_BASE_ADDR+INTR_STATUS_ENABLED_CLEAR, regVal);
    	HW_WR_REG32(FLS_QSPI_CTRL_BASE_ADDR+INTC_EOI_REG,QSPI_INTC_EOI_REG_EOI_VECTOR_RESETVAL);
     *  \Function Name: Fls_Qspi_WriteData
     *   This function is used to Write the Data to QSPI DATA register
        const uint32 *pData;
        pData = data;
            if(pData != ((void *) NULL))
                HW_WR_REG32(FLS_QSPI_CTRL_BASE_ADDR+SPI_DATA_REG, (uint32)*pData);
    		else
    			status = E_NOT_OK;
        else
            status = E_NOT_OK;
        return status;
     *  \Function Name: Fls_Qspi_ReadData
     *   This function is used to Read the Data from QSPI DATA register
        uint32 *pData = (uint32 *)NULL_PTR;
        pData = data;
                *pData = HW_RD_REG32(FLS_QSPI_CTRL_BASE_ADDR+SPI_DATA_REG);
    		else
    			status = E_NOT_OK;
        else
            status = E_NOT_OK;
        return status;
     *  \Function Name: Fls_Qspi_TransactionInit
     *   Function to initialize the QSPI_Transaction structure
    void Fls_Qspi_TransactionInit(QSPI_Transaction *trans)
        if( trans != NULL)
            trans->count = 0U;
            trans->buf = NULL;
            trans->addrOffset = 0U;
            trans->status = SPI_TRANSFER_STARTED;
     *  \Function Name: Fls_Qspi_ParamsInit
     *   Initialize data structure with defaults
    Std_ReturnType Fls_Qspi_ParamsInit(QSPI_CmdParams *QSPI_Params)
        if( QSPI_Params != NULL)
            QSPI_Params->cmd = FLS_QSPI_CMD_INVALID_OPCODE;
            QSPI_Params->cmdAddr = FLS_QSPI_CMD_INVALID_ADDR;
            QSPI_Params->numAddrBytes = 3U;
            QSPI_Params->txDataBuf = NULL;
    		QSPI_Params->rxDataBuf = NULL;
            QSPI_Params->DataLen = 0U;
    		retVal = E_OK;
    	else
    		retVal = E_NOT_OK;
    	return retVal;
     *  \Function Name: Fls_Qspi_ConfigWrite
     *   It will configure the QSPI write opearation
        /* Source address */
        uint8 *srcAddr8 = NULL;
        uint32 *srcAddr32 = NULL;
        uint32 wordLenBytes;
        /* Data to be written */
        uint32 dataVal[4] = {0};
        if (cfgAccess->wlen <= (uint32)8)
            srcAddr8 = (uint8 *)(cfgAccess->buf);
            wordLenBytes = (uint32)1;
        else
            srcAddr32 = (uint32 *)(cfgAccess->buf);
            wordLenBytes = (uint32)4;
        /* Write the data into shift registers */
        while(cfgAccess->count > (sint32)0)
            dataVal[0] = (uint32)0;
            if (wordLenBytes == (uint32)1)
                dataVal[0] = *srcAddr8;
                srcAddr8++;
            else
                dataVal[0] = *srcAddr32;
                srcAddr32++;
            /* Write data to data registers */
            status = Fls_Qspi_WriteData(handle, &dataVal[0], 1U);
    		if(status == E_OK)
    		 Fls_Qspi_ConfigWrite_sub(handle, cfgAccess, wordLenBytes);
    		else
    			status = E_NOT_OK;
    			break;
        return status;
    		/* Wait for the QSPI busy status */
    			if(Fls_Qspi_WaitIdle(handle) == E_OK)
    			QSPI_delay(FLS_QSPI_CMD_DELAY);
    			/* Write tx command to command register */
    			HW_WR_REG32(FLS_QSPI_CTRL_BASE_ADDR+SPI_CMD_REG, cfgAccess->cmdRegVal);
    				if (Fls_Qspi_WaitIdle(handle) == E_OK)
    					/* update the cmd Val reg by reading it again for next word. */
    					cfgAccess->cmdRegVal = HW_RD_REG32(FLS_QSPI_CTRL_BASE_ADDR+SPI_CMD_REG);
    					/* Update the number of bytes to be transmitted */
    					cfgAccess->count -= (sint32)wordLenBytes;
     *  \Function Name: Fls_Qspi_ConfigRead
     *   It will configure the QSPI Read opearation
        uint8 *dstAddr8 = NULL;
        uint32 *dstAddr32 = NULL;
        if (cfgAccess->wlen <= (uint32)8U)
            dstAddr8 = (uint8 *)(cfgAccess->buf);
            wordLenBytes = 1U;
        else
            dstAddr32 = (uint32 *)(cfgAccess->buf);
            wordLenBytes = 4U;
        while((cfgAccess->count) != (sint32) 0U)
            /* Store the number of data registers needed to read data */
            status = Fls_Qspi_ReadData(handle, &dataVal[0], 1U);
    		if(status == E_OK)
            if (wordLenBytes == (uint32)1U)
                *dstAddr8 = (uint8) dataVal[0];
                dstAddr8++;
            else
                *dstAddr32 = (uint32) dataVal[0];
                dstAddr32++;
    		else
    			break;
        return status;
     *  \Function Name: Fls_Qspi_MemMapRead
     *   Function to perform reads from the flash memory.
