Part Number: MCU-PLUS-SDK-AM243X
Other Parts Discussed in Thread: DP83826E, DP83869, SYSCONFIG
Hi all,
I have started working on Ethernet/IP protocol from few weeks and I have tried to run and study the example called "ethernetip_adapter_demo" contained inside examples folder in SDK 9.02.15.
Once loaded example on my AM243x LaunchPad(that works as a slave), I have tried to connect to the slave with a SW on my PC in a private local network that works as a Master.
For example, if I select "Input Only" command for reading attributes from the Slave, I see that the communication between Master and Slave lasts for 8 times.
After that, Master stops to send anything, but Slave continues to send other 8 messages.
Then, Slave closes TCP connection.
Why does the communication make sense only for the first 8 messages and after that Slave continues to send messages without a request from Master?
You can see the log from WireShark as attachment.
Thank you.
Stefano
