Part Number: TMS570LC4357
Other Parts Discussed in Thread: NOWECC, UNIFLASH
ECC can be generated using the linker scripts as per https://software-dl.ti.com/codegen/docs/tiarmclang/rel4_0_0_LTS/compiler_manual/linker_description/05_linker_command_files/configuring-error-correcting-code-ecc-with-the-linker-lit40948978.html#:~:text=To%20enable%20ECC%20generation%2C%20you,in%20the%20linker%20command%20file.
I wanted to check when would one require to use nowECC tool?