        /* Destination address */
        uint8 *pDst = (uint8 *)NULL_PTR;
        uint8 *pSrc = (uint8 *)NULL_PTR;
        /* Transaction length */
        uint32 count;
        /* Memory mapped command */
        uint32 mmapReadCmd;
        uintptr_t temp_addr;
        uint32 dummyBytes, dummyBits;
        #if (FLS_DMA_ENABLE == STD_ON)
            uint32 dmaOffset;
            uint32 nonAlignedBytes;
            uint8 *pDmaDst  = (uint8 *)NULL_PTR;
            uint8 *pDmaSrc  = (uint8 *)NULL_PTR;
            uint32 dmaLen;
        #endif
            QSPI_Object  *object = ((QSPI_Config *)handle)->object;
            QSPI_Transaction *transaction = object->transaction;
            /* Extract memory map mode read command */
            mmapReadCmd = (uint32)object->readCmd;
            /* Set the number of address bytes  */
            HW_WR_FIELD32((FLS_QSPI_CTRL_BASE_ADDR+SPI_SETUP0_REG)+(FLS_QSPI_CS0 * 0x4U),
                        QSPI_SPI_SETUP0_REG_NUM_A_BYTES, (object->numAddrBytes - (uint32)1));
            dummyBytes = (object->numDummyBits / (uint32)8);
            dummyBits = (object->numDummyBits % (uint32)8);
                            QSPI_SPI_SETUP0_REG_NUM_D_BITS, dummyBits);
                            QSPI_SPI_SETUP0_REG_NUM_D_BYTES, dummyBytes);
                            QSPI_SPI_SETUP0_REG_RCMD, mmapReadCmd);
    		Fls_Qspi_MemMapRead_sub();
            temp_addr = (FLS_BASE_ADDRESS + (uintptr_t)transaction->addrOffset);
    	    pSrc = (uint8 *)(temp_addr);
            pDst = (uint8 *)transaction->buf;
            count = transaction->count;
            if(Fls_DrvObj.flsEdmaReadEnabled == TRUE){
                /* Check if the qspi memory address is 4 byte aligned. */
                dmaOffset  = (transaction->addrOffset + 0x3U) & (~0x3U);
                nonAlignedBytes = dmaOffset - transaction->addrOffset;
                pDmaDst = (uint8 *)(pDst + nonAlignedBytes);
                pDmaSrc = (uint8 *)(pSrc + nonAlignedBytes);
                dmaLen = count - nonAlignedBytes;
                /* Do the normal memory to memory transfer of nonAligned bytes at the start. */
                while(nonAlignedBytes != (uint32) 0U)
                    *pDst = *pSrc;
                    pDst++;
                    pSrc++;
                    nonAlignedBytes--;
                if (dmaLen != (uint32) 0U)
                    /* calculate the nonAligned bytes at the end */
                    nonAlignedBytes = dmaLen - ((dmaLen ) & (~0x3U));
                    /* Get the previous multiple of 4 of dmaLen as edma transfer can only be done with length in multiple of 4*/
                    dmaLen = (dmaLen ) & (~0x3U);
                    /* Do the normal memory to memory transfer of nonAligned bytes at the end. */
                    pDst = pDst + dmaLen;
                    pSrc = pSrc + dmaLen;
                        *pDst = *pSrc;
                        pDst++;
                        pSrc++;
                        nonAlignedBytes--;
                    if(dmaLen !=  (uint32)0U){
                        Fls_DrvObj.flsDmaStage = FLS_S_READ_DMA_WAIT_STAGE;
                        FLS_edmaTransfer(pDmaDst, pDmaSrc, dmaLen, handle);
                    else{
                        // dma is not triggered for lengths lesser than 4 bytes
                         Fls_DrvObj.flsDmaStage = FLS_S_READ_DMA_DONE;
            else{
            #endif
                while((count) != (uint32) 0U)
                    *pDst = *pSrc;
                    pDst++;
                    pSrc++;
                    count--;
