Part Number: MSPM0G1105
MSPM0G1105とST7066Uを内蔵した液晶を接続しようと考えています。
最小限の構成で接続する方法について何かアイデアがあれば、私に知らせてください。
よろしくお願いいたします。
よろしくお願いいたします。
I am checking on the datasheet of the ST7066U. It looks like you only need to connect pins in the red block between a MCU and ST7066U. And you can use any MCU's GPIO pin for the connection. No special needs in those ports.
Cash Hao
Hi Cash
Thank you for your quick reply as well.
Is GPIO the minimum configuration?
I'm currently considering 4-bit mode, where only the upper 4 bits of DB7-DB4 are connected.
That was helpful.
Hiroshi Yamada
HI,
That is fine. GPIO can meet the connection requirement for 4 bits mode.
Cash Hao
Hi Cash
Thank you for your support until the end.
Consider using 4bit mode connection.
Hiroshi Yamada
