Part Number: MSPM0G3107
Other Parts Discussed in Thread: LP-MSPM0G3507
Hi there,
I recently started experimenting with the Launchpad LP-MSPM0G3507 under macOS/CCS Theia. In general, I’m a fan of your strategy to transition from Eclipse to Theia. I’ve already gained some experience with VS Code and am very enthusiastic about the plugin concept. However, I’m encountering some issues with the current version 1.5.1.3 regarding unit testing:
- I’m unable to install plugins like C++ TestMate. Will this feature be available soon?
- To at least debug my unit tests (built using a Makefile) via Theia GUI, the debugger would need to be configurable for host debugging. Unfortunately, the only supported “type” in the launch.json is “ccs-debug.” A plugin could solve this, but as mentioned above, I can’t install any plugins.
- As an alternative, I tried installing the TI plugin under VS Code, but I’m encountering an error when trying to install the “dependencies” on macOS.
As it stands, working with CCS Theia isn’t much fun for me yet. Could you help me out?
Thank you very much and best regards,
Marco