            #endif
        else
            status = E_NOT_OK;
        return status;
    	    if(Fls_DrvObj.Fls_Mode == (uint32)FLS_QSPI_RX_LINES_QUAD)
                QSPI_SPI_SETUP0_REG_READ_TYPE, QSPI_MEM_MAP_READ_TYPE_QUAD);
    		else if(Fls_DrvObj.Fls_Mode == (uint32)FLS_QSPI_RX_LINES_SINGLE)
                QSPI_SPI_SETUP0_REG_READ_TYPE, QSPI_MEM_MAP_READ_TYPE_NORMAL);
            else if(Fls_DrvObj.Fls_Mode == (uint32)FLS_QSPI_RX_LINES_DUAL)
                QSPI_SPI_SETUP0_REG_READ_TYPE, QSPI_MEM_MAP_READ_TYPE_DUAL);
    		else
               /*Do nothing*/
     *  \Function Name: Fls_Qspi_ReadMemMapMode
     *   Function to perform reads from the flash in memory mapped mode.
    Std_ReturnType Fls_Qspi_ReadMemMapMode(QSPI_Handle handle, QSPI_Transaction *trans)
    		if(trans != NULL_PTR)
    			object->transaction = trans;
    			status = Fls_Qspi_MemMapRead(handle);
    			if(status != E_OK)
    				trans->status = SPI_TRANSFER_FAILED;
    			else
    				trans->status = SPI_TRANSFER_COMPLETED;
    		else
    			status = E_NOT_OK;
        else
            status = E_NOT_OK;
        return status;
     *  \Function Name: Fls_Qspi_ReadCmd
     *   Function to send specific commands and receive related data from flash
    Std_ReturnType Fls_Qspi_ReadCmd(QSPI_Handle handle, QSPI_CmdParams *rdParams)
    	uint32 rdData_Len = 0U;
    	uint32 wrdlen =8U;
        if(rdParams != NULL_PTR)
            QSPI_ConfigAccess cfgAccess = {0};
            uint32 frmLength = 0;
                        QSPI_MEM_MAP_PORT_SEL_CFG_PORT);
            if(rdParams->cmdAddr != FLS_QSPI_CMD_INVALID_ADDR)
                /* Total transaction frame length in words (bytes) */
                frmLength = QSPI_CMD_LEN + QSPI_ADDR_LEN +
                                    (rdParams->DataLen / ((uint32)8 >> (uint32)3U));
            else
                frmLength = QSPI_CMD_LEN + (rdParams->DataLen / ((uint32)8 >> (uint32)3U));
            /* Send the command */
            cfgAccess.buf = (uint8 *)&rdParams->cmd;
            cfgAccess.count = QSPI_CMD_LEN;
            cfgAccess.wlen = wrdlen;
            /* formulate the command */
            HW_SET_FIELD32(cfgAccess.cmdRegVal, QSPI_SPI_CMD_REG_FLEN, (frmLength - (uint32)1));
            HW_SET_FIELD32(cfgAccess.cmdRegVal, QSPI_SPI_CMD_REG_CSNUM, FLS_QSPI_CS0);
            HW_SET_FIELD32(cfgAccess.cmdRegVal, QSPI_SPI_CMD_REG_CMD,
                                QSPI_SPI_CMD_REG_CMD_FOUR_PIN_WRITE_SINGLE);
            HW_SET_FIELD32(cfgAccess.cmdRegVal, QSPI_SPI_CMD_REG_WLEN, (cfgAccess.wlen - (uint32)1));
    			HW_SET_FIELD32(cfgAccess.cmdRegVal, QSPI_SPI_CMD_REG_WIRQ, (uint32)1);
    			HW_SET_FIELD32(cfgAccess.cmdRegVal, QSPI_SPI_CMD_REG_FIRQ, (uint32)1);
    		#endif
            status = Fls_Qspi_ConfigWrite(handle, &cfgAccess);
            /* Send address associated with command, if any */
                cfgAccess.buf = (uint8 *)&rdParams->cmdAddr;
                cfgAccess.count = QSPI_ADDR_LEN;
                /* Number of address Bytes to bits. */
                cfgAccess.wlen = (uint32)rdParams->numAddrBytes << (uint32)3U;
                /* Update the command register value. */
            /* Send data associated with command, if any */
            if( rdParams->DataLen > rdData_Len)
                cfgAccess.buf = (uint8 *)rdParams->rxDataBuf;
                cfgAccess.count = rdParams->DataLen / ((uint32)8 >> (uint32)3U);
                                    QSPI_SPI_CMD_REG_CMD_FOUR_PIN_READ_SINGLE);
                status = Fls_Qspi_ConfigRead(handle, &cfgAccess);
        else
            status = E_NOT_OK;
        return status;
     *  \Function Name: Fls_Qspi_QuadReadData
     *   Function to read data from external flash
    Std_ReturnType Fls_Qspi_QuadReadData(QSPI_Handle handle, QSPI_CmdParams *rdParams)
    	uint32 wrdlen =8U;
            uint8 dummyBytes = (object->numDummyBits / (uint32)8);
                frmLength = (uint32)QSPI_CMD_LEN + (uint32)QSPI_ADDR_LEN + (uint32)dummyBytes +
                                    (uint32)(rdParams->DataLen / ((uint32)8 >> (uint32)3U));
            else
    		#endif
            /* Send dummy bytes associated with the read command */
            if( dummyBytes > (uint8)0U)
                cfgAccess.count = dummyBytes;
                cfgAccess.wlen = dummyBytes * wrdlen ;
                                    QSPI_SPI_CMD_REG_CMD_SIX_PIN_READ_QUAD);
        else
            status = E_NOT_OK;
        return status;
     *  \Function Name: Fls_Qspi_WriteCmd
     *   Function to send specific commands and related data to flash
    Std_ReturnType Fls_Qspi_WriteCmd(QSPI_Handle handle, QSPI_CmdParams *wrParams)
    	uint32 wrData_Len = 0U;
    	uint32 wrdlen =8U;
        if(wrParams != NULL_PTR)
            if(wrParams->cmdAddr != FLS_QSPI_CMD_INVALID_ADDR)
                                    (wrParams->DataLen / ((uint32)8 >> (uint32)3U));
            else
                frmLength = QSPI_CMD_LEN + (wrParams->DataLen / ((uint32)8 >> (uint32)3U));
            cfgAccess.buf = (uint8 *)&wrParams->cmd;
    		#endif
                cfgAccess.buf = (uint8 *)&wrParams->cmdAddr;
                cfgAccess.wlen = (uint32)wrParams->numAddrBytes << (uint32)3U;
            if( wrParams->DataLen > wrData_Len)
                cfgAccess.buf = (uint8 *)wrParams->txDataBuf;
                cfgAccess.count = wrParams->DataLen / ((uint32)8 >> (uint32)3U);
        else
            status = E_NOT_OK;
        return status;
     *  \Function Name: Fls_Qspi_WriteConfigMode
     *   Function to perform writes to the flash in configuration mode
    Std_ReturnType Fls_Qspi_WriteConfigMode(QSPI_Handle handle, QSPI_Transaction *trans)
            QSPI_CmdParams wrParams;
    		uint8 numVar = (uint8)object->numAddrBytes;
            wrParams.cmd = object->writeCmd;
            wrParams.cmdAddr = trans->addrOffset;
            wrParams.numAddrBytes = numVar;
            wrParams.txDataBuf = trans->buf;
            wrParams.DataLen = trans->count;
            status = Fls_Qspi_WriteCmd(handle, &wrParams);
    		else
    			status = E_NOT_OK;
        else
            status = E_NOT_OK;
        return status;
     *  \Function Name: Fls_Qspi_ReadConfigMode
     *   Function to perform reads from the flash in configuration mode
    Std_ReturnType Fls_Qspi_ReadConfigMode(QSPI_Handle handle, QSPI_Transaction *trans)
        QSPI_CmdParams rdParams;
        if (Fls_Qspi_ParamsInit(&rdParams) == E_OK)
            rdParams.cmd = object->readCmd;
            rdParams.cmdAddr = trans->addrOffset;
            rdParams.numAddrBytes = object->numAddrBytes;
            rdParams.rxDataBuf = trans->buf;
            rdParams.DataLen = trans->count;
    			if (Fls_Qspi_QuadReadData(Fls_DrvObj.spiHandle, &rdParams) == E_OK)
    				retVal = E_OK;
    			else
    				retVal = E_NOT_OK;
    		else
                retVal = E_NOT_OK;
        else
            retVal = E_NOT_OK;
        return retVal;
        volatile uint32 i = delay;
        while (i > 0U)
            i = i - 1U;
     *  \Function Name: Fls_IntClearDisable
     *   This function is used to disable and clear Interrupt Register.
    void Fls_IntClearDisable(void)
    void Fls_Interrupt_Enable(void)
            intrStatus = HW_RD_REG32(FLS_QSPI_CTRL_BASE_ADDR+QSPI_INTR_STATUS_RAW_SET);
            else
    #define FLS_STOP_SEC_CODE
  • Hello Danish,
    I am able to reproduce and debug this issue. Please update your Fls_Qspi_Edma.c file with attatched code (at location "MCAL_install_path\mcal\Fls\V0\Fls_Qspi_Edma.c).
    *   Copyright (C) 2023-24 Texas Instruments Incorporated
    *   All rights reserved. Property of Texas Instruments Incorporated.
    *   Restricted rights to use, duplicate or disclose this code are
    *   granted through contract.
    *   The program may not be used without the written permission
    *   of Texas Instruments Incorporated or against the terms and conditions
    *   stipulated in the agreement under which this program has been
    *   supplied.
     *  \file     Fls_Qspi_Edma.c
     *  \brief    This file contains FLS MCAL driver functions for using EDMA
    /*                             Include Files                                  */
    #ifdef __cplusplus
    extern "C" {
    #endif
    #define FLS_EDMA_QSPI_A_COUNT           (1U)
    /* Max Value for EDMA count */
    #define FLS_MAX_EDMA_COUNT              (31U*1024U)
    /* Value for C count */
    #define FLS_EDMA_QSPI_C_COUNT           (1U)
    /*                         Structures and Enums                               */
    /* None */
    void FLS_DmaRxIsrHandler(void* args);
    /* None */
    /* Requirements : MCAL-____ */
    sint32 Fls_Qspi_dmaChInit(Fls_DriverObjType Fls_DrvObj)
        sint32              status = MCAL_SystemP_SUCCESS;
        void * appdata = (void*) &Fls_DrvObj;
        status = Cdd_Dma_CbkRegister(FLS_UNIT_EDMA_HANDLER, appdata, &FLS_DmaRxIsrHandler);
        return status;
    void FLS_edmaTransfer(uint8* dst, uint8* src, uint32 length,
                           QSPI_Handle qspiHandle)
        Cdd_Dma_ParamEntry   edmaParam0 , edmaParam1;
        uint32 remaining_size , size, size_adjustment;
        /* Dma buffers and length */
        Fls_DrvObj.flsDmaLength = (((((QSPI_Config *)Fls_DrvObj.spiHandle)->object)->transaction)->count);
        Fls_DrvObj.flsDmaDstBuf = (uint8 *)(((((QSPI_Config *)Fls_DrvObj.spiHandle)->object)->transaction)->buf);
        size_adjustment = 0U;
        /* Chaining is done here fo DMA transfer so length is divided into logical two sizes */
        size = length/FLS_MAX_EDMA_COUNT;
        /* If size is less then 2 times of FLS_MAX_EDMA_COUNT in that case just dividing the length in 2 equal sizes */
        if(size < 2U)
            size = length/2U;
        else
        {   /* In order to prevent the remaining size to become 0 below implementation is done*/
            if((length % FLS_MAX_EDMA_COUNT) == 0U)
                size = (size-1U)*FLS_MAX_EDMA_COUNT;
            else
                size = size*FLS_MAX_EDMA_COUNT;
        // To make sure that dma_transfer length for edmaparam0 and edmaparam1 are aligned with 0x04
        if(((size)&(0x3U)) != 0U){
            size_adjustment = 2U;
        // size_adjustment to make size and length as multiple of 0x04
        size = size - size_adjustment;
        remaining_size = length-size;
        uint32 chainOption = (CDD_EDMA_OPT_ITCCHEN_MASK | CDD_EDMA_OPT_TCCHEN_MASK);
        /* edmaParam0 configuration */
        edmaParam0.srcPtr = src;
        edmaParam0.destPtr = dst;
        if(size > FLS_MAX_EDMA_COUNT)
            edmaParam0.aCnt      = (uint16) FLS_MAX_EDMA_COUNT;
        else
            edmaParam0.aCnt          = (uint16) FLS_EDMA_QSPI_A_COUNT;
        edmaParam0.bCnt          = (uint16) (size/edmaParam0.aCnt);
        edmaParam0.cCnt          = (uint16) FLS_EDMA_QSPI_C_COUNT;
        edmaParam0.bCntReload    = (uint16) (size/edmaParam0.aCnt);
        edmaParam0.srcBIdx       = (sint16) edmaParam0.aCnt;
        edmaParam0.destBIdx      = (sint16) edmaParam0.aCnt;
        edmaParam0.srcCIdx       = (sint16) FLS_EDMA_QSPI_A_COUNT;
        edmaParam0.destCIdx      = (sint16) FLS_EDMA_QSPI_A_COUNT;
        edmaParam0.opt           = (CDD_EDMA_OPT_SYNCDIM_MASK);
        /* edmaParam1 configuration */
        edmaParam1.srcPtr =  (void*)((uint32)(src) + size);
        edmaParam1.destPtr =  (void*)((uint32)(dst) + size);
        edmaParam1.aCnt          = (uint16) FLS_EDMA_QSPI_A_COUNT;
        edmaParam1.bCnt          = (uint16) (remaining_size/edmaParam1.aCnt);
        edmaParam1.cCnt          = (uint16) FLS_EDMA_QSPI_C_COUNT;
        edmaParam1.bCntReload    = (uint16) (remaining_size/edmaParam1.aCnt);
        edmaParam1.srcBIdx       = (sint16) edmaParam1.aCnt;
        edmaParam1.destBIdx      = (sint16) edmaParam1.aCnt;
        edmaParam1.srcCIdx       = (sint16) FLS_EDMA_QSPI_A_COUNT;
        edmaParam1.destCIdx      = (sint16) FLS_EDMA_QSPI_A_COUNT;
        edmaParam1.opt           =
            (CDD_EDMA_OPT_TCINTEN_MASK | CDD_EDMA_OPT_ITCINTEN_MASK | CDD_EDMA_OPT_SYNCDIM_MASK);
        /* Write edmaParam0 param set for fls_read */
        Cdd_Dma_ParamSet(FLS_UNIT_EDMA_HANDLER,0,0,edmaParam0);
        /* Write edmaParam1 param set for fls_read */
        Cdd_Dma_ParamSet(FLS_UNIT_EDMA_HANDLER,1,0,edmaParam1);
        Cdd_Dma_ChainChannel(FLS_UNIT_EDMA_HANDLER,0,0,1,chainOption);
        /* Set manual trigger to start QSPI transfer */
        Cdd_Dma_EnableTransferRegion(FLS_UNIT_EDMA_HANDLER,CDD_EDMA_TRIG_MODE_MANUAL);
        return;
    void FLS_DmaRxIsrHandler(void *args)
        Mcal_CacheP_inv((void*) Fls_DrvObj.flsDmaDstBuf, Fls_DrvObj.flsDmaLength, Mcal_CacheP_TYPE_ALLD);
    #ifdef __cplusplus
    #endif
    #endif//#if (FLS_DMA_ENABLE == STD_ON)
    Do let me know if you still face issues with it.
    Gunjan
  • Hello Danish,
    Can you confirm if you are using LGIT patch for FLS DMA or latest MCAL package10.00?
    In case you are on LGIT patch please use this code instead of previous one.
    *   supplied.
    /*                             Include Files                                  */
    #ifdef __cplusplus
    extern "C" {
    #endif
    /* None */
    volatile uint32 Fls_DmaLength = 0;
    #define FLS_START_SEC_VAR_NO_INIT_PTR
    volatile uint8 * Fls_DmaDstBuf = NULL_PTR;
    #define FLS_STOP_SEC_VAR_NO_INIT_PTR
        return status;
        Fls_DmaLength = (((((QSPI_Config *)Fls_DrvObj.spiHandle)->object)->transaction)->count);
        Fls_DmaDstBuf = (uint8 *)(((((QSPI_Config *)Fls_DrvObj.spiHandle)->object)->transaction)->buf);
        if(size < 2U)
            size = length/2U;
        else
            else
        if(((length)&(0x3U)) != 0U){
        else
        edmaParam1.opt           =
        return;
        Mcal_CacheP_inv((void*) Fls_DmaDstBuf, Fls_DmaLength, Mcal_CacheP_TYPE_ALLD);
    #ifdef __cplusplus
    #endif
    Gunjan
